Question about Behringer EUROPOWER EP2500 Amplifier
How can i do this
Ok how do i run a cd mix 3 to a crx 3400 cross over to a ep2500 to my speakers
  • 790 Answers
Hi
the crossover has 6 output and 2 inputs in stereo type! you need amplifier to this...
Thanks!
Posted on Sep 22, 2008
What number on each channel on behringer ep2500 to set for behringer vp1220 speakers
It is best to start with the mark on the ep2500 directly up (12 o'clock position). Gradually increase the output on your mixing board (MAIN MIX) to get desired volume. I you find that you're getting close to -10 to 0 dB, then start increasing the volume knobs on the ep2500. Watch for clipping on the amp.
Oct 11, 2012 | Behringer Ep2500
I have EP2500 amp i want to use it to push 6 tops, what should i switch it to? one channel must push 3 tops and the other as well pushing 3 tops.
OK, you can use ep2500 amp to power 3 tops each,But the only challenge is that you are about to over load your amplifier. might get hot too fast .
You can use a cooling system to make it not too hot..It also depends on how the event your using it for...Using 3 EP2500 amplifier to drive three 6 top, using two top for each amplifier. Just a suggestion.
Using 2 amplifier, you will need to drive on one channel to drive 2 tops, and 1 top for the other channel.
That will do. But make sure you turn on the volume of the amplifier to the max volume ,so that it will be able to work properly for your tops...
Mar 31, 2011 | Behringer EUROPOWER EP2500 Amplifier
I bought a mixer with this model "Behringer XENYX 1204USB 12 Ch USB Mixer". And i'm planning to have a set-up of 2 electric-acoustic guitars and 3 microphone vocals. What would be the best wattage of...
Hello Sir, Hi, the amplifier best suited for it would be a Behringer also, the EP2500 would be a match, and the eurolive B815neo speakers, but this cost a lot, any amplifier and a corresponding speaker will do. for your electric guitars or acoustics the GTX30. If you will use your 15" speakers, match it with a right amplifier, you did not mention its watts rating, If your speakers are 250 watts, then buy an amplifier slightly higher that 250 watt,
Aug 19, 2010 | Behringer EUROPOWER EP2500 Amplifier
The amp turns on but has no sound coming through the speakers
There should be several channel choices and speaker connections, make sure they both match.
If you are not sure, put the amp on main or 1 and try all the connections until you find the ones that sound is being routed to.
Also overload protection is pretty sensitive, if you have touched wires together or mixed up + and - you may have tripped it, and may need to reset.
Jun 14, 2010 | Behringer EUROPOWER EP2500 Amplifier
Two 4-OHM DVC AND two 4-ohm
your amp is stable at 2ohm in stereo mode . you can wire them in series or parallel. series you add up the ohms . parallel you use this (R1+R2)divided by(R1xR2)=total resistance this figures two speakers at a time to add more speakers after total repeat formula as long as you don't go below min load you are fine . in your case all speakers in parallel you would be running 0 ohms bad . in series you would be running 16 ohms stable but not even half the power of your amp. if you hook up two in parallel and two in series on one channel you are running 1.6 ohms still not stable.If i was u I would hook up two 4ohm speakers in parallel on one channel and two in parallel on the other given you a stable 2ohm per channel.
total power output per channel 1200w
Jun 20, 2009 | Behringer EUROPOWER EP2500 Amplifier
I have a xenyx 2442fx mixer and ep2500 power amp hooked up to 2 1800x subwoofers and 2 1520 pro speakers. i am using a peavey xr 684f powered mixer to power my monitors. i would like to add another power...
You would need a 2 or 3 way crossover, depending on whether or not you biamp your tops. Simply go out of your main outs on the mixer into the input of the crossover. Go from the low output of your crossover to your low power amp input (subs), and the high output of the crossover to the high power amp input (tops). Then go from your outputs of your amps into the speakers themselves.
Jan 04, 2009 | Behringer B1520 Pro Eurolive 15" 2-Way...
Both Positive and Negative Speaker Wires Mixed With Truck On
WHEN U CROSSED THE WIRES U POPED A WIRE LEAD LOSE, CHECK ALL YOUR CONNECTIONS.
GOOD LUCK
Dec 12, 2008 | Infinity 475A Car Audio Amplifier
How would i conect a ep2500 amp two 2 subs @ 4 ohms, or 8ohms
hey" i got 2 behringer 2500 amps and i have 2 peavey speaker that are 4 ohms 2000 watts eachand want to mono the amp separte,and i want to run 1 amp to each speaker so can you help me?
Nov 26, 2008 | Behringer EUROPOWER EP2500 Amplifier
I have a problem with an Acer travelmate 530 no sound output anyone got any ideas
1. check the obvious first:(check... don't assume)
a.everything is plugged in .. if possible test the speaker to make sure they're working
b. is your volume all they way up (or at least not all the way down).
c. click once on the speaker icon on your system tray (where the clock is) make sure you're don't have the sound muted or the volume is all the way down.
d. now double click on the speaker again and check the mixer volume control.. check items like master volume, wave, audio cd and others are not muted or with the volume all they way down.
2. if after doing step 1 everything check out ok you you may have a possible driver problem: note: if you see the speaker icon with a red cross (red cross means there's no driver for your sound controller) you need to check device manager for a possible driver problem, do check even if there's no red cross on the speaker icon as it may be a possible outdate driver (for device manager go to start>run> type devmgmt.msc then enter) and check if you have any ! or ? under sound devices. if you do unstill and reinstall drivers or better yet, download updated drivers from sound card manufacturer.
3. if you got upto step 3.. you may have a faulty sound card, get another sound card and test if it works. (this is unlikely but possible)
Oct 03, 2008 | Acer Computers & Internet
Behringer EUROPOWER EP2500 Amplifier Logo
87 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
