Attention: SD TECH have mitsubishi 65905 tv when turned on green light comes on no sound or picture no codes
  • 5 more comments
  • mdoctor1955 Sep 15, 2010
    it was manufactured in may 2000 no the power light does not go off it comes on and there is relay that clicks i could not get any codes
  • mdoctor1955 Sep 17, 2010
    sorry for so many post when sending would say try again
    yes you are right it is on the center board and the little board that sticks up from the center board that is the jungle ds board the connections are covered with glycol pulled the jungle board off center board what now
  • mdoctor1955 Sep 18, 2010
    I willgive it a try will let you know what happens thanks for your help
  • mdoctor1955 Sep 19, 2010
    i cleaned all the glycol off the boards now got pic and sound but red green and blue look like 3d and picture is curved pic looks like one from your notes about convergence problems also cannot adjust convergence asper manul
  • mdoctor1955 Sep 21, 2010
  • mdoctor1955 Sep 26, 2010
    yes helped me fix the problem great job
  • mdoctor1955 Oct 06, 2010
    I cleaned the board the set now turnes on and i have sound and picture but now can not set convergence what next
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
I presume is is WS-65905 which is a 1999 model and it may or may not have the self check feature.
Does power light come on and then go off?
How did you read the codes?
SD TECH
Posted on Sep 15, 2010
  • 12 more comments
  • SD Tech
    SD Tech Sep 15, 2010
    No error is usually 1 blink, 2 blinks
    You press menu and device for 5 seconds and release both and watch power light for blink code two digit.
    If 1,2 something odd is wrong--------Have you examined the set for any sign of GLYCOL leaking from the area of the picture tubes? Remove front speaker grill (pulls out usually) and directly behind it is an inspection plate. Can you try this? If so I will tell you what to look for.
    The click is the power relay coming on.
  • mdoctor1955 Sep 16, 2010
    I pulled the inspection cove and on crt-b the white strip is yellow the other 2 are white do not
    see and leaking glycol fluid
  • SD Tech
    SD Tech Sep 16, 2010
    No, it will be if there on the circuit boards, usually in the first three inches from front of set---the green board to the right (looking from front of set) is the signal micro board---lots of parts soldered to the top of that board---the glycol will appear there in tiny amounts----solder connections that should be bright and shiny will look dull or discolored----it does not take much glycol.
    The middle board contains deflection and convergence circuits---damage if a leak above will appear the same depending on how much leaked----this stuff damages leads on parts and may look like model airplane glue-----
    You have to look very carefully as even a small amount (drops) will cause problems. If it is there the green board is most likely---middle or other would usually trigger a error code---but not the green board.
    I have looked (and I know what to look for) at some of these for several minutes before I saw the damage---solder connections will look dull or even somewhat white, like a powder residue.
    SD TECH
  • SD Tech
    SD Tech Sep 17, 2010
    Do you have a air compressor? The way we dealt with this in shop was to take board to sink and with very hot water and a small brush wash the glycol off---try to keep it just in area with the damage.
    Then with compressed air dry the board completely---we also after this would if warm day put it out on the concrete and let the sun work on it. You are going to have to get it all off and look for any parts with physical damage.
    What I further suggest is when you put it back in the set cut a piece of cardboard and place it above that area, put it at a angle so any drips run forward off of the boards.
    I know using water sounds ODD---but the glycol is water removable only----The cardboard will allow you to see if the set works.
    If it does you have two choices---leave the cardboard in place (under all three tubes in front of boards) or find which tube is leaking, remove and drain it and redo the two seals---not real easy and wear rubber gloves as the glycol is very toxic.
    If it is in the area indicated it most likely is the middle tube--no way to tell----small openings in rear corners of the metal shields around the tube have holes---take a paper tower to them to see if any liquid.
    SD TECH
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
Tip
MITSUBISHI PROJECTION DIAGNOSTIC FEATURE
If you have a Mitsubishi rear projection where the model number begins with WS or in some cases VS and the set turns on for a moment (green light comes on and goes off) Do the self check most models made from 1999 through about 2005 have:
When the power light comes on and then goes out, on the front of the set press both the MENU and INPUT buttons at the same time and hold them both in for at least 5 seconds and then release both buttons.
The power light will blink a 2 digit error code and repeat it at least 5 times.
This does not apply to sets with a WD model number, they have different codes.
The most common error will be 2 blinks, 2 blinks- a pause and then it will repeat it for a total of at least 5 times.
To get it to repeat this--you have to unplug the set, try to turn it on again and repeat the process.
The error codes are to try to narrow down where the problem is.
If you get one, you can post a question in the Free section here attention:
SD TECH AND I WILL TELL YOU WHAT IT MEANS AND MAY BE ABLE DEPENDING ON THE ERROR TO TELL YOU HOW TO FIX IT.
Mitsubishi was one of the first to have this feature so techs could with ease know where to look for whatever was wrong--a time saver and several other companies followed suit.
Again: Post either a free question or a Premium question here Attention: SD TECH and I or some other expert will be happy to assist you.
on Aug 12, 2010 | Televison & Video
My Projection Tv - when I turn on it turns right back off no picture no sound ? help
To know where the problem is:
when set shuts off and green power light goes off:
On front of set press and hold both the menu and input buttons at same time for at least 5 seconds and release both buttons.
Power light will blink a two digit error code like: 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
May 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
I have a mitsubishi ws-65315. When I go to turn the tv on the green power light comes on and you can hear the tv click on, but seconds later shuts off.
this model has a self check, when green light comes on and then goes off. Push and hold both the Menu and Input buttons on the front of the set for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks 2 blinks, a pause and then repeat it several times.
SD TECH
Feb 22, 2011 | Mitsubishi WS-65315 65" Rear Projection...
Click but no picture
Please do self check model listed has: when power light goes off on front of set press and hold both the menu and input buttons for at least 5 seconds and release both.
Power light should blink two digit error code like: 2 blinks, 2 blinks, a pause and repeat 4 more times.
Let me know what error code and I will tell you what it means.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Aug 21, 2010 | Mitsubishi WS-65905 65" Rear Projection...
My tv green light comes on but then turns back off cant watch tv why is that
when you turn it on and then the green power light goes off:
On the front of the set press and hold both the Menu and Input buttons at the same time for at least 5 seconds and then release both.
The green power light should blink a error code at least 5 times: most common is 2 blinks, pause and 2 blinks----
Let me know what error code you find and I will tell you what it means--2,2 is the most easy to fix and common.
SD TECH
Aug 03, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi Medallion 72 inches Tv support does not turn on, when we touch the power button the green lights turns on and there is a clicking sound and the green light goes out
Please try the self check feature this set has:
when power light comes on and then goes off: On the front of the set press and hold both Menu and Input (or device) buttons both for at least 5 seconds and then release both.
The power light should blink a two digit error code--like--2 blinks, a pause, 2 blinks..........it will repeat the error code several times.
Let me know what you find and I will tell you what the error may mean.
If this helped you rate this solution as I do this here for free.
SD TECH
Dec 20, 2009 | Mitsubishi WS-55511 55" Rear Projection...
I turn the tv. on , the green light comes on then
When you turn it on and it shuts off---ON THE FRONT OF THE SET PRESS AND HOLD BOTH THE MENU AND INPUT(DEVICE) BUTTONS TOGETHER FOR AT LEAST 5 SECONDS AND RELEASE BOTH BUTTONS.
Power light should blink a two digit error code---for example: 2 blinks, a pause and 2 blinks--This is the most common error code.
Let me know what error code you get and I will tell you what it means and if 2-2 what the problem is.
If this information helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 12, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Televison & Video Logo
167 people viewed this question
Top Televison & Video Experts
Electro Med Services...
