Question about Frigidaire ATF6000ES Front Load Washer
Front load washer frigidaire leaving small marks on clothes
I have had a frigidaire front load washer for 10 months and about 2 weeks ago the washer started leaving small circular marks on the clothes. I had a tech come to the house to look at the machine. He said that the problem was that I had well water which is hard water. He said to use fabric softener to fix the problem. I started using fabric softener and I still am getting the marks on the clothes. All of my daughter's new summer clothes are ruined.What do I do now?
  • clairegirl Jun 26, 2008
    I have the same problem with my 6-year-old Frigidaire front loading washer. A few months ago it began leaving perfectly symmetrical rows of small, circular grayish grease-like deposits on random articles of clothing. Usually about 1 item per load would be damaged, but sometimes it would be none, sometimes it would be 2 or 3. Around the same time I began to notice that another type of stain would occasionally occur as well. The substance is the same (dark, greasy, impossible to remove) but the appearance was more like something that had been dragged under a moving vehicle (not perfect dots resembling the inside of the washer drum).
    At any rate, I have tried absolutely every method of removing the stains, to no avail. I have examined, and cleaned, the interior of my washer (including the door gasket) many times and yet the problem persists to my dismay. I do not use fabric softener of any stripe (liquid or dryer sheets), but with two small children do laundry every day and rely on a washing machine to render my clothes cleaner than when I put them in rather than dirtier!
    I'm pretty much at my wits end with my machine and was actually just doing some research in the hopes of making a better choice on my next washer when I came across this site. Obviously I would rather fix my existing machine than purchase a new one if a fix is possible. If anyone has any insight into this problem, please let me know. I have many photos of the specific damage if that would help with the diagnosis.
    Thanks!!
  • mkchesta Nov 12, 2008
    i have the same issue with the washer leaving a grey residue (like fine powder) and ruining one item per load, leaving it looking like it was caught in the gasket and dragged during the load. initially i thought i was perhaps overfilling the machine, but this still happens with smaller loads.
I have twice taken apart this front loader Frigidaire washer (also sold as Kenmore) to replace the rotted out aluminum spider arm supporting the spin-basket (which seems to universally fall apart within 5 years), and now I started observing the described black stain pattern on the clothes. As with the spider arm breakdown, this problem has nothing to do with water hardness, softeners, detergents, or dryers (I line-dry all my clothes), and everything to do with the poor quality design of this machine. I have not yet positively identified the cause of the black stains, but I suspect that the bearing seal is breaking down and in the process is releasing greasy particles that mix with the clothes and create the described black stain patterns. Unfortunately the repair would cost more than a new machine for most people, as the spider arm is probably just about gone by this stage. I am lucky to own another junk washer for spare parts and am able to fix it myself. For skilled do-it-yourself mechanics, it is possible to find a replacement seal and bearings on the internet, assuming the spider arm is new (over $200 part), or still in good shape.
Posted on Dec 19, 2010
I don't have a solution, but I have what sounds like the same problem. Grayish-brownish blotches, some are circles or sort of crescent-shaped, and some are longer marks. Not rust-colored at all. Nothing takes them out. Mostly on t-shirts and towels. Just one or two per load, sometimes none. Cleaned the whole inside of the washer, including the gasket. I put a filter on the water line. We have really soft water, so I don't use water softeners. I use very little detergent, so it doesn't seem to be any kind of build up. No dryer sheets either. I have a 6 year old Frigidaire GLTR1670ASO. To be honest, I think I will just get rid of mine and buy a top-loader. Our water bills didn't go down when I got this washer, so it doesn't seem worth it. It somehow makes me feel better that I found someone else who knows what it's like !
Posted on Oct 13, 2008
I have had this problem with not only this washer, but my prvious one as well. Both times these marks started to appear it was not long after that my water heater neede to be replaced because the heating rod in the water heater was corroded and the junk in the bottom of the water heater (if you don't flush out the tank every now and again) this gets stirred up, gets into the water and on your clothes. My first water tank was about 13 years old when this started to occur. The other only 2 years old, (piece of **** bradford white!). Anyway maybe read up on your water heater and flush out some of the sediment at the bottom of the tank.
Posted on Oct 18, 2008
  • 868 Answers
Do you use Fabric softener sheets??If so, than look in the dryer foe one to be caught in there and as it  makes contact with the clothes it will actually mark them.If you dont use them than take a long look inside of your washer ,look for something stuck in the tub or around the top clothes gaurd that sits above the edges of the tub.Also ,are you sure its not oil?Oil will leave a distinctive mark that is almost impossible to remove.Most likely it is a item stuck in the Dryer and not the washer.I'll be happy to guide you through this at any time .
Posted on May 22, 2008
Frigidaire won't go through cycles...
you need to call a repair service . the control board has failed
Jan 30, 2018 | Frigidaire ATF6000ES Front Load Washer
How do I go to clean cycle-Frigidaire affinity ATF6000fs
I was doing a search for infor on how to clean my affinity front load washer, and came across this infor and this did not work for me either, but when I turned my dial to rinse and spin then hit clean the clean option appeared.
Jan 21, 2010 | Frigidaire ATF6000ES Front Load Washer
Mildew smell
PLEASE KKEP IN MIND THAT THE MAYTAG NEPRUNE FRONT LOAD WASHER IS WHAT GOT MAYTAG IN TROUBLE!!!!!!
Whirlpool bought MAYTAG about 3 year ago.
THe mold is because of the rubber boot in the front of the door. PLEASE check to see if the rubber seal has a small hole in the lower bottom of the seal to let small portions of water drain out. If you DO NOT have this small hole, you need to replace the rubber boot with one that has a hole.
NOW, WORD TO THE WISE and this is what I tell ALL FOLKS that have a FRONTLOAD WASHING MACHINE:
AFTER you washer in the washer LEAVE THE DOOR OPEN so that the washer can ventilate and remove any moisture that is within.
ALSO, every 2 months, get a WHITE CLOTH with WARM WATER and a littl;e bit of BLEACH and CLEAN THE RUBBER BOOT!!!!!!
Nov 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
FTF530FS Front Load washing machine. Clothes smell.
all front load washers have the problem. Mold and a build up or dirt and soap and fabric softner cause s old musty smell. The low water use makes the machine dirty and build up inside. Run a few Hot water washes with out clothing, Run it empty ,(run your hot water neer your washer to get the cold water out of the house pipes) hot water and pour bleach in side, 2 or more cups. Keep doing it. When your not using washer leave the door open so air can get inside. Hot wash,es with bleach will keep it clean, also dont use fab softner.
Nov 11, 2009 | Frigidaire FTF530FS Front Load Washer
Frigdaire front loader leaves black marks on clothes
the bearing oil seal has probably broken down, black greasy marks are a giveaway.
Oct 04, 2009 | Frigidaire GLTF2940ES Front Load Washer
Front loader leaving black marks
had the same problem. Tried changing the washing powder to no effect.
Jul 03, 2009 | Frigidaire GLTF2940ES Front Load Washer
Clothes smell like mildew
HI thanks for your question. My solution is 1 cup of vinegar, per wash load. In time, will solve your problem.thanks the appliance doc. please rate my answer. thanks.
Oct 04, 2008 | Frigidaire ATF6000ES Front Load Washer
Bleach stains
try putting your washer on the highest boil wash this sometimes will stop any of these problems from accuiring again
Jun 12, 2006 | Hotpoint WMM39 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
1,740 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
