Question about Whirlpool LXR6432JQ Top Load Washer
I have a 15 yr old Whirlpool washer that has run great. During a cycle, it stopped full of water. I moved the dial around to different areas pushing it in and out and got a cyle to run long enough to pump out most of the water. Does the main dial switch need replacing?
    Problem Solver:
  • 10 Answers
Not always a Timer issue. could be stopping at the cold fill part of the cycle which is the 8 o clock position on the dial. This would be fault with the cold fill vavle.
Posted on Sep 15, 2010
Whirlpool washer model wfw9050xw00 This unit is 1 yr old and is stopping at various times during all of the cycles. Also the unit is buzzing a bit when it is using the pump for drainage. Some times we...
Only 1 yr old so I assume its a simple fault like partial blockage at pump. Remove filter bottom right of machine check and clean if needed . remember to use an old towel fist as this will contain around half pint of water assuming its drained 1stly , Always unplug machine from Electrics before any repairs, Good luck.
Jan 08, 2018 | Whirlpool duet Washing Machines
6 yr old side by side inglis fridge/freezer. water
can be from an obstruction (i.e. food or debris) or incomplete defrost. water forms around the drain during defrost cycle and ices up when cooling cycle comes on. defrost the drain and try installing a heat probe part#819043 made by whirlpool.its a metal rod that wraps around the heater and goes into the drain opening to prevent the drain from icing up. hope this helps.
Oct 21, 2009 | Kenmore Refrigerators
Water won't dump
When you replace the pump, always to remember to makes sure the pump is pushed all the way in so that the shaft has a good grip. Try taking it out and pushing it all the way in. The 4 legs should touch the motor, as you put the 2 little clamps on the top and bottom.
Good luck, I'm pretty sure it's something really basic with the pump :)
Jul 19, 2009 | Whirlpool LTE6234D Top Load Stacked...
Washer stopping mid-cycle
Push down on lid. You may have a bad lid switch. Start machine and press the switch down with something like a screwdriver and see if the motor runs.
Jul 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine won't complete cycle
If it is a hot and cold fill washer, yes, then it could be a hot water problem related to the valve, or the water supply., if it is cold fill only, then the problem is elsewhere.
Pleas rate my solutikon.
Thanks.
May 13, 2009 | Whirlpool AWM5125/1 Front Load Washer
Washer stopped after wash cycle
The lid switch is the culprit. Push down on the lid it should start. It needs to be adjusted . the tab on the lid is not activating the switch. Try triming the door bumpers.
Apr 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer shuts off during cycle
Replace the timer - it is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 13, 2009 | Washing Machines
Washing machine water want stop running.
Sounds like your stop valve has a leak.
You dont need a control unit, just the proportioning valve.
Dec 28, 2008 | Washing Machines
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Whirlpool LXR6432JQ Top Load Washer Logo
106 people viewed this question
Dan Webster
Dan Webster
Sal De
