Question about Samsung CLP 315 Laser Printer
Have two computers:dell dimension 4400 & gateway DX484; computers are networked;original computer is dell 4400 which operates two laser printers:samsung clp315 & hp1200;it seems gateway computer does not recognize either samsung printer or hp printer;cannot print using from gateway computer; is there a solution? thank you ginocordani@msn.com
  • ginocordani Sep 16, 2010
    Please consider my computer ability level not far above elementary; therefore, if possaible, would appreciate detailed, stepped description of solution.
    Thank you very much,
    Gino Cordani
  • 4,281 Answers
First make sure usb cable connected to your printers from computer is working fine.Try with another usb cable. Then uninstall usb drivers from computer for that right click on my computer icon then click on property then hardware ->device manager uninstall all usb drivers 1 by 1 then it automatic install all usb drivers. Then uninstall printer driver from control panel->add remove program download driver from below link then install then both printer are working fine. Click here Click here Let me know if you need further assistance.Thanks for using FixYa.
Posted on Sep 16, 2010
  • Samsung Master
  • 11,800 Answers
First of all you must make sure that the Dell is visible and accessible from the Gateway when you try to print. To check for that create a folder in it , fill it with something , share it and try to modify it.
Then make sure the drivers are correctly installed and that the printers have distinctive names
Finally go to Control panel / Printers and right-click the printer icon and click Properties. In the Properties window click the sharing tab and make sure both printers are shared. Then run the Printer wizard on the Gateway to find out if the printers are detected.
Posted on Sep 15, 2010
  • Azrael SRL Sep 16, 2010
    Open Control panel ; put the cursor on the Printers and if the printers were correctly installed they will appear there; right-click each printer icon and click Properties. In the Properties window click the Sharing tab and make sure the printer is shared - you must do that for bot of them.
    Then run the Printer wizard on the Gateway (Start - Control Panel - Printers - Add Printer) to find out if the printers are detected.
Bios pins where is correct placement on DELL 4400
Hello here is the homepage:
http://www.dell.com/support/drivers/us/en/04/Product/dimension-4400
To clear the CMOS values
1.Turn OFF the computer and unplug the Power cord.
2. If your motherboard uses jumpers move the jumper from pins 1-2(default) to pins 2-3. Keep the cap in this position for about 10-15 seconds, then move the cap back to its original position.
If you motherboard has only two pins for CMOS reset , then you may use use a metallic object like a wire to create a contact between the two pins for 10-15 seconds.
3.Plug the power cord and turn ON the computer .
The bios can also be set to reset, by removing the cmos battery.
Hope this will help you.
Feb 03, 2013 | Dell Dimension 8400 PC Desktop
Need step by step instructions to reinstall XP home edition recovery CD on dell 4400 32 system is damaged and I can not open anything
Insert your System CD (the one with the operating system on it). Boot up the computer and press F12 during the couple of seconds at the very beginning of the boot sequence to access the boot menu. You'll want to specify the CD-ROM as your 1st boot device. The system will boot from the system CD and you just follow the prompts to reinstall the operating system. Just realize, this will restore your computer to "out of the box" condition. You'll have to update Windows XP several times as well as your drivers. Also, ALL data that was on the computer will be lost forever.
Mar 18, 2010 | Dell Dimension 4400 PC Desktop
Dell gateway dimension desktop 2600
You can install driver from following likn.
Download your network adapter driver then install in your computer.
Select your computer model from this link then downlaod network adapter driver.
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Then set ip addreses as your router settings then you can access internet .
Aug 01, 2009 | ZT Group CISNET A7022 PC Desktop
Dell Dimensions 4400 boot failed: system halted
reload the windows, it missing the loading operating files.
Jul 06, 2009 | Dell Dimension 4400 PC Desktop
D4 Post code using tech aid diagnostic card
check power supply in back to see if you have on and off switch but you would'nt be the first with this problem from dell about the power supply going out meaning:
if you don't have nothing happening when your trying to boot the computer then it's the power supply, plug in computer power up and feel in back to see if the fan is blowing if nothing power supply is gone call dell.
Apr 05, 2009 | Dell Dimension 4400 PC Desktop
Replaced 128mb with 512mb in Dell Dimension 4400. Plugged everything back in & turned on. Or at least think it is turned on; there is a green light for both the power button and hard drive lights. ...
If you have replaced the memory on a computer and it does not turn on normally that means that either the memory is defective or it is not compatible. Do you hear beeps when you turn on the computer?
Nov 26, 2008 | Computers & Internet
Dell Dimension 4400 Won't Turn On
inside the pc there should be a green light. called flea light. if its not on.. then id say motherboard or power supply are bad.
take power cord off. and hold power button down for 10 ecs. then reconnect and retry. i think its abad psu.
Oct 09, 2008 | Dell Dimension 4400 Power Supply ** FREE...
Samsung CLP 315 Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
