Question about Sony Playstation 3 (PS3) Console
Movies yes i was wanting to know how i can watch my movies in 1080i on my playstation 3 and do i need to buy certain cables can you help
U might need a hdmi cable
Posted on May 17, 2008
Hi,I have a XP-65DHD RUNCO PLASMA DISPLAY when I want to play a blu-ray movie on 1080p the screen starts flickering so I have to watch the movies on either 1080i or 720p,I really don't know what to do
If you got a blueray player (the hardware) it should have come with a disk with software. If you got the OEM version without, you need to buy your own software. PowerDVD should work. If you are somehow looking to download something to play bluray disks on a PC without an actual bluray player, you need to buy the drive.
Mar 21, 2014 | Runco CW42i 42 in. HDTV-Ready Plasma...
Tip
So you just got your new HDTV and the piture isn't as good as you thought.
There are some things you need to know when setting up your HDTV.
First off, you need to use HDMI cables to connect your tv to your cable box or you will not get HD. That being said the first thing you will find is that HDMI cables are expensive. Although you can buy a really cheapo cheap one, be careful. Make sure it can support 1080p or the max resolution your TV displays at. Some of the cheaper ones can only support up to 720p.
So you hooked it up to the cable box using an good HDMI cable and you still do not have the picture you should. There are a few things you may still need too do to get 1080i out of it. Yes, I said 1080i. Even though your tv may be up too 1080p, cable and dish networks only transmit up too 1080i. But don't worry, 1080i is amazing for cable/dish.
First thing you need to make sure of is, does your cable/dish receiver support HD? If you have had the same box for a long time, it may not. You will have to call your provider to get an updated box. If you recently got cable/dish and the box is new, most likely your good to go. Also, it will most likely say on it, HDTV, 1080i or something related to HD on it.
Now you are good to go with you box because it is in fact HD compatible. Some cable boxes may need to be configured for HD. You don't need an HDTV signal if you don't have an HDTV, and not every one does, so why send the unit configured for HD. You need to go into your cable/dish settings and make sure you set the HD set up to display in 1080i.
Okay you set the box to 1080i. There still could be some setting on the TV if your not getting the best picture.
Make sure you are on an HD channel. Make sure you do not have zoom on, and that the TV is set to display an aspect ratio that is determined by the program, or auto. Not all TV's have these settings. Likewise, some tv's allow you to select the max resolution, if this is the case make sure it is set to 1080p, the max it can be.
You should at this point have an excellent picture on the HD channels. Not all channels are HD.
Now, a few other things not worthy as a new owner of an HDTV.
a standard dvd player does not play in high def. they have a max resolution of 480p. 480p is going to look really good if its the first time you watch a dvd on an HDTV, but it can be a lot better. For around starting at $45 and up, you can buy a DVD player that can upscale your dvd's to 1080p when you use HDMI and you will get amazing picture. But for around starting at anywhere from $100 to $150 and up, you can get your self a blu-ray player that will play blu-ray disks, and give you amazing beyond belief picture, and it will upscale your dvd's.
So you got a blu-ray. First thing I can say is I hope your refresh rate is at least 120hz or better. 60hz may disappoint you with a blu-ray player.
Blu-ray can play movies in their native 24 frames a second format of which they were filmed in. However, at 60hz, you will run into a problem trying to play the movie in 24fs. now I am not going to get technical with this, just to let you know, you need 120hz or better to use 24fs. You can turn it off, but you will get blur and it will not be as smooth. As well, with most players you must enable 24fs in the settings, usually by default, it is off,
So to recap:
  • Make sure your cab/dish box is HD compatible.
  • Always use HDMI cables.
  • Check settings on cable/dish box and make sure its set to 1080i.
  • don't use zoom.
  • If applicable, make sure tv settings are at max res of 1080i
  • you need an upscaling DVD player or Blu-ray player to watch your DVD's in HD.
  • Also must us HDMI.
  • Can't use 24fs if you have 60hz refresh rate, but can if 120 or better.
  • 24s is usually off by default.
on Mar 06, 2010 | Televison & Video
My playstation volume wont work.what should i do?
Try changing the PS3 Sound output settings, check the cables leading to the console and TV, and if that doesn't solve it, watch another movie, then come back to the original. If it is one movie in particular, you may want to contact Netflix online at netflix.com/youraccount. Here, you can click the "Report problem" next to movies you've watched recently to tell Netflix about the issue.
Oct 24, 2012 | Sony Playstation 3 Black Console
Ps3 only displays in 1080i
I have similar problem , ps3 320gb + 5 years old sony bravia 1080p = everything OK
but when i connect ps3 to new samsung ue46d7000 1080p = doesn't work (only 1080i)
I am using same HDMI cable
Jun 19, 2012 | Sony Playstation 3 (PS3) Console
Can playstation act as dvd player or i should buy dvd player separately?
Yes, it can play DVD movies as well as Music CD'S and CD-R's music. You dont have to buy another machine. One tip thou when using it as a DVD plyr you might put it where ventilation can get to it - due to the overheating problem PS2 has. I use mine all the time, and I put a fan next to it, so I can play longer and watch movies longer. I hope this helps. Good Luck.
Jul 20, 2010 | Sony PlayStation 2 (PS2) Console
I have a playstation 1 game that i play on my 3,
Yes, GameStop and EB games both sell an adaptor you can buy, I believe it's around $20 that allows you to save and copy your data from the PS3. I have Gran Turismo 3 and I had just about everything in it on my PS2; I thought I had to start all over when I got my PS3 but I got one of these adapters and it worked wonders. Same applies for PS1 games.
Good luck and if I've helped you please give me a good rating.
Respectfully,
Don
May 10, 2010 | Sony Playstation 3 (PS3) Console
Multizoning my playstation 3
Yes, but is easy if you have a A/V Receiver like a Marantz or Yamaha and put in the "MultiZone" Out, in Marantz you can see in your room example a Cable, and in MultiZone a PS3 DVD, 2 outs with 1 source (Receiver).
May 08, 2008 | Sony Playstation 3 (PS3) Console
Sharp Aquos LC-32D43U
To adjust screen size, choose the View Mode feature on the top right of the remote control. Zoom size is full screen for watching DVD movies, but sometimes there is still a thin black band due to the formatting of the dvd (unless you buy full screen versions) S. Stretch view mode is best for TV Movies.(usually fills whole screen) Occasionally there are TV movies which just don't respond to being stretched to fill the screen, it's just the way the signal is coming through . 1080i/p detects the resolution of the signal and displays the same number of pixels on the screen, but a 720p signal input will be viewed in full screen.
Jan 25, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Ps3 hook up
Yes, you can! But not straight out of the box. You need to purchase a DVI to HDMI cable adapter. It will convert it so your tv can use it. Here is a link to some:
http://www.connectworld.net/syscon/dvi-to-hdmi-adapters.html
Hope this helps! Please rate me!
Jan 20, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
26 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
