Heating element makes a loud hum. this unit is a new one which was gotten to replace another one which did the same thing. Thanks
  • 32 Answers
There is a restriction or your ducting is too small
Posted on Sep 16, 2010
  • trainman48 Sep 16, 2010
    Thanks for trying to help. I did not make it clear this is a base board heater there are no ducts.
Mr Steam MS Super-1 kW: 10 doesn't generate steam
the first thing the generator should do when you hit the on button is fill. You will hear the water entering the tank. Once the water stops it indicates that the water has reached the water satisfied level, after which you should hear a loud click(your contactor engaging for the heat cycle, newer units will have all three light on the side lit). After this point is you aren't getting any steam after 5 minutes it probably means your heating element may be damaged. It would be best to remove the element at this point from the left side of the unit via 6 bolts and 2 wire leads. Any physical damage on the element such as a pinhole pop, burn mark, melting, or scar will surely prevent the element from heating
Jan 10, 2014 | Mr Steam Electrical Supplies
I have a Magic Chef refrigerator in my apartment that is approximately 11 years old. It has worked fine until apprx a year or so ago when it became louder and was emmiting more heat. We cleaned the coils...
this problem is creating by compressor bec u said that this unit is about 11 year s maybe the wear and tearing of mechanical parts thats cause of vibration and humming sounds, of ref. heat is only normal try to replace new compressor or replace new unit of ref.
Feb 05, 2011 | Refrigerators
Heater makes noise humming sound is this normal i replaced 3 8ftrs they make the humming sound the smaller 6ftrs and3 ftrs dont make a sound ?????
This is perfectly normal. This is caused by the heating elements sagging over time. In my years of doing this I have seen this many times before. If yours is new then it may just be a mount loose. Turn it off and check the mounts on in inside of the unit. UNPLUG IT FIRST!!!
Jan 26, 2011 | Fahrenheat Electric Convector Baseboard...
MY DISHWASHER IS MAKING A LOUD NOISE AND THE DISHES ARE NOT COMING CLEAN. ALREADY HAD THE MOTOR REPLACED ONCE
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jan 06, 2011 | KitchenAid 24 in. KUDI01ILBS Stainless...
The unit is 3 years old and when I turn it on there is a loud hum. Theunit also does not heat but turns the turntable?
From your description it sounds like the magnetron has failed in this oven. That's the part the makes the microwaves to heat the food. It typically fails by shorting out and making a loud hum noise. It not usually worth fixing since the price of a replacement magnetron is almost as much as a new oven.
Jul 01, 2010 | GE Profile Spacemaker JVM1871 Microwave...
Dishwasher makes a loud, low pitched humming sound & is leaving a gritty residue on dishes when the washing cycle is completed
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Mar 03, 2010 | Maytag 24 in. MDB5651A Built-in Dishwasher
Not heating and no manual. Need amnual
If drum turns and no heat.
If unit is electric, look for:
1. Safety tripped or malfunctioned at heater elements.
2. Burnt out element. Wire has come loose or burnt off due to loose connection.
3. Clogged or restricted exhaust. This causes a safety to activate and stops the heating process.
4.Timer malfunction and needs replaced.
5. Improper voltage to unit. Reset breaker and verify proper voltage to unit. (Usually between 208 to 240 volts depending where you are located and the manufacturer of the unit.
Please keep in mind that in many cases, it is cheaper to buy a new unit that it is to repair the exsisting one. Do you homework on this. I've gotten real good dryers at about $200 from places like Lowes.
Hope this helps and let me know how things work out.
May 11, 2009 | Hotpoint NWXR473EV Dryer
Dryer wont heat but runs
Hi, Unplug the dryer and remove the rear panel (on most models). Then take a continuity test on the element as well as the thermostats and the thero fuse. If any of these parts have no continuity, they are bad and will need replaced.
I hope this is helpful. If I can help further, please let me know.
Thanks
Vic
May 11, 2009 | Kenmore 64902 Electric Dryer
Maytag dishwasher.Loud humming noise, wash cyle,at beginning
Is the water filling up and then draining out? Mine did this and a part was broken inside the unit. The part was five dollars and called a lifter. I fixed it myself.
Jan 01, 2009 | Maytag 24 in. MDB3700 Built-in Dishwasher
Loud humming
If this is an electric resistance heater then there is no power supply or transformer. I had a baseboard heater that would hum loudly and I found there's a wire that runs along the bottom to connect the far end of the heat element to the electrical wiring at the supply end. This wire becomes magnetized from the current flowing through it and vibrates in the channel it runs through. I was able to open this channel and squirt a bit of silicone caulk in to keep the wire from vibrating and the hum is gone.
Dec 19, 2006 | Honeywell HZ514 Baseboard Heater
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
