Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
On our Coleman Furnace, we were getting a code of Combustion Air switch closed. After much fidling and googling ways to fix it (we tried everything), We bought a new switch and new hoses. But we are still getting the same code. We have fire in the box and the blower motor is running. We can only get it to light by sucking on the hose. But it won't stay lit or blow heat. What do we do next?
    President:
  • 3,072 Answers
May be the thermo coupler
Posted on Sep 15, 2010
Coleman combustion air switch failed to close
Hi, new switch can be found on amazon... here: Amazon com Coleman air switch. I hope this was helpful. Cheers
Nov 24, 2010 | Coleman Propane Forced Air Heater...
Trying to light the coleman furnace and error flashes says "Combustion air switch failed to close. Have turned circut breaker off and tried to start it several times. Cannot even get it to light.
Make sure both the exhaust vent and the air intake vent is clear of any obstruction. If the pipes do not pitch back toward furnace, they may have water in them blocking the flow of air. Also check the condensate drain and pump for blockage.
Oct 03, 2010 | Coleman Heating & Cooling
Have a Evcon Coleman Furnace shows three green blinking lights but will not ignight what could be wrong
I have had the same problem with mine for the last 2 years. Remove the motor on the side of the furnace(usually held on by 3 screws) and turn the fan blades inside by hand. after sitting all summer it seems to get stuck. If it moves freely, replace the motor and try to start it again. This fixed mine the last 2 years! Hope this helped.
Sep 29, 2010 | Coleman Propane Forced Air Heater...
I have a coleman/evcon electric ignition lp furnace. I get error cede combustion air switch stuck closed even after replacing the combustion air switch.
Have you tried to replace pressure switch for the combustion air. If your not sure where to find it if you pull the front panels off follow the flue pipe down to combustion chamber the combustion fan motor is either inside the flue pipe or out side of it not sure on the one you have but you should see two plastic tubes that connect to a barb onto the topside of the fan and one on the bottom they both should go back to the pressure switch. i hope this helps you if you have any more question or if this doesnt fix the problem just reply back to this message . Make sure fan is working when furnace starts up. It should be the first thing that comes on when there is a call for heat
Jan 20, 2009 | Coleman Propane Forced Air Heater...
Heater flashes 3 times says it means combustion switch failed to close
Combustion switch is your vent safety.. Check your vents outside for blockage, sometimes the intake pipe will freeze or frost up not allowing the preassure switch(vent safety)to close. putting furnace into a lock out.. you can reset the furnace by turning the power on and off.. if there is no power switch just remove the bottom door and reinstall...
Jan 08, 2009 | Coleman Propane Forced Air Heater...
Furnace shuts off
Defective combustion air switch. The 3 blinks are an error code. You didn't say, but I'm guessing you have a Coleman Evcon. They had alot of defective Combustion air switches. Your specialists were not that.
Jan 05, 2009 | Coleman Propane Forced Air Heater...
I have a red t brand furnace. i think it's part of coleman.
could be bad switch but is the vent free and open of all debris or being blocked by anything
Nov 18, 2008 | Coleman Propane Forced Air Heater...
Coleman mobile home furnace...Model number DGAA077BDTB...The furnace about a month ago started going out ( flash code- Combustion Air switch stuck closed)We replaced the thermostat on the wall and it...
I had the same errror code on my coleman furnace (3 flashes combustion air switch failed to close) but at first didnt realize there was even a light that gave codes..Anyways long story short, after searching many forums one guy mentioned about the furnace giving a false reading and talked about improper air flow ( coming in and going out) which isnt triggering the switch correctly. After thinking about it and after getting the furnace to run correctly every time I took the door off to tap on the switch (and other spots not knowing what the problem was yet) I always put the door right back on then the furnace would do the same thing (stop running). so I pulled the door off again got the furnace to work properly and left the door off and tested it. It ran great, it started and stopped like normal for a hour and realized I might not be getting proper air flow. Then I remembered I asked my roommate to change my filters for me while I was gone (which he did) and looked at them while I still had the door off and realized the filters were in backwards! which resticted the air flow so much the switch wouldnt operate fully. so check your air filters, something so stupid almost cost me a house visit by the furnace guy....this may not be everyones problem but maybe I will help someone save a house visit....I still cant believe that was my problem and the furnace is still running great.
Mar 14, 2008 | Dishwashers
Heating & Cooling Logo
110 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
