Question about Frigidaire Cooktops
My frigidaire gas cooktop is having problems. Only one burners igniter is working, but all four burners produce gas when the knobs are turned. Also no matter which knob is turned the front left and only the front left burner's igniter sparks. Any ideas?
    Genius:
  • 1,417 Answers
Yes.
What this indicate is that there has been a bring up/meant wire from the wire connection from the main power supply (from the wall) connected to the burner. there are two of solving this problem bellow
put off the power supply from the wall or were ever the power supply is from to put of the the element then two unplug the wire from the wall the unscrew the range the trace the wire down to element (heat provider) from the back properly then test the round the wires and replace the weak wire among them.
You can get a wire replacement from any technician store around your local area but if you are unable to get if your self then you will have to invite a technician to visit your range in order to avoid more damage on it.
Thank you and thanks for using fixya..
Posted on Sep 15, 2010
Cooktop burner do not ihnite
Hi hgodoy2 - Is the electronic igniter aligned properly? Ensure that tip of spark igniter is aligned with metal point or "nib" located on underside of burner cap after the burner mounting screws have been tightened. (Not all burners having mounting screws). When the burner control knob is set to the "LITE" position do the igniters spark? Can gas be heard or smelled coming from the burners when the control number is turned on? However, if you smell gas, I highly recommend turning the unit and the gas off if you can reach it and contact your gas provider. The range itself does not have a switch or regulator to relight it. Keep in mind that it may be experiencing an issue with the spark module, electrodes, wiring or EOC.
Nov 24, 2012 | Frigidaire 36 in.GLGC36S9E Gas Cooktop
When one burner knob is turned to ignite all four burners turn on.
What do you mean by "all four burners turn on"
Some electronic ignite systems turn on on all the burners, But just the SPARK not the gas part of the burner.
Is this what you are describing?.
Jan 11, 2011 | Jenn-Air JGD8130 Gas Cooktop
10-12 year old dacor 4 burner epicure cooktop --left front burner
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 29, 2010 | Dacor Epicure ESG366 Gas Cooktop
A spark that causes a snapping noise when a burner is turned on.
heatman101
May 26, 2010 | Viking 31 in. VGSU101 Gas Cooktop
R rear burner not sparking
heatman101
May 02, 2010 | Dacor Preference SGM365SS Gas Cooktop
GE XL44 range - electric igniter for top burners not working.
Sounds like igniter problem. Did some one pull the electrical cord or has a fuse or breaker blown/ Things to check. Your igniter is run by electricity.
Dec 30, 2017 | GE Profile JGP636 Gas Cooktop
Whirlpool Cooktop igniters keep firing, even after igniting
when you cleaned the unit you may have gotten water in side the igniter, dry it out w/ a hair dryer. Once dry should work .
Mar 29, 2009 | Dacor Preference SGM365SS Gas Cooktop
Constant sparking
I don't have a Thermador cooktop but here is ma taught.
Could you unplug the two faulty igniters and see if problem remained
Could you plug one of the faulty igniter at the location of a good one. The goal is to isolate the problem. Is it the igniter or the electronic board.
Faulty ground problem may occur also after an spillover on the stove. In that case, use a cotton swab dipped in scrubbing alcool and clean the spark area on the igniter and the burner.
Good luck
Mar 31, 2017 | KitchenAid 31 in. KGCC505 Gas Cooktop
Electronic ignition
Most likely you got water (or some other liquid) into the control knobs. Unplug, go to bed and try it again in the morning. If you continue to futz with it, you run the chance of burning out the electronics in the control knob, like I did. :(
Oct 22, 2007 | Miele 35 in. KM326G Gas Cooktop
Cooktops Logo
98 people viewed this question
Top Frigidaire Cooktops Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Frigidaire Cooktop Expert? Answer questions, earn points and help others
