Question about Olympus VN-3100PC Digital Voice Recorder
Vn-3100 i have the non pc version of this device and i need to transfer the files to my pc. i do hve the patch cable that converts the headphone jack to a usb can you help
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
Use a compaticord and plug from the earphone to the mic of the pc and use sound recorder to record the message
Posted on Aug 20, 2008
I can't find the drivers for my Olympus Digital voice recorder VN-2000PC. What can I do? I can't tranfers my audio files to my PC.
Do you need the software/drivers for the VN-2000PC or the VN-2100PC? The software for the VN-2100PC is available here: http://www.olympusamerica.com/cpg_section/cpg_support_downloads.asp?id=1270 . Select your OS and you'll find the software.
The VN-2000PC doesn't connect to the computer via a USB port. To transfer your files to a computer, connect the earphone jack to the line In (blue) jack of the computer with a 3.5mm to 3.5 mm audio patch cable. Use a program like Audacity to record the audio track during playback. Make sure to set the Audio input to Line In. (In Windows 7, click Start > Control Panel > Hardware and Sound. Under Sound, click Manage Audio Devices. Then select the Recording tab and set the input device.) Then set the recording device in the software as well. Click the Record button in the software and then start the play back on your VN-2000PC. You should see a flat line for a bit then see a wave form start. If the line stays flat, you haven't set the Line In device properly.
I hope this helps.
Sep 01, 2012 | Olympus VN-2100PC Digital Voice Recorder
I have a olympus voice recorder vn-5000 and i dont know how to transfer de audios to my computer
Some of these devices have a port....on one side (or top) that looks similar to that of a cell phone charger connection that allow file transefer via a USB cable or by removing the memory card. This particular modle allows neither. To get the files off of the recorder you have to literally play the file into your computer...can be time consuming but this is how you do it. You will need a cable that has the headphone plugs on both ends. One end goes into the earphone connection on the recorder and the other into the microphone (input) of your computer. Most computers have a built in program that allow recording. You record (into the computer) what the VN-5000 in playing...thru the output of the headphone cord. Not an easy cut and paste solution but is what is required to get the files off the device. Best to you.
Feb 06, 2011 | Olympus Cameras
I recorded meeting minutes to my digital OLYMPUS VN-480 PC voice recorder and want to transfer the recording on it to my Dell Inspirion/1100 laptop. Could I transfer the audio from the headphone jack to...
yes, it is possible. You will connect the earphone jack from your voice recorder to Mic of your laptop. Then you will be needing a wave software on your laptop, download the wave software from the internet, open the wave file, then press play on your voice recorder and the minutes will be recorded into your laptop as a wave files.
But the easiest method of tranferring the minutes is by using the usb cable of your OLYMPUS VN-480 PC voice recorder. If you don't have it you can purchase it, then connect it from your OLYMPUS VN-480 PC voice recorder to the usb of your computer and it will be read like a flash drive.
After that, go to my computer and you will see a drive representing the OLYMPUS VN-480 PC voice recorder, open the drive and you will see your minutes, then simply create a folder on your computer, and copy, paste the minutes into the created folder. And the would be all.
God luck.
Oct 11, 2010 | Sony ICD-B200 Digital Voice Recorder
Digital voice recorder connection problem
There are many steps in installing Digital Wave Player on VISTA, it is important to follow every step since installing Digital Wave Player on VISTA is dependent on this process.
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. In the next window browse to the location that you downloaded the Digital Wave Player application to
12. Click Next
A security warning window will open,
13. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
Jun 02, 2009 | Olympus VN-2100PC Digital Voice Recorder
I can't conect my recorder to my PC
If it is a VN-1000 it is not designed to be interfaced with a computer as there is no USB port on the unit at all. If you wish to transfer the files you can purchase what is called a compaticord or patch cable that will connect through the ear jack of the recorder to the mic jack of the computer to be able to transfer the information on to your computer.
Apr 13, 2009 | Olympus VN-1000 Digital Voice Recorder
File transfer VN-480PC doesn't work on notebook (Vista)
12. Click Next
Feb 19, 2009 | Olympus VN-480 PC Digital Voice Recorder
Olympus VN-3100 software
Call tech support at Olympus. They maybe able to help you with a special link.
Feb 06, 2009 | Olympus VN-3100PC Digital Voice Recorder
Vn-3100 non pc
I beleive that recorder is mono. You have to use an adapter for stereo headsets or listen on one side of the head set.
Accessories are available at olympus.com
Jun 30, 2008 | Olympus VN-3100PC Digital Voice Recorder
Here is the download instructions for the VN recorder software it work with the VN 240Pc up to the VN 4100PC and Widows 2000 - VISTA.
Digital Wave Player (2.1): is available via download as a courtesy, please follow the instructions below:
After unzipping the file, click on the SETUP.EXE file to begin installation.
Download update: http://olympusamerica.com/files/DWPUP2EN.zip
Download update 2.1.3: http://olympusamerica.com/files/DWPUP4EN.zip
Jun 23, 2008 | Olympus VN-3100PC Digital Voice Recorder
Olympus vn-2100pc
check out this link, i had exactly the same problem but this blogger has a working patch for the vn-2100pc and vista - works fine now!!
http://blog.ironguard.net/2007/06/olympus-vn-2100pc-and-windows-vista.html
Sep 13, 2007 | Olympus VN-2100PC Digital Voice Recorder
Olympus VN-3100PC Digital Voice Recorder Logo
156 people viewed this question
Top Olympus Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
