Question about Garden
Owners manual for stihl wood boss 024 AV - Garden
2 Suggested Answers
SOURCE: stihl 024 slows down when
How old is the saw? Is the chain on correctly (sharp edge of the chain faces toward you on the bottom) and is it sharp? If none of those the carburetor may need adjustment.
Posted on Dec 07, 2010
Stihl 028 wood boss av carb wont prime
Remove the primer plate, you will see small orifice on side opposite the bulb, blow compressed air through this toeard bulb side. This is check valve that becomes plugged quite often. Now blow all other orifices gently to prevent damage.
Sep 10, 2017 | Stihl Garden
How remove fuel tank from a stihl 029 wood boss ?
stihl have a range of pdf version workshop manuals for their equipment
go google and enter details and download the manual for your machine
Jun 18, 2016 | Stihl Garden
Stihl o28av wood boss will not start even after I rebuilt carb
Rebuilding it does not mean it is adjusted correctly but if you are confident with that I would check for air leaks in the hoses. Replace the spark plug or make sure that there is spark in the existing one. You can test that it will fire with starting fluid then you know that it is not getting the right amount of fuel.
Oct 10, 2012 | Stihl Wood Boss Chainsaw 20"
Stihl wood boss 024 av electric quick stop manual
There is no way to tell unless I saw a picture of the wiring out of the machine.
Mar 21, 2012 | Stihl Garden
Stihl 026 chainsaw... bogs down when giving it gas. Removed the breather and helped a little, but still bogs down under a load.
Probably need to adjust the high and low speed settings on the carburetor.
See your owners manual for location and adjustment procedures.
Apr 12, 2011 | Stihl Chainsaw 024 026 Oil Pump
Where are the oil holes that grease the chain on a 026 wood boss
karey678,
Remove the bar and chain assembly. You may have to remove the sawdust from the oil hole to find it but it will be opposite the hole in the bar ahead of the drive sprocket on the top half of the bar. Usually when you remove the bar and chain the hole can be identified by the oily sawdust in the area that I just mentioned.
Thanks for using FixYa and for the great rating.
hardrocko
Oct 13, 2010 | Stihl Chainsaw 024 026 Oil Pump
I have a stihl 024 av chainsaw. the case hinges
Are you asking about the PVC carrying case? Isn't it possible to mount a couple of small hinges using countersunk screws from inside the case to lock washers and nuts outside the case. Use a file to remove any threads extending beyond the nuts so your leg can't get snagged. It might even be worth adding a couple of countersunk flat washers to the inside of the case. HTH
Lou
Sep 10, 2009 | Garden
Garden Logo
1,827 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
