Question about Peavey Pv 2600 Power Amplifier
Can one(1) Peavy PV 2600 amp provide enough power for two(2) Yorkvilles 15" 300W full range and two(2) Yorkvilles 18" 400W subwoofers?
  • Peavey Master
  • 5,603 Answers
It should be able to do this. You would need to put each type speaker on a seperate side and then use either an elctronic crossover or an EQ set to pass only lows into the side for the subwoofer to block sending highs to the subs.
Posted on Sep 16, 2010
  • 1 more comment
  • Glen
    Glen Oct 28, 2010
    I agree with fredy2 as it will work BUT with four cabinets (and two of them being subs!) your system is grossly underpowered. Check out the great deals on Crown XLS amps happening right now. These are headed to "discontinued" land but are backed by Crowns 3-year warranty so no worries.
  • Matthew Spark
    Matthew Spark Nov 30, 2010
    the amp is 900 watts per channel at 4 ahms, which would be the load with 4 speakers, assuming the speakers are 8 ophms apiece. that is plenty of power for what he has, a little more, actually. freddy is right for the most part. hook the mains up to i channel, and the subs to the other channel, ands get a passive crossover to send the lows to the sub channel and the highs to the mains channel.
  • Power Electronics
    Power Electronics Nov 07, 2013
    Actually you don't need to hook it up with an active xover, since the PV2600 is equipped with an internal one that sends only low frequency to low's and low cut for up's
Pv 2600 manual como conectar subwoofer
Peavey service is quite helpful and has most parts in stock for good prices. Call them directly at (800) 752-7896
Jun 22, 2014 | Peavey PV 2600 Power Amp
One chanel of my pv 2600 amp is playing very low
Clean all back switches first of all, use a cleaning solution spray and give a 3 shot per switch, then push in-n-out several times each one and check amp functionality again.
May 29, 2011 | Peavey Pv 2600 Power Amplifier
As a starting point clean ALL switches on the back of your amp, including the Stereo/Bridge switch then re-check functionality, good luck.
Can i connect the pv 112 to the pv 118 subwoofer since the powered mixer i bought it only has 2 main outputs? The powered mixer I bought is the PV XR 8600D powered mixer...
Generally speaking you should only send low frequencies to subs. The highs, while lower in power than the lows, will over time harm the voice coils. The ideal way to do this is to use an external crossover netween the main output and the amp input with the higher range going to a general set of speakers. Send the lows through the second channel of the amp and then to the subs.
In short, while not recommended, yes you can hook them up in parallel.
Dan
Dec 09, 2010 | Peavey Pv118 1x18" Subwoofer Speaker...
I have Peavey Pv 2600 Power Amplifier ,the B side did not work sound did not come
One side of the amp has failed and repair is NOT DIY. Take it in for servicing. This amp has many components in the power amp and repair is complicated. A failure can lead to 20 components being damaged. Failure to replace all damaged ones can result in immediate failure destroying the replaced ones.
Aug 28, 2010 | Peavey Pv 2600 Power Amplifier
My peavy has three lights at power on when in use red light comes on is that beacuse my amp is overheating or is it normal it does that when i crank the volume amp i not hot well vented
Here is a link to the manual:http://www.peavey.com/assets/literature/manuals/00512180.pdf Page8 sections 2 through 4 discusses the LEDs. I think what you arte talking about is the DDT active LEDs. Page 12 specifically discusses this and page 15 notes that Red signifies DDT clipping. Peavey recommends that you don't defeat the DDT circuit and that is good advice as it protects your amp and your speakers. The clipping is not caused by the amp but by the amount and quality of signal being input. Check earlier in your signal chain for the cause.
Aug 14, 2010 | Peavey Pv 2600 Power Amplifier
Do you know what regulator/ rectifiers are used and their numerical values so i can repair my fried pv 2600 these are the row along heat sink small black ones 2 pin and 3 pin cheers
7815 and 7915 plus and minus regulators specifically. Diodes fr the 15 supplies are 1N4001 but you can use 1N4007 or anything in between.
Big power rectifiers are 2504's... which are probably 25 amp 400 volt modules.
Jul 18, 2010 | Peavey Pv 2600 Power Amplifier
CAN I POWER UL15 AND XT115 [WITH CROSSOVER] WITH 1 AMP
You need 1 channel of amplifier per stack. Assuming the ul 15 is a full range box, and the XT115 is a subwoofer. But be careful with your Ohm ratings for the speakers and your power ratings of your amps. You want the proper Ohm load on the amplifier for maximum power. And use proper speaker cable, with correct wiring.
Wire the to the sub first, and then jump to the ul 15.
Feb 20, 2010 | Peavey Pv 2600 Power Amplifier
In the wirring is there any way of making the amp produce a high out sound rather than full range
Unfortunately range and power are not correlated. Good amps have a full range, cheap ones do not....range it not related directly to power output.
What are you trying to accomplish exactly?
Thanks!
Feb 03, 2010 | Peavey Pv 2600 Power Amplifier
Amp will not come on
hi thanks for using fixya!!
On this error, you should check still the built in breaker.
Apr 21, 2009 | Peavey Pv 2600 Power Amplifier
Peavey Pv 2600 Power Amplifier Logo
228 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Peavey Music Expert? Answer questions, earn points and help others
