Question about Bernina Activa 130
Granddaughter has just received Activa from her greatgrandmother. Sewing great when received. Now it want sew a stitch. Want pickup bobbin tread to form a stitch. I've checked treading, making sure bobin is in tach What are we doing wrong?
  • sqs1011 Sep 16, 2010
    Has the needle hit any pins or has the needle hit the needle plate?
  • shirlholt1 Sep 16, 2010
    The needle bent and I changed the needle. have correct needle in position. Sews , no stiches. Seems like nothing is catching.
    Scholar:
  • 109 Answers
It can be a number of things so we'll check them all! First make sure when you re-thread it that your presser foot is up and that the thread goes between the tension discs in the front. (Pretend you are flossing and pull the thread back and forth and then pull it out to hear the click just to be sure you have it snuggly in the tension.) Next make sure your bobbin thread is in its tension slot. (You can do the same test as the top...pull it in the slot and pull it back out to make sure you hear the click.) Put a new needle in and make sure the flat side is to the back of the machine. If you do all of this and it still doesn't pick up the bobbin thread, most likely the machine timing is off and this is a repair to be done by an authorized dealer. It can be a result of: if you hit a pin or two, run over a very thick seam or pulled your fabric too tight because it wasn't moving under your presser foot. Do you remember your needle hitting the needle plate? When this happens because of any of the above examples, it causes the hook in the bobbin case to not line up with the needle when it comes down to pick up the thread so you don't get a stitch. I would call a repair center if none of the above suggestions worked and check and see how much it would cost. It could be anywhere from $50 to $150 depending on where you live or who you go to. I'll try to answer any other questions you have. I'm here until you're satisfied! Please let me know if I can be of any more help to you and let me know how you made out. Thank you for asking for me.
Posted on Sep 19, 2010
Missing stitches
Please check the stitch regulator and check the bobbin tension and winding or you check the thread put properly. Otherwise you go to mechanic shop.
Mar 01, 2014 | Bernina Activa 130
12 wt thread
12 wt thread generally will not work well in the bobbin...
"Aurifil 12wt Thread
Aurifil 12 wt thread is ideal for hand quilting, big stitch hand quilting and machine quilting. 12 weight thread creates a more defined and often primitive look. It's great for designs that use a longer stitch length if using a machine. When machine quilting with 12 wt thread, use 40 wt in the bobbin, increase your stitch length, lower your tension, use Topstitch size 90 needles and stitch slowly."
May 08, 2017 | Bernina Activa 140
Have a lockstitch elite for granddaughter, the top stitch looks correct but the bottom stitches are bunching up. What do I need to do?
Check for proper threading, check the pressure foot is down. and check to be sure the bobbin is in correctly. (some turn clockwise, other counterclockwise) check tensions (both upper AND bobbin tensions). These can all be causing
the "underthread" to bunch or tangle. good luck and happy sewing.
Jan 09, 2013 | Sewing Machines
Why won't my Bernina zig zag bobbin thread catch underneath; the top looks great.
have you tried changing the needle?
have you tried adjusting the top tension?
May 13, 2012 | Bernina Sewing Machines
Singer stylist 7258, will only pick up bobbin on one side when doing zigzag stitch
try using a washable stablizer or interfacing.
if that doesn't help then it's possible that a gear or cam may be worn enough to cause the machine zig zag not to work properly
Mar 27, 2012 | Singer 7258 Sewing Machine
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
I have a bernina activa 130 and when you turn the wheel to insert the needle into the fabric the needle breaks. I am not sure what to check.
Check that your needle is centred when straight-stitch is selected and / or that you have the correct stitch-plate fitted. Is the needle breaking because it is hitting the stitch-plate or is it breaking when the needle goes down through the slot/hole in the stitch-plate. If you are sewing zig/zag or patterns, you must have a slotted stitch-plate fitted. If it's breaking when the needle passes below the stitch-plate, then take the bobbin /bobbin case out and the hook/shuttle and see if it still happens. If it does, the timing on your machine may be out and need professional adjustment. If it doesn'y happen after removing just the bobbin case, make sure the bobbin case is being correctly fitted.
Sep 19, 2011 | Bernina Activa 130
Won't sew with foot dog down and using the freehand embroidery foot
Won't sew can mean more than one thing - the machine has no power or is seized up; the needle is not going up and down; the needle and bobbin are not forming a stitch.
When the feed dogs are down, you move the fabric by hand.
The presser foot has to be down to stitch.
If you wound a bobbin before you starting the sewing, did you disengage the bobbin winding feature(s)?
Mar 20, 2010 | Bernina Activa 140
Sewing machine not picking up bobbing stitch
MY 132 Q SINGER FEATHERWEIGHT SEWING MACHINE,
WON'T PICKUP THE BOBBIN STITCH
Feb 27, 2008 | Sewing Machines
Sewing Machines Logo
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
