Question about JVC KD-G200 CD Player
How to hook up an amp to a car - JVC KD-G200 CD Player
  • 625 Answers
Remote turn on wire( blue/white) from stereo to amp. RCAs from stereo ( sub out) to amp. Power wire (fused) from battery to amp. Ground wire from clean, paint free chassis to amp. Speaker wire from amp to speaker. ( simplied version). Do you have an amp kit? All the wires, connectors and the fuse will be included in the amp kit.They are rated for the amps power output; 0,4,8 gauge.
Posted on Sep 16, 2010
Tip
Car audio hook ups
when installing a car audio sytem it is always wise to leave the power wire the last thing you hook up.ive seen many brand new amps fry because of people hooking power up to fast,if it sparks your in trouble, amps power wires should always be connect to the amp it self before connecting to the power supply. saves on amps:] And your ground should always be less then 3 feet on an amp the shorter the better!
on Jan 02, 2010 | Car Audio & Video
How do i hook up the mrp-m1000 to 2 type r subs since it is a one channel amp? the subs r 4 ohms so it should work right?
hook the positive to positive and negative to negative on both subs then run wire to the amp the amp will see a 2ohm load
Jan 07, 2010 | Alpine MRP-M1000 Car Audio Amplifier
Amp goes dirctly into protect
ok well it could be two thing wrong your amp dont have a good ground or your amp is a smar amp and your subs must have to be hooked up so the power from the amp cn go to the subs so the amp can see that you do have subs hooked up to take it out of protect o and look at your fuses to to smal or to big will send it to protect to
May 19, 2009 | Kenwood KAC-9102D Car Audio Amplifier
No power to amp
you need to hook up the rem wire, that runs from head unit to amp its usaully a blue wire on the head unit and there should be a rem input near where the power leads are on the amp
Mar 21, 2009 | Kicker ZX400.1 Car Audio Amplifier
Thunder 5604
okay u will have to troubleshoo the amp.....dose the amp light up?...when u have the radio on? also check your sub wires.going to the amp....make sure the rca'sare hooked up to the radio rear out puts are the radio sub out puts...and then test your amp gain adjustment...let me know if that work's
Jun 23, 2008 | MTX Thunder5601 300W x 1 Car Amp Mono...
Jl audio 500/1 amp
You may have the amp set to turn on via an audio signal. Set the Signal Sensing switch to OFF.
Jun 13, 2008 | Jl Audio 500/1 Car Audio Amplifier
Factory stero to amp
If the amplifier has inputs for a high level signal, you unhook the wires going into the speaker and plug them into the amp, then hook the outputs up to the speakers. If the amp only has rca inputs, you need to also buy a line level converter. Then you unhook the speakers, hook the wires up the the converter, then hook the converter up to the amp, then hook the amp up to the speakers.
Please leave good feedback!
Dec 08, 2007 | Blaupunkt PCA250 Car Audio Amplifier
JVC KD-G200 CD Player Logo
265 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
