Question about Whirlpool Refrigerators
Icemaker stopped working - Whirlpool Refrigerators
    Problem Solver:
  • 10 Answers
It can happen that the ice got too thick for the little auger and it snapped off. The other issues arise when the water inlet tube freezes up so no water gets dispenced into the ice maker.Defrost unit to check this out. At least 24hrs.
Posted on Sep 15, 2010
Why did it stop working?
How to Fix an Icemaker-EASY ICEMAKER REPAIR - YouTube
? 3:52
www.youtube.com/watch?v=4Lmpy--Rz2I
Aug 18, 2012 - Uploaded by n4ktz If you have a Kitchenaid, Whirlpool, Maytag, Estate, Roper orKenmore Refrigerator/Freezer and the Icemaker ...
Jul 31, 2015 | Kenmore Refrigerators
MY ICEMAKER HAS STOPPED HOW DO I KNOW IF IT IS COMPLETELY BROKEN AND WHAT CAN IT DO TO GET THE ICEMAKER WORKING AGAIN.
There are many problems that will prevent the ice maker from working. It could be frozen over, the inlet water valve could be inoperable, the harvest thermostat may be bad. If you can remove the ice maker, you might be able to tell what might be the problem.
Oct 13, 2014 | Whirlpool Refrigerators
Water will not stop flowing in to icemaker
Dirt in body of icemaker water supply valve. OR. Ice maker timer stuck when it selected "add water to icemaker.
The first solution is simple, change icemaker water filter and disassimble valve to clean.
The second is simple, buy a new icemaker.
May 15, 2012 | LG LFC25760ST 25 Cu. Ft. Panorama French...
Ice maker has stopped working
IT is either your inlet valve which is cheaper than replacing the icemaker, when you replace it(located behind panel on back of fridge) make sure you do not have ice build-up in the water tube behind icemaker. If that does not work than you will have to replace icemaker. If you take a flathead screwdriver and pop the cover off of your icemaker you will either have a screw that you can manually turn to test the icemaker to see if it is working. There is one you can do this with, the other one you would need an icemaker tester that most tech's have. Good luck!
Aug 20, 2010 | Frigidaire Refrigerators
Icemaker doesn't work
Icemaker seems to be working now.
I think that moving lever and switching on/of helped. I see and hear that it is producing ice now.
Jan 10, 2010 | GE PSS26SGRSS Stainless Steel Side by Side...
You will have to determine whether the problem is due to no water getting to the icemaker or a control problem in the icemaker unit.
There is a water valve near the bottom of the refrigerator where water from the outside source enters the refrigerator. This valve sends water to the icemaker (and probably the water dispenser) when the refrigerator controls call for water. These valves can malfunction, and the water lines can get blocked.
The other possibility is that something inside the icemaker controls has malfunctioned, and it is not calling for water.
Oct 18, 2009 | KitchenAid Superba Architect KSCS25INSS...
Amana side by side icemaker stopped working
The icemaker is not working because the water pressure is too low. An icemaker is controlled by a timer so it has no idea how much water is in it. The water valve gets energized for about 7 seconds letting water in the icemaker, but if there is no water pressure then the icemaker will not fill.
Sep 12, 2009 | Refrigerators
Ice maker stopped working
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig .
Sep 05, 2009 | KitchenAid KSRP25FNSS Side by Side...
Icemaker not working after installing new filter
I have a Kenmore 106.56542400 icemaker stoped working ,water line is cleared not getting water to icemaker
Jul 02, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
you likely need a new icemaker (part # 2198597) i would visit the following website to help determine this fact.  http://fixitnow.com/sbrvrs/icemakers.htm
Feb 05, 2009 | Whirlpool GD5SHAX Side by Side...
Refrigerators Logo
42 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
