Question about Kenmore 22422 Top Load Washer
It agitates and the dial goes through normal cycles, then stops when it comes to drain.
  • tzgeis Sep 16, 2010
    They sent instructions and diagnosis for a top load.
    My question is about a front load washer.
    Model #41744102301
    serial # xXC64204537
    President:
  • 1,554 Answers
This is a clear evidence of a broken lid switch. Power to the drive motor is routed through the lid switch during the drain/spin cycle. The machine, therefore, cannot drain and spin when the lid switch is not working. The drain pump doesn't work because it is directly coupled to the rear spline of the motor. Replace the lid switch to address the problem.
Release the console from the top of the cabinet depending on the model of your machine then pull forward and up on the console and lay it back on the hinges.
Disconnect the lid switch harness connector by pressing on the tab It agitates and the dial - 9698f29.jpgthe middle and pulling it up.
The cabinet is attached to the rear of the washer by two brass-colored retaining clips. Insert a flat blade screwdriver into the turned-up edge of the clip, located on both sides, anIt agitates and the dial - 4e2277c.jpgback to release the clip from the slot in the cabinet.
Open and hold the lid while grabbing the cabinet front opening then tilt the top of the cabinet toward you by pulling the cabinet away from the base. This releasesIt agitates and the dial - 8557e5b.jpgand back slots of the cabinet from the tabs in the front and back of the base.
Using the side of your leg and/or body as a support for the front of the cabinet, carefully liIt agitates and the dial - 9652994.jpgn>the cabinet and lay the front on a cushioned floor to access the lid switch.
Remove the lid switch ground and mounting screws then releasIt agitates and the dial - b27a7aa.jpgharness from the metal retainers. Pull the lid switch connector out and install the new lid switch in reverse order of the removal steps.
Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine.
Reconnect the lid switch harness then push the retaining clips back down into position to secure the cabinet to the rear of the machine. Reinstall and secure the console to complete the repair.
Posted on Sep 15, 2010
  • Jahn27
    Jahn27 Sep 15, 2010
    You don't have to accept or reject and rate this post to add information or post comments and follow-up questions should you need further assistance. But accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
  • Jahn27
    Jahn27 Sep 16, 2010
    The problem was posted under the a category of Kenmore top load washer and the model number of the machine was not specified. Also the problem is described as if the machine is a top loader. We troubleshoot and give advice by model number and based on how the problem is described and on experience. That is the sole reason why a troubleshooting and repair guide for a top load machine, instead of a front loader, is provided, my apologies for that.
    Thanks for the information provided yet no further description for the problem so let met troubleshoot again based on what is described here. The agitates and the dial goes through normal cycles, then stops when it comes to drain, the problem says. My understanding of the problem now is that, the timer stops and eventually the machine
    when it comes to drain. This is a clear manifestation of a faulty timer. A dead spot at the point where the drain functions start must be causing the timer to stop. Fiddle with the timer knob or the dial as you call it when the timer stops. Fiddling with it may clean off the dirt that is causing the dead spot. Replace the timer (part number 131802100) if the problem persists.
    You have to remove the top panel and the console to access and replace the timer. The top panel is secured to the rear of the machine. Release the panel then lift off the cabinet. Pull the timer knob off and remove the console from the cabinet.
Roper washing machine does not fill for rinse cycle. Goes directly to rinse agitate without water.
Without Model number I am only guessing but I suspect you have a blocked sensing tube that travels from the Level selector switch to the side of the tub somewhere. It is possible for this plastic tube to become partially clogged and not allow trapped air to vent when tub is drained of water. Usually this problem manifests itself as an overflow of the tub. Check the full length of this clear hose and see if the end nearest the tub looks like it may have debris or dirty detergent clogging it.
This hose is pushed onto a nipple mounted to a reservoir on the side of the tub. Push a thin copper wire 4-5 inches into the those after removing from nipple and also down into the nipple an inch or two before reinstalling the hose to the nipple. You MIGHT even blow into the hose while you have it off and you SHOULD hear a clicking sound coming from the level selector switch body.
Good Luck. Come back with Model number under lid if that doesn't help.
Nov 28, 2015 | Roper Washing Machines
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
Whirlpool washer model lsr8233eqo
So when the cycle first starts, it will fill and agitate and spin. But then on the rinse cycle it stops?
Feb 03, 2013 | Whirlpool Washing Machines
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Goes thru agitate cycle then stops - no drain of water, no spin. Control dial does not advance but manual advance also not result in drain or spin. Position of dial on agitate area results in agitation.
If the drain pump is not operating correctly, the cycle will not continue. Also, sometimes the pump has something jammed in it, and may just need to be unclogged.
Sep 14, 2009 | Kenmore Washing Machines
Kenmore washer quit working
it may be waiting for a faulty heater to kick in. try it on a cold water wash, no heat and see if it continues the full wash. if it does not then it may have a faulty timer.
Mar 16, 2009 | Washing Machines
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Does not agitate or spin - fills and drains - checked belt & pulleys seems fine
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
The washer is equipped with a lid switch failure detector. If the lid switch
should malfunction, the detector will stop operations for your safety.
Read below
First,turn the control dial to proper cycle and pull dial out to start the washer. If
equipped with buttons, be sure they are fully depressed.
Close lid and pull dial out to start the washer. For your safety, washer will
not agitate or spin unless the lid is closed.
should malfunction, the detector will stop operations for your safety. Call for
service.
Pauses are normal. Wait and see if the washer will start again.
Please remember to leave a rating before you go!
Thank you
Sep 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore 22422 Top Load Washer Logo
115 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
