Question about Frigidaire Ovens
I have a Frigidare oven. It keeps turning off during use. What would cause this?
    Problem Solver:
  • 10 Answers
If this ocurrs during cooking it's most likely a safety cut out stat.
Posted on Sep 15, 2010
F10 code flashing on my frigidare oven
A faulty RTD sensor probe is one of the causes for an F10 code or overheating oven. The sensor probe is supposed to detect the exact temperature in the Frigidaire electricrange cavity and relay it to the oven's main control so it knows when to shut off the heating elements.
Hope this helps
Bob
Sep 15, 2017 | Frigidare Ovens
Owen in frigidare is not turning on
The element is most likely burnt out. This is the most common problem of all. FIRST OFF, UNPLUG THE RANGE !! With a bright flashlight, check the element for a spot where it looks like it's burnt. It will be pretty obvious. Hope this helps ! If not, get back with me.
Sep 05, 2016 | Frigidare Ovens
Frigidare double wall oven, both heating elements not getting hot.
Check the mains voltage at the socket it may be blown fuse or faulty circuit braker, If ok check the oven on off switch for voltage.
Nov 26, 2014 | Frigidare Ovens
Frigidare oven door bangs when opwning
Check the SPRING Tension on the door. Call the company and have a representative walk you through that process.
Apr 02, 2014 | Frigidare Ovens
My gas oven trips the ground fault circuit breaker that's it's connected to, when I turn the oven on, but it works fine on a normal circuit breaker. What is likely the problem that is causing this?
More than likely there is a ground fault somewhere. The most likely culprit is a bare wire touching somewhere. I had this problem when rodents chewed wires on the self clean latch.
Feb 02, 2014 | Frigidare Ovens
My frigidare gas oven wont turn on...
try changing the igniter it may have burned out or is weak
Aug 26, 2012 | Frigidare FGB24S5DC Gas Single Oven
Hope you can help i have a frigidare 30 in stove 7 years old oven does not go on glow coil is working help thanks andrew
the "glow coil" /ignitor is weak and needs to be replaced , to get a bit techinal for a minute since the ignitor comes on at all that eliminates all other possibilities and the ignitor must draw between 3.2-3.6 amps to open the gas valve it indeed is coming on yet not drawing enough amps(getting hot enough) to open the gas valve.I base my oponion on 30 years plus as a appliance repair technician
Jul 19, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Gas oven not heating
Hi, the oven temp sensor is not registering correct temp signals. i recommend replacing the oven temp sensor asap.
Mar 24, 2009 | Frigidare FGB24S5DC Gas Single Oven
Oven model FGF316ASA OVEN WILL NOT IGNITE
change the igniter its just weak
cost around $65 for universal fit
takes 15min to change
Nov 17, 2008 | Frigidare FGB24S5DC Gas Single Oven
Self cleaning frigidare oven FEF368CCTD
If this stove has knobs, Make sure the clock keeps time. If it doesn't you will have to manually turn this off. (DON"T FORGET OR LEAVE WHILE CLEANING) Make sure there are no large puddles of oil or grease on the bottom of the oven.If the oven is really dirty it may stink a little. Nothing but the racks can be in the oven.Press the lock button and slide the lock lever to lock the door. Set the stop time for 3 hours and turn the knob by the clock to auto. Turn the oven knob to clean. (MAY have to push to turn all the way to clean) It should start heating up. Let it finish and then cool down. It will not let you unlock or open the door until it is completely cool. Wipe out any remaining ash with a wet rag. ALL CLEAN!
Jun 28, 2008 | Ovens
Ovens Logo
163 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
