Question about Sony PlayStation 2 Slimline Console
How to fix ps2 Memory card slot 1 - Sony PlayStation 2 Slimline Console
  • 18 Answers
SOURCE: PS2 doesn't acknowledge memory card in memory card slot 1
make sure that theres nothing blocking the mem slot 1.
Posted on Jan 02, 2008
  • 147 Answers
SOURCE: ps2 memory card
The solution is to buy a new PS2. The memory card is fine, but the problem is the slot. Over time, with wear and tear and users roughly shoving the cards in - the data pins on the inside get bent and warped until they can't handle the abuse anymore and give up entirely.
I recommend GameStop to buy quality used PS2 systems. Good luck!
Posted on Feb 23, 2008
  • 4 Answers
SOURCE: PS2 Memory card problem
there is an eternal problem get a NEW ps2
Posted on Aug 31, 2008
  • 7 Answers
SOURCE: Memory Card Corrupted
you cannot save another file until you delete previous one.Corruption occurs if the memory card is removed from console or if you reset the game while saving or loading game remember this also happens when you are saving or loading game and electricity turns off.
Posted on May 30, 2009
  • 115 Answers
SOURCE: my ps2 memory card won't work wheni put it in it
your memory card i think has got corrupt. u will have to format it either from a the game options windows or connect it with a computer n format it and then try it again.
Posted on Nov 01, 2009
I have no manual my problem is I have a First Generaiton Ps3 and would like to transfer my Ps2 memory card and cant figure it out. pleae help thank you Nichole
Prerequisites There is no PS2 memory card slot in the PS3 so will need a Memory Card Adaptor. Sony made an official adapter but there are also a number of cheaper alternatives. Buy one online:
Steps
  1. Plug your PS2 memory card into the adaptor
  2. Plug the adaptor into a free USB port on your PS3
  3. Go to the "Game" menu in the XMB and choose "Memory Card Utility (PS/PS2)"
  4. If the adaptor is working you should see an item called "Memory Card (PS2)". Below the title should be the size of the card and how much is in use-in my case "1334 KB / 7998 KB"
  5. Press the controller's Triange button to get the Memory Card options. Select "Copy"
  6. Select "Yes" to confirm the copy from memory card to the hard drive
  7. Enter a name for the new Internal Memory Card that will be created on the hard drive, or leave the default name. I named mine "Original PS2 saves". Select "OK"
  8. The data will be copied. If the amount of saved data is too large, the system will automatically create multiple internal memory cards
  9. You may be informed that the new internal card has been assigned to a "slot". These slots are an emulation of the physical memory card slots in the PS2, so similarly you may only have two internal/virtual cards "plugged in" (assigned) at a time. The internal memory card must be assigned to slot 1 or 2 to be available when you run PS2 games
  10. The new internal memory card should now be showing in the XMB, under Game > Memory Card Utility
  11. Selecting the card will allow you to browse the game saves that were copied across!
Jan 04, 2011 | Video Game Consoles & Games
Slot one not reading cards properly.
There isn't way to fix this easily. I recommend taking it to Geek Squad and having them look at it. Although it may be cheaper just to purchase a new Ps2.
Jul 17, 2010 | Sony PlayStation 2 (PS2) Console
My memory card slot 1(PS2) does not read cards but slot 2 does?
take out slot one memory card and insert your second memory card into it (they are supposed to use slot 1)
Dec 23, 2009 | Sony PlayStation 2 (PS2) Console
My playstation keeps saying to put in a memory card.. even though I have done
did you try reading the memory card without any game discs put in via the ps2 menu?
is your memory card working properly? could be a corrupted memory card or a faulty memory card slot.
try putting a friend's memory card on that same slot.
if it works... then your memory card is gone bad...
if it doesnt work...then your memory card slot has gone bad.
else try putting your memory card in your friend's ps2, see if that ps2 reads your memory card. if it does...then your memory card slot has gone bad.
Sep 07, 2009 | Sony PlayStation 2 (PS2) Console
My ps2 will not reconize my memory card it says no memory card in slot 1
try blowing into the card and the slot of ur ps2. clean them out
Jun 22, 2009 | Sony PlayStation 2 (PS2) Console
PS2 Memory Card Read Error
Have you tried cleaning the open connections?
Apr 08, 2008 | Sony PlayStation 2 (PS2) Console
Want to play ps1games
I don't have that problem with mine, I have two memory cards 1 for a PS 1 & 1 for a PS2 and it depends on what game I want to play as to which memory card I put in the 1st slot! maybe your system is different but I don't have any trouble saving anything from PS 1 onto a PS 1 memory card.
I don't know if this helped any, but I sure do hope that you get your problem fixed!!
Mar 10, 2008 | Sony PlayStation 2 (PS2) Console
My memory card slot 1 doesn't work can I change the unit so that games will save to slot 2 instead or how do I swap the slots in the unit
When you choose to save when you are in any game, on the save screen you can choose to save to slot 2 provided there is a memory card inserted in slot 2.
Dec 27, 2007 | Sony PlayStation 2 (PS2) Console
Dec 26, 2007 | Sony PlayStation 2 (PS2) Console
Ps2 memory card
Hi Lofatman,
If this problem happens with the memory card when its in either slot 1 or slot 2
I suggest you clean the contacts of the memory card.
If it just happens when you have in Slot 1 or Slot 2 only,
 Go to Radio Shack and get a Can of contact cleaner that has a Brush built into the Spray nozzle.
  1. Turn off the PS2 and disconnect the power cord.
  2. Use a small screwdriver to press open the memory card slot. Do not use too much force, its delicate.
  3. Push the Brush sprayer up into the memorycard slot and spray a little and brush away at the memory slot contacts.
if you do not have success with that, you must open the PS2 case, and Remove the Controler ports and clean up the whole controller port assembly.
If that doesn't work, and your frustrated and not Electronically skilled enough to do this.  I can get the PS2 in tip top shape, for $32 and that includes return shipping.  I run the website www.playstationclinic.com
This should put you in business.
Oct 17, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 Slimline Console Logo
277 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
