Question about Home
My triton bezique shower is showing a fault with low pressure and is running cold, the water presure seems fine, what are the possible problems?
3 Suggested Answers
  • 44 Answers
SOURCE: triton electric shower runs cold
hi it sounds as though the thermostat has gone on top of the can assembly, or moreover it has scaled up & the element needs replacing, if thats the case your better off buying a new unit as the cost of the can assembly & the fitting it will be nearly as much, plus witha new unit you'll be getting a 2 yr guarantee?
Just a thought!
Posted on Dec 15, 2008
  • 122 Answers
SOURCE: low water pressure
When it was installed was there any copper sweating done? If so, the valve cartridge can get fried if not removed prior to the immense heat from a torch.
Posted on Jan 30, 2010
Triton showers after runs hot then after a while goes cold
Is it possible that you don't have enough water pressure, electric shower heater elements will cut out if the water pressure gets too low, try increasing the water flow.
Apr 13, 2014 | Kitchen Appliances - Others
On OpulenceTM SHOWER Trim Kit w/8incg Sunflower Showerhead, the water presure is too low on both hot & cold, seems like there isn't sufficent water to supply the 8inch head. the model number is 502057BNT....
Either this is a consequence of having a "low-flow" shower head, or the pipes are too small or have too many bends and elbows to support the flow rate required at 65 PSI for such a large shower head. What is the water pressure at the shower head fitting while the shower is running? It won't be 65 PSI, but it shouldn't be below the recommended inlet pressure for the unit.
Feb 26, 2018 | Danze Home
Triton t300si shower low pressure problem
there is a fine inlet filter on the plastic pipe,remove and wash under tap pressure
Feb 26, 2013 | Home
My triton shower won't turn off and has no hot water
Your supply pressure is too high for the unit, it is too much for the solenoid to shut off, you need to put a pressure limiting valve inline.
Mar 10, 2012 | Home
Triton t80si shower is very hot even on a low setting then fluctuates between hot & cold, pressure switch is not activating but pressure seems low any advise will be gratefully received.
If the water temp is fluctuating from very hot and cool the problem could lie with a blockage in the inlet to the shower, scale inside the heater can, shower hose needs replacing or the shower head needs to be cleaned The problem is a "slowing" of the water across the heating elements which causes the water to pick up too much heat
Jul 09, 2010 | Home
Shower keeps coming up with low pressure and water goes
think ur presure redusing velve [prv] is durty and ur hot and cold water is not balenced presure . the prv is 90% of time located in 1m radius on cold water seply to geyser look for a curtrage , unscrew clean out and put back. will fix the problem
Plz rate my advice
Jun 01, 2010 | Home
Triton electric shower T90si ran dry and not now working.
pump needs attention and the heating element has burnt out
pump needs water to run and the heater element needs water to keep it cool
Sep 07, 2017 | Heating & Cooling
Triton electric shower runs cold
Just a thought!
Dec 01, 2008 | Home
Home Logo
318 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
