Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
My epson stylus sx 115 won't print. it keeps telling me ther's a "general error" no matter what I do. it tells me to remove any foreign objects from the printer and turn it back on. and there is nothing in the printer. what can I do?
SOURCE: epson stylus 1290 - machine locked up
You can download the repairer's manual for free from http://pcprinter.blogspot.com/2008/05/service-manual-for-epson-89012801290.html  which is where the solution below is listed (p.68).
Basically Epson want you (or, rather, a service centre which you'll have to pay!) to replace the waste ink pad every so many copies. However, you can reset the printer even without replacing anything by switching it off on the silver button, switching it on again whilst holding down the two black buttons alongside it, then releasing them all before quickly holding down just the left-hand black button for 10 seconds. You have only three seconds to do this after switching back on, whilst the green and red lights are flashing together. If you're not quick enough on the first try, switch off using the silver button and repeat the procedure!
Posted on Mar 07, 2009
SOURCE: My Epson Stylus DX5000 won't work.
i had the same problem and checked for paper jam but wasnt any so i kept turning on the printer while looking in side and found that one of the little white cogs where the ink box rests wasnt catching when i pushed it into place the printer set itself and started working maybe you could try this. good luck.
Posted on Apr 16, 2009
SOURCE: Remove any foreign objects from
Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes, turn the printer back on.
Posted on Feb 14, 2011
  • 80 Answers
SOURCE: my epson stylus t13 have
Hello there,
This is called a false paper jam. normally, a reset is required for this.
Hold the power button for 30 seconds and this should prompt a shut down.
next, make sure that the rollers are clean inside. use a lint free sloth and some distilled water. Dampen the cloth (Q-tips works fine too, please do not use cotton) and rub the rollers.
Then as it dires up. turn the printer on and do a test page.
Please don't forget to leave a feedback and testimony if it works.
Posted on Mar 12, 2011
SOURCE: my printer Epson t13 has
do you have a ciss t13 printer?.. coz if you have , then the problem is in your hose installation is short, if its not then your michanichal gear is broke,.. you have to bring it to its service center
Posted on May 24, 2011
General error L200, what is solution? I try to turn off and switch again...It Error again..
Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes, turn the printer back on. but not working printer.
Sep 30, 2012 | Epson L200 Original Continuous Ink Tank...
All lights flash on Epson stylus TX110
switch off the main power of printer in running situation and then on the printer.. hope it will be work..
Aug 20, 2012 | Epson Stylus Multifunction Inkjet Printer/...
General error remove foreign objects inside the printer
Getting General Error Messege delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer
Jun 08, 2011 | Computers & Internet
When the Epson C87 stylus printer is about to print, it makes a high pitched scream and doesn't print. The 2 left hand red lights flash quickly and simultaneously and the green light does not show. The...
Hi
I think maybe it could be that your ink cartages are slipped on the thin belt that moves them from one side to another or it stuck or belt come off take a look and see it the ink will slid from side to side you can do this by hand but don’t push them to hard, that what it sounds like to me it worth a try.
All Best: Pineworks
Jan 24, 2010 | Epson Stylus photo C87 InkJet Printer
General error Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes%2C turn the printer back on.
general error Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes%2C turn the printer back on.
Nov 24, 2009 | Epson Stylus Photo R300 InkJet Printer
My Epson Stylus DX5000 won't work. All the lights are flashing and my comouter tells me to open it up and remove the "foreign" object. I can't see any foreign object and can't see hoe t open it up other...
Feb 22, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Both red lights on my printer are blinking
Blinking wit general error message : head carriage error. It cause by head cannot move to parking position or chip at ink tank not good connected. Try to use another chip. Just turn off printer for a moment for clearing epprom.
Nov 09, 2008 | Epson Stylus C83 InkJet Printer
Foreign object
It appears as though the printer hardware itself is malfunctioning and will require service.
Apr 06, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
1,258 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
