Question about Kodak Cameras
Kodak MX1063 replaced battery. I have 2 of them . When I turn them on the lense extendeds then retracts and shuts off??? I can not get them to stay on. They are fully charged.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with try to blow compressed air around the lens cover so that if there is any dirt it cleans if off. You can also stick a thin strip of paper between the lens shutter and the outer support ring & move it in a way that it clears the debris that's stuck in there. If still the issue is not resolved then you'll have to replace the lens assembly & lens mechanism to fix this issue. It is recommended to be done by a professional. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 16, 2010
My Kodak mx1063 camers powers up then shuts off
I had this problem with my Sony camery when using rechargeable batteries. If I put good quality batteries in it works just fine.
Jul 04, 2012 | Kodak Easyshare MX1063 10.3 MP Digital...
I dropped my mx1063 and now the lens won't retract all the way, and when I try to turn it on it starts to make the chime sound, but then just shuts right off again. Is there some sort of quick fix for...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 12, 2010 | Kodak MX1063 Digital Camera
HELP!! I am having a real Kodak moment. I have a Kodak M883, The wall charger says the battery is full but when you put the battery in the camera the camera turns on, the lense extends, battery reads...
Hello :
It seems that the battery is dead or the battery base is rusty or there's isolation stuff on it . Try to clean the base first . If that didn't help , then I recommend you to replace the battery .
good luck .
please don't forget to rate !
Apr 04, 2010 | Kodak EasyShare M883 Digital Camera
My kodak mx1063 will turn on but shut itself right off. I have put in a new battery and dusted off any debrie where the battery goes in. Any ideas?
I have o solution Our first one did the same and since it was under warrenty they replaced it but now that one has the same problem- so no solution except don't buy another Kodak digital camera!
Dec 25, 2009 | Kodak MX1063 Digital Camera
The camera will not stay on
try to use lithium batteries they are the stronger in the market, o just grab a fresh AA alkaline batteries, not the cheap batteries for clocks o remotes. otherwise it won't turn on
Oct 08, 2009 | Kodak MX1063 Digital Camera
Kdak MX1063 won't stay on...
Try cleaning the contacts from the battery and the battery compartment of the camera. I had the same problem, used a cotton swab to clean and this fixed it, it seems to be a common problem.
You can also try the official Kodak troubleshooter at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Aug 09, 2009 | Kodak EASYSHARE M1063 Digital Camera
I just got a kodak c913 camera yesterday and everytime i switch it on it stays on for seconds and then switches off, help!
My co-worker brought me a C913 with the same problem. I took out the batteries, took out the SD card, played with the buttons... nothing. A web search was unfruitfull. For fun, when I turned it on, I grabbed and held the lens. The camera turned off but the lense stayed out. I turned on the camera, the lense stayed out and the camera WORKED! I turned it off, the lense docked properly. I turned it back on, it worked... Woohoo! Theory: Either the lense was slow at coming (binding) out or was not coming out far enough. The camera shut itself off because it wasn't fully extended in an alloted period of time. Hope it works for you. Glennster™
Dec 26, 2008 | Kodak EasyShare C913 Digital Camera
Turns on then automatically shuts of
FIRST CHARGE YOUR BATTERY OVERNIGHT AND THEN REMOVE YOUR BATTERY FOR ABOUT 10 MINS PUT BATTERY BACK YOU HAVE TO ADJUST THE DATE AND TIME AFTER DATE EVERYTHING WILL BE OK BUT IF YOU ARE USING 9 OR HIGHER MEGAPIXEL YOUR BATTERY WILL BE DRAIN IN THREE TO FOUR HOURS.
Dec 12, 2008 | Kodak EASYSHARE V1253 Digital Camera
Kodak easy share z612 will not turn on to take a picture
When the battery dies, usually the camera will retract the lens if possible. If the battery is so dead the lens can not retract, I would recommend trying to charge or change the battery. Or try to turn the camera on, and then manually shutting it off if you can.
Nov 16, 2007 | Kodak EasyShare Z612 Digital Camera
Cameras Logo
103 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
