Question about Hitachi UltraVision DZGX5020A DVD Camcorder
Screen reads cannot read disc check dirt/crack/both-sides contrary/inserted correctly
  • 76 Answers
Ultimately it sounds like the dvd drive needs to be replaced. The laser is weak and cannot read the data that is being sent back to the processor, that is if the laser is firing at all. I hope this helps
Posted on Sep 16, 2010
The discs could not be read and they have no scratches and look fine then
The Wii console will not play game discs (disc is not recognized)
System displays either error message "Unable to read disc" or "Disc could not be read"
Note
Wii Game Discs are region locked, and can only be played on hardware from the same country where the game was released. (A European game cannot be played on a North American system, for example.)
What To Do:
The Wii console is only compatible with Wii and GameCube discs. It is not compatible with DVDs or discs made for other home consoles. Verify that the disc you are inserting is compatible with the Wii system.
An error message may display if the disc is ejected during play. Return to the HOME Menu before changing discs.
Verify that the console is placed correctly.
If the Wii console is lying flat, the game disc slot should be above all three buttons and the SD Card slot.
If the Wii console is standing vertically, the power button should be on the top and the console should be in the stand. Note: Only Wii consoles with model number RVL-001 are intended to be placed vertically. (Learn more)
Verify that the disc is being inserted properly.
If the console is placed horizontally, the disc label will face upwards.
If the console is placed vertically, the disc label will face to the right.
Check the non-printed side of the game disc for dirt or severe damage (such as scratches or cracks).
If the disc is dirty, try cleaning the game disc. (How to)
If the disc is damaged or scratched, it will need to be replaced. Please click here for replacement options.
If the problem occurs with only one game disc, there may be a problem specific to that game. Click here to check our list of specific game issues.
Make sure only licensed accessories are being used. Unlicensed products do not undergo Nintendo's testing and evaluation process. They may not work at all with our game systems, and they may have compatibility problems with certain games or accessories.
Nov 17, 2012 | Nintendo Wii Console
Hitachi BX37E error
You can try to clean the laser lens first with a q-tip and 99% alcohol. If that fails, you should take it in for repair because the laser lens mechanism may be out of line because of a bump. There may also be a dust build up inside that prevents the proper movement of the lens. This can be done at home too.
Oct 15, 2007 | Hitachi DZ-BX37E DVD Camcorder
Dear Expert, Warm Greetings ! I have a Hitachi DVD CAM - GX3300E, on switching it on with a disk inside, I get a msg "DISC ACCES". Even on using a new RW DVD Disk i get the following...
Sounds like your lazer is weak,if you have warranty send it back for repair,if not make sure you get a quote before fixing it might be expensive.Good luck!!
Jan 08, 2011 | Computers & Internet
WON'T PLAY CD'S READS "NO DISC"
  • Check the disc you're using for scratches and dirt. If the disc is damaged it won't play properly, regardless of the CD player's ability to function. You can use a CD repair device like the "Disc Doctor" to repair the CD or purchase a new CD.
  • Clean the laser lens with a CD laser lens cleaning disc. CD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
  • Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
  • Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
  • Dec 11, 2010 | Sony CMT-EP505 CD Shelf System
    Hardly used it & now it doesnt recognize any dvd any clue what could be wrong
    Laser eye reading buble,might be dirty,reqiure cleaning or having problems with those DVDs disc's itself like dirts,grimes or cracks and big scratches on those DVDs disc's laser shinning surfacing data's reading side?Check all ur DVDs disc's again u are using,might just require a good cleaning on DVD's discs on the reading data's shinning surface sides,with some dish washing soap?If the DVDs disc's are not the problems.Tries websites like Ebay.com,Amazon.com to buy a DVD disc cleaning kit.By using the DVD cleaning disc,might work,might not.But than u don't have to be littery taking the portable DVD player aparts and used some Q tips,dipping in with some rubbing alchahol to clean the Laser eye reading buble itself.
    Dec 01, 2010 | TruTech PVS12701 Portable DVD Player
    Xbox 360 says reading then open tray, close tray
    check the unit with a different disc, also better do a optical disc cleaning on yur unit. sometime lens get dirt and hard to read the disc inserted.
    hope this helps
    Jul 09, 2009 | Microsoft Xbox 360 Console
    It doesnt work
    The disc type is not correct, cd or dvd or blu ray or cdrw. The new disc in not empty for burning or its not empty.
    Worst, the laser head is busted, it can't read disc inserted so it ejects thinking it is reading the other side but not.
    please vote. thanks.
    Oct 27, 2017 | Hitachi DZ-MV230A DVD Camcorder
    Hitatchi bx35a... after recording no data
    Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
    Download from the following link ------
    http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
    Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
    For any other help contact me.
    Thanks
    Dec 03, 2008 | Hitachi DZ-GX3200A DVD Camcorder
    HITACHI DVD CAM BX35A
    You I bought also this piece of junk full of craft. The dvd disk can be read in my my but not in my pc. It cant be hook also in the PC. Dont buy it you will regret.
    Aug 09, 2008 | Hitachi DZBX35A DVD Camcorder
    Error for record
    I got mine to go with a good lens cleaner, just like the one for your DVD, but for your camcorder.
    Nov 19, 2007 | Hitachi DZ-MV730A DVD Camcorder
    Hitachi UltraVision DZGX5020A DVD Camcorder Logo
    546 people viewed this question
    Top Hitachi Video Cameras Experts
    Mohamed Ismail
    Mohamed Ismail
    Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
