Question about Fluidmaster & Fits-All Faucet Connector
Brand new 105c; water will not shut off when filling tank
    Filmmaker:
    Uploaded 5 video answers.
  • 119 Answers
Turn the water off. Remove r=the top section of the fill valve. Slowly turn the water on while holding a cup over the open end of the Fluid-master fill valve. This is to wash out any debris. Turn the water off. take the rubber seal out of the fill valve cap and wash it under warm water. Replace the seal and reinstall the cap. Slowly turn the water back on. If you still have problems after completing this task. Replace the rubber fill valve seal or the whole valve. I do not think the supply line is the main problem.
Posted on Sep 15, 2010
I have a 2000 Holiday Aluma Lite Travel Trailer. Having difficulty filling the water tank. There appears to be two places to hook up the hose to fill the tank. Which intake do I hook the hose up to?
There must be a water shut off valve between the tank and the water pump. One of those hook ups will be for city water that goes direct to your tap and the other inlet is to fill the on board tank. Again check for shut off valves.
Jun 12, 2017 | RVs
After a flush, water tank fills up but water will not shut off automatically, have to shut off the main water supply at the bottom of the toilet after each fill up.
There is a problem with your fill valve. The fill valve has a float connected to it, that rises up as the water level reaches its correct level, which then shuts off the water entering the tank.
Replace the fill valve. They run in the neighborhood of $10-15.
Feb 28, 2015 | Home
Toilet not flushing correctly :why does tank not fill so that it will flush
the fill valve is not letting water in you either have a float that raises up when water is full so when you flush the float drops down letting water in then when water raises it shuts off i would replace the float fill valve and corky flapper.... here is what you do .... first shut water off where it goes up to the tank....... flush commode to empty as much water from tank....... reach up under tank there is a plastic coupling that connects the water supply line to the bottom of the toilet tank...put a small pan under the shut off valve that goes to the toilet some water is going to drain from the tank when you take the coupling loose..... turn the coupling counter clockwise ( use a channel lock adjustable wrench to loosten then had turn) once this is loose you can pull the riser tube away from the tank...... now there is a plastic nut that screws the shaft to the bottom of the tank loosten with channel lock then remove with hand by turning counter clock wise ( you will get a bunch of water flowing down to the pan) remove the entire fill valve , replace with a fluidmaster fill valve ( about 8 bucks from big box store when you take the new fill valve out of the box there is a neopreme seal you must put on the new threaded shaft ( it has an inner ring you may have to punch out) once you put this on you can insert the entire shaft down through the hole in tank then secure with thin nut provided tighten but do not overtighten then put coupling back on,,,,,put the over flow tube on the tit of the fill valve and stick down into over flow ok thats done when you go to big box store purchas a 5 buck corky flapper (red caus it can handle chlorine water better) remove the old one at bottom of tank( just two clips to remove and chain attached to flush lever...install new one be shure chain does not have a lot of slack so it does not fall under flapper seal when you flush......OK YOU ARE DONE TURN WATER ON WATCH TANK FILL LOOK FOR LEAKS TAKE A TOWEL AND DRY ALL AREAS THEN TAKE YOUR HAND AND FEEL FOR LEAKS UNDER TANK AND DOWN TO SHUT OFF VALVE .....CONGRATS YOU DID IT!
Jul 31, 2014 | Kohler Home
Dehumidifier Does Not Shut Off
Switch it off when you go out. Find replacement float switch
May 15, 2012 | Dehumidifiers
We have an brand new Cimmaron two piece. It has only been in for a week. Twice the tank emptied compeltely on a flush and did not refill. We have to fill the tank manually to get things working. Once we do...
Sounds like the fill valve may have something stuck in the part that makes the water shut off. This can cause it not to refill as it doesn't let the inner mechanism work as it should. If your home is a little older and depending on the piping in the home it is possible in the change that some debris passed through the system when the water was turned on. Another possible issue is that when attaching the water to the tank the fill valve was turned to where the float for the mechanism is jammed against the side of the tank and is not moving freely with the water. If this is the case then the entire body of the fill valve will need to be twisted so the float can move freely. Aside from these things, you may want to simply replace the fill valve to avoid any further complications or issues. Don't worry, anyone can do it and is only about $10 to do. I recommend Fluidmaster brand, they come with really good instructions.
Aug 18, 2010 | Kohler Cimarron Comfort Height elongated...
How do I adjust tank fill valve to increase water level in toilet?
There are many different fill valves out there so it would be a little hard to tell you how to adjust your particular one without knowing the brand and type of the fill valve.
So I will give you a generic adjustment.
Look for someway/something to adjust your float in the toilet tank.
There should be a screw, moveable metal, something that will adjust your float.
Once you locate the adjustment, you can then adjust your water level in the toilet tank.
Adjust the water level in the toilet tank to be about a 1/4-1/2 inch before it flows out of the overflow tube when the water shuts off.
Good Luck, I hope this helped.
Please rate me, Thanks
Mar 11, 2010 | Home
How do you replace a fluidmaster 200A fill valve?
SHUT OFF WATER.REMOVE WATER FROM TANK.UNSCREW SUPPLY LINE NUT TO FILL VALVE, (UNDERNEATH TANK). UNSCREW FILL VALVE NUT FROM FILL VALVE, (UNDERNEATH TANK). REMOVE OLD FILL VALVE. INSTALL NEW VALVE IN REVERSE ORDER.
Dec 14, 2009 | Plumbing
WATER HEATER ELEMENT IS NOT WORKING NEED TO REPLACE IT.
is there one or two,, turn off power drain it down, use the water heater element wrench remove the wires and the element, install new element snug it tight, start filling the water heater while it is filling reinstall the wires, turn on a hot side faucet only let the air out, wait till you have a full flow of water out of the faucet then turn the power back on to the unit, the thermostat should beat 120 degrees,
Feb 21, 2009 | Select Brands 20012 500°F Heating...
Elec. hot water heater
thanks for your question, sounds to me like you have a burned out bottom element in the tank, depending on how old the tank is, the amount of calcium in the tank, will determine if you should repair or replace, if your tank is fairly new, then you will first have to shut the power off to the tank, turn the water off at the shut off, drain the tank, write down the model #, the serial #, what brand, and the ratings on the lower element too, go to the hardware store, buy a new element and element wrench, return home, write down which wire goes where on the element, very important ! remove wiring, remove element, that's the hard part most of the time, install the new element, rewire, close all panels, refill tank, do not turn the tank on before filling !! then after tank is full, turn power back on, you will have to wait about an hour for hot water, if the unit looks to old, then replace it. I would say anything over ten years is worth replacing, hope that helped ya, thanks again for your question, let us know what happens, mr.grzz
Jan 12, 2009 | Water Heaters
Fluidmaster & Fits-All Faucet Connector  Logo
162 people viewed this question
Top Fluidmaster Plumbing Experts
Mack Baxter
Andrew Bugbee
Tom Chichester
Are you a Fluidmaster Plumbing Expert? Answer questions, earn points and help others
