Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
When I hit the button to close the door, the unit hums for a little while then quits. Is there something I can do?
    President:
  • 3,197 Answers
Check to see if the trolley is jammed against the bolt just in front of the motor unit. If it is you can either remove the bolt or loosen the chain just a bit to relieve the strain on the chain and then run the opener until the door closes. While the door is closed locate the 'up limit' control on the side of the motor unit and turn it 2 complete turns in the opposite direction of the arrow printed on the cover. Replace the bolt or tighten the chain.
Posted on Sep 15, 2010
Auto garage door opens will not close not the sensors
Look at the back of the motor unit and see if that little light is flashing a code. Post the code.
Aug 13, 2012 | Sears Craftsman LiftMaster Chamberlain...
My 1/3 hp craftsmen door opener just hums when you hit the wall button or remotes in the car. I replaced the starter motor capacitor and nothing changed any ideas?
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain until the tension is removed from the trolley. Run the motor until the door is closed. While the door is closed locate the 'up limit' adjustment on the side of the motor unit and turn this 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Dec 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remote will open door when remote is hit to close door the light flashes and will not close. The wall unit will close door but the button must be held and released when the door hits the floor.
Make sure there is nothing tripping the IR beam at the bottom of the door. The beam is bounced back and forth between its source and a mirror about six inches off the ground. If something breaks the beam the door will go back up as a safety precaution. Also check to make sure there is nothing directly under the door that stops the doors from completely closing. Even a small rock can send the door back up.
Good luck
Dec 09, 2010 | liftmaster Chamberlain Garage Door Opener...
Garage Door opened but will not close. I opened
I think the trolley has jammed against the bolt just in front of the motor unit. Remove the bolt and then run the door until it is closed. With the door closed locate the 'up limit' control on the side of the motor unit. Turn this 2 turns in the opposite direction of the arrow printed on the cover. Replace the bolt.
Sep 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garbage disposal quit working. Just hums, won't actually turn. Nothing stuck in it. Was working fine and just quit. Do you have to turn something before you hit the reset button?
There could be something stuck you can't see.
Most disposals come with a tool you can use to rotate the shaft from the bottom of the unit, sometimes an allen wrench will substitute, then hit the reset button on the disposal.
hope this helps
Jun 05, 2009 | Home
When start button is pushed, hums but does not run. Drum does not turn. Belt is okay
It sounds like it is the motor or a stuck/obstructed blower wheel. You can start by opening the door, push the door switch in, hit the start button & see if you can turn the drum clockwise by hand. This might get it going. if the drum does not move by hand then the problem is probably within the blower. post your findings for a follow up
May 01, 2009 | Dryers
RV Rooftop AC Unit
Sounds to me like your fan is hitting something
Remove the cover and turn the fan by hand ( with the power off ! ) See what it is hitting
Oct 24, 2008 | Dometic Rooftop RV Air Conditioner
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
98 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
