Question about TORK Timer 1 Channel Signal Timer Dgs100
I have a tork digital time switch DZS200A that I dont know how to reset the time to. Can you tell me how to do this or send me a link to the manual. Thanks
2 Suggested Answers
SOURCE: Tork model dts200a/dzs200a shows no
Tork DTS200a/DZS200a is 2-channel digital timer with 365 day programming and astronomic capability.
2-channel means that timer can control two different circuits with different program schedule applied to each circuit.
http://waterheatertimer.org/pdf/1TORK.DTS200A.DZS200A.INSTALL_OP.pdf
http://waterheatertimer.org/Tork-Digital-timers-and-manuals.html#DTS
1) Timer has 'snap-in non-rechargeable 9-volt lithium battery'
Replace with ordinary 9 volt battery
Battery location is not apparent from image of product, and I don't own this particular timer line.
Add a comment and say where battery is located.
2) Programming is stored indefinitely in memory chip even if battery goes dead.
Current time might have to be reset shown in manual page 3.
Memory can be cleared using procedure outlined in manual starting page 13.
3) If timer function is not restored, then timer might have gone bad.
Contact NSI:
http://www.nsiindustries.com/contact-us.aspx
Many timers and other electronics are not protected from power surge.
Lightning strikes, electrical storms, and simple power outage can knock out electronic timers, and water heaters, water softener, treadmill, etc.
1-event Surge protectors can be installed in main panel to help protect circuits and electronics.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Aug 30, 2011
How to set a tork timer
1) Copy following link to identify timer, and download possible manual:
http://waterheatertimer.org/Tork-timers-and-manuals.html
2) Tork TU universal
http://waterheatertimer.org/How-to-set-timers.html
3) Usually the dial will rotate manually until current time lines up with Time arrow located next to override lever, or time arrow located on inner dial, depending on model number.
4) Tork DTU digital timer:
http://waterheatertimer.org/How-to-wire-Tork-DTU40-timer.html
5) After opening links to identify timer, add comment and describe where you are, and what you discover.
Feb 20, 2013 | Intermatic T101 - 24 Hr. Dial Time Switch...
How do i program a tork dtu40 timer
1) Copy following link for programming manual and wiring Tork DTU40 40amp timer.
2) The timer mechanism is old Intermatic/Grasslin/GE discontinued model, and then newly re-minted by Tork in 2012. Timer has 1 year limited warranty against defects in workmanship. This timer is protected from surge by the reset feature, but can burn out in heavy surge event. Non-replaceable Internal rechargeable battery retains programming until timer is reset. Always reset new timer to delete trace memories.
3) This timer can be wired many different ways, and timer automatically detects voltage, so there are no dip switches to set. Timer must be wired before power is turned on. Do not spark-test across terminals.
Feb 17, 2013 | TORK Hardware & Accessories
Tork pool timer
Analog timer: Buy new trippers
Digital timer: reset timer and reprogram and avoid conflicts in programming
Copy following link to help identify timer:
May 28, 2012 | TORK Hardware & Accessories
Tork model dts200a/dzs200a shows no display and has stopped working. any Suggesqtions?
Contact NSI:
Aug 30, 2011 | TORK Hardware & Accessories
How do you program a Tork 602A timer? I can't get mine to cycle on and off at a desired time.
The Tork 602A mechanical outdoor timer with 2 grounded outlets.
Tork 601A and 602A manual
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Manual has images of timer that will help.
Plug timer into outdoor outlet.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial is divided into light and dark sections that represent day or nighttime hours.
Reset time after power outage.
96 pins located around timer dial are used to set on-off times.
Each pin represents 15 minutes in 24 hour day
Move pins in-or-out with fingernail or ink pen to set timer on-off functions.
With Tork timers, usually when pins are out, timer is ON.
When pins are in, timer is OFF.
To double-check pin setting, manually rotate timer to watch when lights turn on-off.
Set multiple ON/OFFs each day.
Change on-off times by resetting a pin or two.
Timer repeats every 24-hours.
Manual ON/TIMER switch is located on inner dial.
Set Manual switch to TIMER for programs to operate.
To override time and turn on Load, move override to ON position.
Dec 09, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
I didn't get any instructions with my timer. It is a tork 601A I don't know how to set it. I think it looks great and just what I'm looking for. The case was sealed but no instructions. Thanks J Seel
Tork 601A outdoor timer manual:
Timer has 1 125Volt receptacle located on bottom of timer
96 captive tabs located around timer dial allow times to be set each 15 minutes.
Move pins in-or-out with fingernail or pen to set timer on-off functions.
Minimum time setting is 15 minutes.
Maximum time setting 23 ¾ hours.
Dial is divided into daylight and nighttime hours.
Nighttime PM hours are on dark background.
Daylight hours are on light background.
To set timer, rotate dial clockwise until current time lines up with arrowhead located on inner dial. Reset time after power outage.
Manual ON/TIMER switch located on inner dial.
To override time and turn on Load, move override to ON position. To use timer functions, move override to TIMER position
Dec 02, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
I just took over an old building with three Tork Digital Timer Switched EW 120A-C. I have no idea how to reprogram these to get them to do what I want. If the overhead lights are on, no outlets work and...
Here's a link to the Tork website. The model timer you have is a past model. The manuals are listed in the technical library.
The model you have is most likely either EW101A SERIES or EW101SA SERIES
See the library for details: http://tork.com/techlib.aspx
Jul 19, 2010 | TORK Digital Interval Timer Ssa100r-24
Timer keeps time, but sticks at tripper points
1) Clock motor needs replacement:
Link below shows timer and wiring manuals.
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
2) 120Volt Clock motor sells for $43 at Frontier lighting
http://www.frontierlighting.com/product.jsp?part=10431&process=search&show=&ID=,Photo.Cells...Time.Controls,Replacement.Motors
3) New Tork 1103 sells for $55. Just swap out insides without changing box.
4) Intermatic crossover for Tork 1103 shows Intermatic T103 timer.
Amazon sells T103 for $50
http://www.amazon.com/Intermatic-T103-120-Volt-Mechanical-Switch/dp/B000LDIDBY
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Oct 01, 2009 | TORK Digital Interval Timer Ssa100r-24
I'm trying to find a users manual to reset my timer.Our recent manual has been misplaced thru the years.I did the reset,but still no lights on at syncronized time...anybody?help?
Open following link to identify Tork timer
Add a comment and include photo of your timer and wiring.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Apr 14, 2009 | TORK Variable Cycling Timer 8601
TORK Timer 1 Channel Signal Timer Dgs100 Logo
675 people viewed this question
Top TORK Hardware & Accessories Experts
 Kenneth
Kenneth
rgbypoet
Andrew Taylor
Andrew Taylor
Are you a TORK Hardware and Accessory Expert? Answer questions, earn points and help others
