Question about Samsung 18.8 Cu. Ft. Bottom-Mount Refrigerator - Black
Upper part of fig. is not cooling, freezer is working great.
  • Samsung Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 16, 2010
Change out cooling system radiator
RADIATOR
REMOVAL 1) Disconnect negative cable from battery. 2) Discharge the A/C system. 3) Remove the front fascia.
WARNING: DO NOT REMOVE THE CYLINDER BLOCK PLUG OR THE RADIATOR DRAINCOCK WITH THE SYSTEM HOT AND UNDER PRESSURE BECAUSE SERIOUS BURNS FROM COOLANT CAN OCCUR. 4) Drain the cooling system. 5) Disconnect the radiator fan electrical connectors. 6) Disconnect coolant reserve/recovery hose. 7) Remove A/C lines. 8) Remove the auxiliary transmission cooler hoses. 9) Remove the pushpins and the upper radiator seal.
10) Remove the pushpins and the LH and RH radiator seal (Fig. 20).
11) Remove the A/C condenser side brackets to radiator attaching screws (Fig. 22). Separate the condenser from the radiator by lifting upward to disengage from lower mounts (Fig. 22). Allow the condenser to rest in front of radiator. 12) Remove the upper and lower radiator hoses.
13) Radiator can now be lifted free from engine compartment. Care should be taken not to damage radiator cooling fins or water tubes during removal. (Fig. 21) 14) Remove the auxiliary transmission from the radiator module. 15) Remove the cooling fan assembly from the radiator module. INSTALLATION
1) Install A/C condenser, (if removed). 2) Install radiator fan assemble, if removed. 3) Install auxiliary transmission cooler, if removed. 4) Slide radiator down into position. Seat the radiator with the rubber isolators into the mounting holes provided, with a 10 lbs. force. 5) Install mounting screws. 6) Connect the cooling fan electrical connector. 7) Install the radiator upper and lower hoses 8) In the LH and RH radiator seals. 9) Install the upper radiator seal. 10) Install the auxiliary transmission cooler hoses. 11) Connect the coolant reserve/recovery hose. 12) Install the front fascia. 13) Fill the cooling system. 14) Connect negative cable to battery
Apr 02, 2014 | 2004 Chrysler Pacifica
Thermostat on 2005 aviator location
Removal & Installation
Print
4.6L & 5.4L SOHC Engines
  1. Partially drain the engine cooling system to a level below the thermostat.
  2. Disconnect the upper radiator hose from the water outlet adapter.
  3. Remove the power steering reservoir upper mounting bracket.
  4. Remove the bolts and remove the water outlet adapter.
  5. Remove the water thermostat and the O-ring seal. Discard the O-ring seal.
  6. Installation is the reverse of the removal procedure. Tighten the water outlet adapter bolts to 18 ft. lbs. (25 Nm). Tighten the power steering reservoir upper mounting bracket as shown in the accompanying illustration.
    Fig. View of the power steering reservoir upper mounting bracket and tightening specifications
    Fig. Exploded view of the water outlet adapter and tightening specifications
5.4L & 6.8L Engines
  1. Partially drain the cooling system to a level below the thermostat.
  2. Disconnect the upper radiator hose.
  3. Remove the coolant outlet connection, as follows:
    1. Remove the bolts.
    2. Remove the coolant outlet connection.
  4. Remove the (A) coolant thermostat and the (B) O-ring seal.
  5. Discard the (B) O-ring seal.
    Fig. Remove the (A) coolant thermostat and the (B) O-ring seal
To install:
NOTE Thermostat must be installed as illustrated.
  1. Use a new (A) O-ring seal to position the (B) coolant thermostat in the (C) upper intake manifold.
    Fig. Use a new (A) O-ring seal to position the (B) coolant thermostat in the (C) upper intake manifold
  2. Install the coolant outlet connection, as follows:
    1. Position the coolant outlet connection on the upper intake manifold.
    2. Install the bolts and tighten to 15-22 ft. lbs. (20-30 Nm).
  3. Connect the upper radiator hose.
  4. Fill the cooling system.
  1. Before servicing the vehicle, refer to the precautions section.
  2. Partially drain the cooling system to a level below the thermostat.
  3. Disconnect the upper radiator hose.
  4. Remove the coolant outlet connection, as follows:
  5. Remove the (A) coolant thermostat and the (B) O-ring seal.
  6. Discard the (B) O-ring seal.
To install:
5.4L DOHC Engine
  2. Disconnect the upper radiator hose, the heater water inlet hose and the heated PCV inlet hose from the water outlet adapter.
    Fig. Disconnect the upper radiator hose, the heater water inlet hose and the heated PCV inlet hose from the water outlet adapter
  3. Remove the water hose connection and thermostat.
  4. Installation is the reverse of the removal procedure. Tighten the mounting bolt to 18 ft. lbs. (25 Nm).
    Fig. Exploded view of the thermostat-5.4L DOHC engine
Aug 13, 2012 | 2004 Lincoln Aviator
Thermastat diagram install
Thermostat - 3.0L (2V) Removal and Installation
  1. Partially drain the engine cooling system. For additional information, refer to COOLING SYSTEM DRAINING, FILLING AND BLEEDING .
  2. Remove the three thermostat housing bolts. Fig. 25: Removing Thermostat Housing Bolts
    Courtesy of FORD MOTOR CO.
  3. Remove the thermostat O-ring seal.
  4. To install, reverse the removal procedure.
Thermostat - 3.0L (4V) Removal and Installation
  1. Raise and support vehicle. For additional information, refer to JACKING & HOISTING .
  2. Remove the front splash shield. For additional information, refer to FRONT END BODY PANELS .
  3. Drain the cooling system. For additional information, refer to COOLING SYSTEM DRAINING, FILLING AND BLEEDING .
  4. Remove the cooling tube bolt. Fig. 27: Removing Cooling Tube Bolt
  5. Lower the vehicle.
  6. Remove the radiator upper cooling tube bolt. Fig. 28: Removing Radiator Upper Cooling Tube Bolt
  7. Disconnect the upper radiator hose and engine vent hose. Fig. 29: Disconnecting Upper Radiator Hose And Engine Vent Hose
  8. Remove the two bolts, and separate the radiator tube from the thermostat housing. Remove the thermostat. Fig. 30: Removing Bolts And Separating Radiator Tube From Thermostat Housing
  9. To install, reverse the removal procedure.
Apr 22, 2012 | 2002 Ford Taurus
Were is my thermostat in my 1997 eagle vision
REMOVAL & INSTALLATION
  1. Disconnect negative battery cable. CAUTION
    Do not remove the radiator pressure cap with the cooling system hot and under pressure. Serious burns from hot, pressurized coolant can result.
  2. Allow cooling system to cool completely. Place a pan under the radiator drain, located at the lower right side of the radiator. Open the valve to drain the cooling system to a level just below the thermostat. Do NOT drain the cooling system completely, unless the coolant is being changed. Close the valve.
  3. Loosen the radiator hose clamp from the upper radiator hose at the thermostat housing and if necessary disconnect the hose from the housing. Fig. 1: Loosen the radiator hose clamp from the upper radiator hose at the thermostat housing 88173p06.jpg
    Fig. 2: If necessary, separate the upper hose from the thermostat housing (it is not required) 88173p11.jpg
  4. Remove the thermostat bolts and housing. Fig. 3: Loosen the thermostat housing bolt with the proper size socket 88173p07.jpg
  5. Remove the thermostat and discard the gasket. Thoroughly clean both gasket sealing surfaces. Fig. 4: Separate the housing to access the thermostat 88173p08.jpg
    Fig. 5: Lift the thermostat out . . . 88173p09.jpg
    Fig. 6: . . . then clean the mating area 88173p10.jpg
    To install:
  6. Clean the thermostat housing bolts well. On any engine, bolts that thread into the water jacket are subject to rust and corrosion. A bolt with rust or debris in the threads can easily strip out the threads in an aluminum manifold requiring a time-consuming thread repair operation. Clean the bolts well and lightly lubricate before installation.
  7. Install the thermostat into the recess in the intake manifold. Place a new gasket, moistened with water, on the water inlet mating surface on the intake manifold.
  8. Install the thermostat housing over the gasket and thermostat and tighten the mounting bolts to 21 ft. lbs. (28 Nm) on the 3.3L engine and 105 inch lbs. (12 Nm) on the 3.5L engine.
  9. Connect the upper radiator hose to the thermostat housing and tighten the radiator hose clamp.
  10. Refill and bleed the cooling system.
Aug 19, 2010 | 1997 Eagle Vision
I am trying to remove my radiator and place it with a new one? I have a 1998 Dodge Grand Caravan.
Chrysler Caravan/Voyager/Town and Country 1996-1999
Radiator - REMOVAL & INSTALLATION
Fig. 1: Before removing the hood latch, mark it's location on the crossmember with a paint marker or other tool
  1. Disconnect the negative battery cable.
CAUTION Do not remove the radiator cap or drain with the cooling system hot and under pressure or serious personal injury can occur from hot pressurized coolant.
  1. Place a drain pan under the radiator drain. Open the radiator drain plug and allow the coolant to drain.
  2. Remove the air intake resonator from the air cleaner assembly.
  3. Remove the Coolant Recovery System (CRS) overflow tank filler neck hose.
  4. Disconnect the cooling fan electrical connector located on the left side of the cooling fan module.
  5. Remove the CRS overflow tank mounting screw from the upper radiator crossmember.
  6. Remove the upper radiator-to-crossmember mounting screws.
  7. If equipped, disconnect the engine block heater wiring connector.
  8. Remove the upper radiator crossmember.
Fig. 4: ... and the upper radiator-to-crossmember bolts, then ...
Fig. 5: ... unbolt the crossmember ...
Fig. 6: ... and lift it from the front of the vehicle
  1. Remove the entire air cleaner assembly.
  2. Disconnect and plug the automatic transaxle oil cooler lines from the radiator.
  3. Disconnect the upper and lower radiator hoses from the radiator. Remove the lower radiator hose clip from the cooling fan module.
  4. Remove the A/C condenser mounting fasteners and separate the A/C condenser from the radiator. Be sure the condenser is supported in position.
  5. Remove the A/C filter/drier mounting bracket, 2 mounting bolts to the cooling fan module and 2 mounting nuts to the filter/drier. Remove the mounting bracket.
  6. Carefully lift the radiator out of the engine compartment. Be careful not to damage the radiator cooling fins or water tubes during removal.
To install:
  1. Be sure the air seals are properly positioned before installation of the radiator. Lower the radiator into position and seat the radiator with the rubber isolators into the mounting holes provided.
  2. Install the A/C filter/drier and mounting bracket onto the cooling fan module. Install the bracket mounting fasteners.
  1. Install the A/C condenser to the radiator.
  2. Unplug and connect the transaxle oil cooler lines to the radiator.
  3. Connect the upper and lower radiator hoses to the radiator.
  4. Connect the CRS overflow tank filler neck hose to the radiator.
  5. Reconnect the cooling fan motor electrical connector.
  6. Install the entire air cleaner assembly.
  7. Install the upper radiator crossmember.
  8. Install the upper radiator mounting screws and torque to 105 inch lbs. (12 Nm).
  9. Reconnect the engine block heater electrical connector, if equipped.
  10. Install the CRS overflow tank mounting screw to the upper radiator crossmember. Torque the screw to 18 inch lbs. (2 Nm).
Fig. 11: Unbolt the lower radiator mounting brackets
Fig. 12: Once all of the components are removed or set aside, the radiator can be removed from the vehicle
  1. Install the air intake resonator.
  2. Refill the cooling system with a 50 / 50 mixture of clean, fresh ethylene glycol antifreeze and water to the proper level.
  3. Reconnect the negative battery cable.
  4. Start the engine and run until it reaches normal operating temperature, then check the coolant level and the automatic transmission fluid level. Add fluids, if necessary.
Hope help with this, remember comment and rated this.
Jul 22, 2010 | 1998 Dodge Caravan
How do you install radiator on chrysler 2002 town and country
Caravan, Grand Voyager, Town and Country, Voyager, 2000-2004
Radiator - Removal & Installation
  2. Place a drain pan under the radiator drain. Open the radiator drain plug and allow the coolant to drain.
  3. Remove the air intake resonator from the air cleaner assembly.
    Fig. Before removing the hood latch, mark its location on the crossmember with a paint marker or other tool
    Fig. Once the hood latch is matchmarked, remove it from the crossmember (without disconnecting the cable) and set it aside
  4. Remove the Coolant Recovery System (CRS) overflow tank filler neck hose.
  5. Disconnect the cooling fan electrical connector located on the left side of the cooling fan module.
  6. Remove the CRS overflow tank mounting screw from the upper radiator crossmember.
  7. Remove the upper radiator-to-crossmember mounting screws.
  8. If equipped, disconnect the engine block heater wiring connector.
  9. Remove the upper radiator crossmember.
    Fig. Remove the grill extension...
    Fig. ...and the upper radiator-to-crossmember bolts, then . . .
    Fig. ...unbolt the crossmember . . .
    Fig. ...and lift it from the front of the vehicle
  10. Remove the entire air cleaner assembly.
  11. Disconnect and plug the automatic transaxle oil cooler lines from the radiator.
  12. Disconnect the upper and lower radiator hoses from the radiator. Remove the lower radiator hose clip from the cooling fan module.
  13. Remove the A/C condenser mounting fasteners and separate the A/C condenser from the radiator. Be sure the condenser is supported in position.
  14. Remove the A/C filter/drier mounting bracket, 2 mounting bolts to the cooling fan module and 2 mounting nuts to the filter/drier. Remove the mounting bracket.
  15. Carefully lift the radiator out of the engine compartment. Be careful not to damage the radiator cooling fins or water tubes during removal.
continue...
Mar 27, 2010 | 2002 Chrysler Town & Country
How to remove a radiator from a ford taurus
Disconnect battery ground cable. Remove battery. Remove battery tray. Remove clip retaining contant control relay module and position module aside. Remove radiator cap. Raise vehicle front end as high as possible. Remove radiator splash shield. Drain radiator. Remove the radiator mounting bracket assembly. Remove lower radiator hose. Partially lower vehicle. Remove upper radiator hose. Remove radiator overflow hose. Remove upper A/C condenser core retaining bolts. Remove upper transmission oil cooler tube clips. Remove lower transmission oil cooler tube. Raise vehicle. Remove lower transmission oil cooler tube clips. Remove lower transmission oil cooler tube. Remove transmission oil cooler bracket and position transmission oil cooler aside. Remove lower A/C condenser core bolts and position A/C condenser core aside(be careful not to loosen the AC condenser lines. Remove radiator support bracket. Remove radiator out through the bottom of the vehicle.
Installation
Position radiator. Position radiator support bracket and tighten nuts. Position A/C condenser core and tighten lower A/C condenser core bolts. Position transmission oil cooler tube and install transmission oil cooler tube bracket. Install lower transmission oil cooler tube. Install lower transmission oil cooler tube clips. Install lower radiator hose. Install radiator mounting bracket assembly. Tighten bolts. Install radiator splash shield. Lower vehicle. Install upper tranmission oil cooler tube. Install upper transmission oil cooler tube clips. Install upper A/C condenser core retaining bolts. Tighten bolts. Install radiator overflow hose and tighten clamps securely. Install upper radiator hose. Position constant control relay module and clip securely. Install battery tray. Install battery. Connect battery ground cable. Fill and bleed cooling system. Start engine and inspect for leaks.
Nov 25, 2009 | 1998 Ford Taurus
How to change a thermastat 1994 ford escort with a 1.9 engine
1.9L Engine
CAUTION Never open, service or drain the radiator or cooling system when hot; serious burns can occur from the steam and hot coolant. Also, when draining engine coolant, keep in mind that cats and dogs are attracted to ethylene glycol antifreeze and could drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantities. Always drain coolant into a sealable container. Coolant should be reused unless it is contaminated or is several years old.
  2. Drain the cooling system.
  3. Remove the air intake tube, crankcase breather and PCV hose.
  4. Remove the ignition coil pack and bracket.
  5. Remove the upper radiator hose.
  6. Remove the ignition coil pack bracket.
  7. Unfasten the heater hose inlet tube bracket bolt and remove the heater hose inlet tube from the thermostat housing.
  8. Remove the three thermostat housing attaching bolts, then remove the thermostat housing and gasket.
Fig: Remove the ignition coil pack
Fig. : Detach the air intake tube, crankcase breather and PCV hose
Fig. : Disconnect the upper radiator hose from the radiator
Fig. : Unfasten the ignition coil pack bracket upper bolts...
Fig. : ...and the lower bracket bolt, then remove the bracket
Fig. : Unfasten the heater hose inlet tube bracket bolt (arrow)
Fig: Unfasten the heater hose inlet tube-to-thermostat housing clamp
Fig.: Disconnect the hose inlet tube from the thermostat housing
Fig. : Unfasten the three thermostat housing bolts
Fig. Separate the thermostat housing from the engine block
Fig. : Remove the thermostat from the housing
Fig. : Use a scraper to clean old gasket material from the engine block's thermostat housing mating surface ...
Fig. : ... as well as the thermostat housing
continue...
Oct 29, 2009 | 1994 Ford Escort
I am trying to find out how to disassemble the radiator support in my 1999 Chevy Suburban and I am having some difficulities.
  1. Drain the cooling system.
  2. Unfasten the upper fan shroud bolts and remove the upper fan shroud.
  3. If equipped, remove the upper panel fasteners and the panel.
  4. If equipped, remove the upper insulators and brackets.
  5. Disconnect the radiator upper and lower hoses and, if applicable, the transmission coolant lines.
  6. Remove the coolant recovery system line, if so equipped.
  7. Remove the oil coolant lines, if equipped.
  8. Remove the lower fan shroud bolts and the lower fan shroud.
  9. Remove radiator from the lower brackets and insulators.
    0900c152802490af.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Exploded view of the radiator mounting
    0900c152802490b0.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Remove the radiator upper panel fasteners
    0900c152802490b1.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Remove the radiator upper panel
    0900c152802490b2.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Disconnect the transmission cooler lines
Sep 02, 2009 | Chevrolet Suburban 1500 Cars & Trucks
Freezer and fridge not cooling (halfway)
SxS Amana upper half of feezer and Refrigerator not working
Jun 22, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Samsung 18.8 Cu. Ft. Bottom-Mount Refrigerator - Black Logo
95 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
