Question about Rankin-Delux Bronzetone Patio Heater
Won't ignite. Bad thermo couple? - Rankin-Delux Bronzetone Patio Heater
  • 32 Answers
May be a propane problem,low or out,or tank ,try changing the tank
Posted on Sep 16, 2010
Bosch Confort S 13 BP tankless water heater won't ignite, It clicks but no gas going thru valve
The S 13 BP is a simple unit that does not have a pilot light. It uses electronic ignition on demand, which is what you hear clicking. If there is no gas going through and you've verified there is gas to the inlet, then it has to be the gas control valve.
Feb 01, 2013 | Bosch & Tankless LP Hot Water Heater
Tip
Gas Hot Water Tank Not Producing Hot Water Pilot will not stay lit Trying to...
Trying to light your pilot light and it keeps going out when you turn on you gas valve. This is a common problem when your thermo-couple goes out. The thermo-couple sends a small electrical charge to the gas valve to keep its self lit. When the unit calls for heat the pilot flame gets bigger producing more electric and tells the gas valve to open the main gas valve to the burner tubes. The thermo-couple is an easy item to change most of the time. You will need to follow these steps to change out your thermo-couple:
1. Turn off the gas (there is an inline shut off on the supply line before it reaches the gas valve, you need to turn this crossways to the pipe)
2. Locate the thermo-couple it will look like this and be attached to the gas valve
3. Unscrew the thermo-couple from the gas valve
4. Remove the other end of the thermo-couple from the pilot holder
5. Measure or take the old thermo-couple to the hardware or appliance store with you to get the proper length (there are many different lengths of thermo-couples)
6. Reinstall the bulb end at the pilot
7. Reinstall the threaded end on the Gas Valve (make sure not to cross thread the thermo-couple it should start by hand)
8. Turn the gas valve to the pilot position and hold down the red button wait a few seconds then turn off and do again (you will need to do this around 5 times in order to get the gas back up to the pilot light then try and light the pilot)
9. Try to ignite the pilot light.
10. Once you get the pilot light lit you will want to hold down the button for 60 seconds then turn the gas valve to the on position.
Here is an image of a thermo-couple (they will all look similar to this):
Thank you for choosing FixYa.com. If you have any further questions please post them and we will gladly answer them
Justin
on May 03, 2011 | Plumbing
We can't get our Dometic fridge to light when it's turned to gas. Model number 2453. It works on AC and DC but just won't light at all on gas. The gas will light but won't stay lit in the...
If you are lighting the pilot corectly and waiting for the thermo couple to warm up and then setting it to on, then the thermo couple is probably bad. Good luck!
Jun 27, 2011 | Refrigerators
Wont stay burning if you let off ignition button
this could be a bad thermo coupling -- try and hold down the gas button for about 15 to 20 seconds while it is running and then let go and see if it stays running ( the thermo coupling needs to reach the proper temp ) -- if it shuts down after that then replace the coupling and all should be good.
c...
Feb 02, 2011 | Scheu (BG150T) Heater
Smeg gas hobs ignite immediately but flame goes out when i let go of the igniter. I have to hold it down for a very long time befor it stays alight. this is time consuming and not right. What is the...
depending on what you mean by " a very long time " -- holding down the gas valve button while the thermo-coupling gets up to the proper temperature is normal. ( normal hold and wait time should be between 10 to 25 seconds, anything longer than that is a sign that the thermo-coupling is bad ).
c...
Jan 02, 2011 | Microwave Ovens
I have a rheem fury 50gal gas water heater that will not stay on. I have replaced the thermo couple, it did lite but then went out.
I would like to know how old this heater is. This information can be found on either model or serial numbers.It won't appear obvious but last six numbers will tell you. You have already changed thermo-couple so I would check to see that it's properly centered in pilot flame.When you light it hold pilot button down for two-three mins.while watching thermo-couple.It should be a nice cherry red. If it is and pilot goes out after you release button then you either have another bad thermo-couple or gas valve is bad.If it does not get cherry red at least on tip then you need to reposition thermo-couple and try again. If gas valve is bad and heater is less then six years old valve will be covered under warrenty,however labor won't typically be covered unless you have extened service contract.Hope this helps.Thanks.
Nov 03, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Goodman gmp125-5 burners ignite, then shut off after about 5 sec
One of two problems are happening here, your flame sensor is bad, your thermo pile or thermo couple is bad, or last is that the cap on the flue is blocking the exhaust from escaping
Feb 08, 2009 | Goodman GDS80904BNA Open Flame Heater
Pilot light is out of our coleman 7900 mobile home furnace and we can't get it re-ignited
The thermo couple or the gas valve itself is most likely bad. Cheap enough to start with the thermo couple.
Sep 04, 2008 | Coleman Heating & Cooling
Motorcaravan fridge auto-igniter continues to flash even when fridge has lit but the gas flame ,visible through small glass in the inside rear of the fridge remains constant.Usually a do-it-myselfer i am...
Yes the problem has been solved by cleaning jet and repositioning thermo-couple so that it is well into the flame.It would therefore appear that the combination of a partially blocked gas jet and a badly aligned thermo-couple triggered the auto-igniter .
Thanks for your interest,.......I am afraid that at my age now help has to come free of charge.A new auto-igniter would have been £69 and a thermo-couple £35.A new jet was a reasonable £6...........
Regards Iain edwards g4wrk@talktalk.net
Apr 29, 2008 | Electrolux Refrigerators
Rankin-Delux Bronzetone Patio Heater Logo
55 people viewed this question
Top Rankin-Delux Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rankin-Delux Heating and Cooling Expert? Answer questions, earn points and help others
