Question about Dishwashers
GE quiet power 3 dishwasher manual - Dishwashers
  • 1073 Answers
SOURCE: Plugging the GE quiet power 3 dishwasher return line
remove the drain line and plug off the port on the sink that the dishwasher connected to, to plugit off black electrial tape wrapped arround the hole till it seals off will work
Posted on Apr 12, 2008
SOURCE: ge quiet power 3 dishwasher
According to the GE repairman who visited, the solution is to close the machine (with the lights flashing). The machine starts and goes through the cycles, which it does rapidly and then all the lights turn off and the machine becomes silent after 1-1/2 to 2 minutes. Then the machine has been reset to normal. During this reseting period nothing happens inside the machine, although you may hear a running sound.
Thus, the solution is to run the machine in this flashing light state for the 1-2 minutes it takes to go raipdly through each cycle and then reset.
I hope this helps.
Posted on Jan 03, 2009
PaulyV777
SOURCE: ge quiet power 3 troubleshooting
I have a GE Quietpower 3 dishwasher and let me tell you it is the worst dishwasher, hands down that I have ever owned. It is not quiet and it certainly does not have any power to clean anything. Or so i thought. After reading a few of the posts on this site it dawned on me to check the drainage. I took the whole drain assembly apart. Cleaned all of the gunk out of it. Then went for the drain hose. It was just about a clean as it was brand new. Then i reexamined the drain and found that it did not drain into the Garbage disposal like I am use too. Instead it had to make an immediate 30" climb into a PVC drain that sat just below the underside of the countertop. I rerouted the hose to dump into a bucket and ran the dishwasher. Guess what??? All clean and no residue. I am off to Lowes now to get the clamps and such to drain the dishwasher into the disposal. I still think this dishwasher is the worst I have ever owned and think GE should give that Six Sigma save a few pennies on one DW and the company can save hundred of thousands, at the expense of a customer spending hours on fix-it sites to find out the company cheapened the pump, a rest! However, for all of you that just want to fix your dishwasher, try draining it into the Disposal now before you blow your pump out.
Posted on Dec 16, 2009
tbirdfan1
  • 3051 Answers
SOURCE: My dishwasher GE profile quiet power II MV832134B
Hello there again
I think we got disconnected in the chat room so i will post the solutions here for you to check ok
The water doesn't drain from the machine If the water doesn't drain from your dishwasher, check these: Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water. Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing. Belt If the motor isn't turning or working, the unit won't drain. at all." If the motor hums but doesn't turn, it may need to be replaced.
Posted on Jun 27, 2010
SOURCE: my ge quiet power 3 dishwasher will not start, the
I have the same problem. If I turn the circuit breaker off (for 30 seconds) then turn it back on, the lights will light up, but the controls don't work. After several minutes, the lights go out again.
Posted on Jul 19, 2010
My GE quiet power 2 dishwasher isn't cleaning
its your water actually. go to www.dishwasherfilter.com and get the dishwasher filtration system. it filters the hard minerals that leave spots and film on dishes before they enter your dishwasher. you will love this product.
Apr 25, 2013 | Dishwashers
Hello ... We have a GE Quiet Power 3 Dishwasher -- only two years old. Dishwasher won't start ...and we are getting an 1h code. What is a 1h code? The manual does not provide any code...
Try unplugging the unit for several minutes if that does not fix the issue you will need to replace the main control board to fix the issue, let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Dishwashers
I have a ge profile quiet power 3 model # gsd4330z00ww, theres power to the dishwasher but its acting like theres not, no lights or buttons work.
The control board may have failed. There is no way to know the exact problem without troubleshooting with a multimeter
Sep 02, 2009 | GE Dishwashers
Soap dispenser does not open during cycle
Had similar problem. Water was not hot enough. Check your manual for proper water temp.
May 29, 2009 | GE Dishwashers
GE Quiet Power II Dishwasher
My GE dishwasher will only flash the start button and when I try to change a cycle it flashes the regular cycle and beeps every ten seconds without starting. I have had success once turning off the breaker and it resets.
May 11, 2008 | Dishwashers
Dishwashers Logo
1,583 people viewed this question
Top Dishwashers Experts
