Question about Dishwashers
I HAVE A BOSCH D/W MODEL SHU4306 AND PUT A NEW BOARD IN IT AND IT WORKS BUT NOW THE CLEAN LIGHT STAYS ON ALL THE TIME WHY ?
  • Dishwashers Master
  • 2,605 Answers
Welcome to FixYa.
Since you`ve installed the control, what cycles have you used and have you run more than one time through ?
Can I ask why the control was changed or suspect ?
These when answered can be insightful in a diagnosis, I hope you can appreciate the process.
For now though I`d suggest running a diagnostic cycle, here`s how...
**To bypass a function: SHI/U 43-- Press the SCRUB WASH butto**
SHI/SHU 43— MODELS
To begin the test program, press the POWER SCRUB PLUS and REGULAR WASH buttons both in at the same time as
you turn the unit on by pressing the ON/OFF button.
When released the LEDs for the two programs will begin flashing.
To check all LED indicator lamps press the SCRUB WASH button.
To start the test program, press the POWER SCRUB PLUS and REGULAR WASH buttons both in a second time.
When the test program is complete, if a fault is detected the following indicator LEDs will be illuminated.
WASH = Heating Fault
RINSE/DRY = Filling Fault
CLEAN = NTC Fault
Let me know what you find and I`ll try to help move you forward from there.
Please keep me posted, Good luck.
Regards,
Macmarkus :)
Posted on Sep 15, 2010
Panel light on Bosch microwave out but works fine. I'm just flying blind
I have had sometmes where bad solder connections on the display crystal stopped the display from working. May be worth a look at the connection on the main board where the display crystal is soldered to the board. If not, new main circuit board $$$$. Sharp uses a conductive rubber pad below the crystal to conduct power to the display. It is possible Bosch did something like that too. If so remove the main board, see how the crystal is connected to the board. Clean the rubber conductive pad or look for bad solder connections.
Sep 30, 2017 | Bosch Microwave Ovens
Tip
Bosch DIshwasher Woes
Does you Bosch dishwasher seem to hang up at finishing the dish washing cycle?<br><br>Since originally writing this tip 2-3 years ago (2009 maybe?), I have provided the upgrade to countless others who have had the problem. Here it is, 2013, and I continue to upgrade several control son a weekly basis. Please follow the information below, and I can assure you that your dishwasher will be up and running again - better than new!<br><br>I happen to own one of these beauties, and SHU4306, and while all the Bosch dishwashers in this series of dishwashers do an excellent job of washing the dishes, they also have a design flaw that is very expensive to fix as it requires a new controller board.<br><br>But the problem surfaced with our dishwasher a few months ago, and I was put to the test by the resident dishwasher at out house, who is not happy when the dishwasher is broken.<br><br>There is a relay on the controller board that will fail, sooner or later. Bosch even has a service bulletin for their techs on a recommended procedure to repair a burned place on the circuit board underneath the relay. However, the repair is short term, and eventually the relay will fail again (I know, I tried it.). The repair is not sufficient, and there really is a more economical, and more technically correct, way to repair the board.<br><br>After the Bosch directed repair failed, I pulled off my dufus cap, put on my Engineering cap, and dug in. Here, I found the failed relay, and discovered the flaw in the board design. I ordered a more substantial replacement, and two days later, I was up and running.<br><br>I know that the failure occurs on the following Models-<br><br>SHI<br><br>4302 4306<br><br>6802 6805 6806<br><br>SHU<br><br>3032 3035 3036<br><br>3302 3305 3306 3322 3326 3336<br><br>4302 4306 4312 4316 4322 4326<br><br>5302 5304 5305 5306 5307 5312 5314 5315 5316 5317<br><br>6802 6805 6806<br><br>9902 9905 9906 9912 9915 9916 9922 9925 9926<br><br>SHV<br><br>4303 4803<br><br>There may be others, and, other manufacturers may have similar issues.<br><br>Bosch also provides a test sequence for their dishwashers that anyone can put the dishwasher through to help isolate what the problem might be. I am sure other dishwasher manufacturers do the same, and I will continue to dig for those sequences as time permits.<br><br>Contact me for additional help and support in determining the cause of your failure, and instruction on what parts to purchase or what to do next. (Don't throw the dishwasher out with the dishwater, so to speak!.).<br><br>You can reach me at - BoschRepair "at" tx.rr.com - (type it in as an email address, just like it sounds :-) ).<br><br>I can also make repairs to failed boards, where I make the needed repairs and test the board on a test bench made up of the same components that are found in the dishwasher. I do this with quick turn around, normally shipping the boards out the same day I receive them.<br>All repairs are made taking into consideration my years of experience in HVAC and appliance repairs, including working as an Engineer in design of such equipment, working with listing agencies such as U/L and CSA. I know what the concerns are, and will only make repairs that I deem are suitable and equally if not more safe than the original design.<br><br>I can easily save you the cost of a new board, as my repairs are 1/4 the cost of a new board.<br><br>Looking forward to hearing from you!<br>
on Dec 18, 2009 | Dishwashers
Why doesn't the clean light come on at end of cycle of my Bosch dishwasher?
It's an energy-saving feature. This is one of the ways the DW gets a good Energy Star rating. Having a light come on and stay on would use electricity. Depending on the model, it will tell you when it is working (red light, projected graphic, etc.), and when it no longer says it is working, then it's done. No light necessary.
Jul 03, 2017 | Bosch Dishwashers
Please can someone advise how to get at the switch board for a Bosch cooker hood E-Nr DKE 995 A GB and FD 8009.
many of the switches used are of the push in type and have little clips on the sides that need depressed to extract the switch . without the ability to see exactly what you have make it impossible for us to assist . contact an electrician locally .
Sep 21, 2016 | Bosch Kitchen Ranges
Will not stay light,put in new flame sencer & cleaned all grounds what else may be wrong ?
If flame stays on a few seconds it may be the control board, depending on model/brand there may be a bad connection on the circuit board, solder joint may be cracked not allowing the sensor to send signal to control board. Also check the sensor wire as it may be bad.
Note: make sure all the burners are igniting and clean gas orifices as necessary.
Oct 16, 2011 | Dayton Gas Furnace Heater
Pilot light will not stay on Bosch natural gas tankless water hea
Check to make sure the flame of the pilot is hitting the thermocoupling. If not then you can use compressed air to clean the pilot port and relight and check again. If the flame is hitting the thermocouple, then it may need to be replaced.
May 05, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
I have a bosch dishwasher its described on the front as a clasixx maxx freedome performance but doesn't seem to have a model number. how can i get it
The Bosch model and serial number are located on a sticker generally found on the right hand side of the door as well as underneath the kick panel at the floor. Remove the end screws of the kick panel and near center you will see a model number generally starting with SH... MINE is an SHU4306 / UOC series 006
Nov 06, 2009 | Bosch Dishwashers
Dishwashers Logo
69 people viewed this question
Top Dishwashers Experts
