Question about Philips 32PT6441/37 32" TV
When i turn on my tv the sound comes on for about 3 seconds and then goes off...pic doesnt come on at all and the power light in front just flashes...any suggestions?
bluegreenash
  • 661 Answers
SOURCE: no picture just comes sound
sounds like the Backlight has failed, if you look closely at the screen you should be able to see the image changing, but as there is no back light there is no luminescense so it will appear black or grey, It is probably the backlight inverter or element that has failed, if this is within warrany organise with them to fix it for free,
Posted on Sep 27, 2007
SOURCE: won't power, light goes green 5-10 seconds later red flashing light
Solution Found.
I had the same problem with my 42FD5994. It was working fine, then one day I turned the TV on and the front light turned green for about 5 - 10 seconds and then the TV switched to protection mode (front green light is now red and flashing constantly). I did some research and found out the the power board is faulty. I ordered a DIY fix it kit on Ebay for around $55 (includes shipping). The kit contains 5 high temp capacitors and a new IC chip. It also comes with a good detailed photo of the circuit board the components that needed replacing.
I also spent $70 at Radio Shack for some soldering gear and went to work. It took me 3 hours to replace the 6 components. The IC chip was a pain to remove, but one that was out the rest went pretty smooth. I had to remove two extra blue capacitors in front of the IC chip to desolder some of the leads.
After I cleaned the board with Isopropal alcohol (99% pure) to remove the excess flux, I inspected the solder joints to make sure I didn't solder some runs together. All looked good.
Next I put the TV back together and hooked everything back up. I powered on the TV and the same problem as before. The TV went into protection mode. But this time I heard the speakers pop and the screen buzzed. So I pushed in the power button to reset the TV. Next, I turned the TV back on, but this time when the light was green, I quickly pushed the power button again to power off the TV. I tried the TV one last time. I powered the TV back on, and with the remote I turned the TV on. Viola! It worked. The TV powers on great, and works like a champ. I am guessing that the first time I tried to turn the TV on, the new components needed a minute to energize. I also started the TV cold, I should have plugged it in for a few minutes before I tried turning it on.
So, I was successful fixing my 42FD5594 with the DIY kit on Ebay. I ordered it from California. The company was great, and Everything arrived well protected. I figured if this didn't work, it was time to get a new TV anyway. I can save the $2000 for another day.
Posted on Feb 12, 2008
SOURCE: Philips 42 in. Plasma shut down
Thank god we purchases the ADVANCED extended warrenty. This tv has been nothing but problems.
Fuzzy picture, picture shutting off after 20 sec coming back on and now blog of colors shut off never to come on again. 7 blinking red lights on the front. Waiting for the repair man again.......
Posted on Apr 13, 2008
jerryg50
  • 1667 Answers
SOURCE: No Power / LED ERROR CODE
If there is a failure in any of the scan circuits, the set will go in to protect mode. This is most probably what is happening.
Before starting to work on a TV set is is best to have the full shop service manual with the schamatics, with all the required service details about the set.
The fault can be any of the components in the associated cricuits. This can be a bad cap, open resistor, or a failed semiconductor.
In the case where a set is going in to the protect mode, it is difficult to take voltage readings, because the power supply is being partialy shut down. The parts of the supply that runs the high voltage and scan circuits are shut down, and also the uPC makes sure that the CRT is biased off to protect it.
It is most common that capacitors go out of specs with age. To properly test the caps you would need a cap an ESR meter. The other way to test caps is to replace them until you have worked out all the defective ones. This is shotgunning for a bad cap. With this method, you an end up changing a lot of caps, and they were not the fault.
In the case of the other types of components a DVM can be used to check them. IC's must be changed to properly check them. It is impossible to properly check an IC just with a DVM.
This is an idea of what troubleshooting is.
Jerry G.
Posted on Apr 21, 2008
  • 52 Answers
SOURCE: PHILIIPS 51 IN PROJECTION HD TV
6 slow and 1 fast blink error on this model is vertical sweep failure. vertical ic's are located on large signal board. to verify error is correct would recommend disconnecting 1516 6 pin connector on lsb to msb as sometimes that board causes shutdown issues and if no change reconnect and disconnect crt anode leads going into hv generator and if no change replace large signal board
Posted on Aug 22, 2008
No pic no sound, but power on
Apparently power is getting to your TV but the internal power supply has failed
May 18, 2013 | Toshiba 55G300U TV
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
Power light comes on for 2 seconds and then off.
Need to have the power supply rebuilt, expect to pay around $350 Julio at milleniumtvsvc@gmail.com
Jul 21, 2009 | Mitsubishi WS-55807 TV
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Philips 32PT6441/37 32" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
