Question about Saeco Royal Cappuccino Espresso Machine
In the programing, the is a menu called "system 2". What is that? The menu Rinsing is missing.
How do I erase missed calls.
Go into the call log menu and delete them.
Sep 28, 2016 | Panasonic KX-TGE433B DECT 6.0 Expandable...
Error 1317.Setup cannot create the folder__C:\ProgramData\Microsoft\Windows\Start Menu. Verify that the path exists in your system and that you have sufficient permissions to update it._
Follow the path in the error message above by going to start, then computer , then C: then find the folder named "ProgramData" and in that folder find another folder named "Microsoft" and in that folder find one called "Windows" and in that folder find one called "Start Menu" . You will be missing one of these folders most likely the Start Menu folder when you find the one you do not have , create a new folder with the name of the missing folder in the correct folder that it is listed in in the error message. Now try to install the program agian. If that dosent work than you may have some how deleated some folders. If you cannot install then you need to insert you operating system install disk and choose reapire or you could also try a system restore to a time when your computer was working correctly. Then try to install office agian. Also office has a installation troubleshooter that may be able to fix it for you I would try that before a system restore or repair.
Dec 19, 2012 | Microsoft Office Professional 2007 Full...
How do I eliminate "# of missed calls" from screen on handsets?
# 1: Press menu
# 2: Down arrow to call log
# 3: Press menu
# 4: Down arrow to to Delete all calls
# 5: Press menu
# 6: Question appears; Delete all calls?
# 7: Press menu
Let me know if this answered your question.
Master FixYa....saailer@att.net
Dec 04, 2009 | Panasonic KX-TG1033S Cordless Phone
My internet explorer icon is missing on the desktop and im using windows xp
Is this the only icon that is missing?
If so, find the folder C:\Program Files\Internet Explorer (assuming you have drive "C" as your main drive). You should find a file called "iexplore.exe". If you're viewing the folder with "Tiles" as your view option, you should recognize the internet explorer logo on this file.
When you find the file, right-click on the icon, and select "Send To" from the drop down menu. Another menu should appear, and from there, select the "Desktop (create shortcut)" option. This should put the icon back on your desktop.
Hope that helps.
Dec 02, 2009 | Microsoft Computers & Internet
Missing Calls and Texts. Alarm Caput.
Cause:-
Call logging is not enabled for the Message list.
Ensure call logging is enabled from the Phone application Options menu.
1) From the Home screen, open the Phone application.
2) Display the menu and select Options.
3) Select Call Logging.
4) In the Show these call log types in message list field, select the type of call log to be displayed in the messages list.
5) Display the menu and select Save.
I hope I was able to help you.
Nov 23, 2009 | RIM BlackBerry Pearl 8100
Things in the internet option is missing
Hi ,
Hope you have virus in your system
Download a free antivirus program such as avast or avg , and update it and run a full system scan. For Internet explorer issue reset the internet explorer setting to default one.
If this is not resolved your problem , Format you hard disk.
Thanks
Siju
Aug 28, 2009 | Microsoft Windows XP Home Edition
Illustrator CS2 menu problem
system fonts and adobe fonts not installed properly
Mar 09, 2009 | Adobe Illustrator CS2 for Mac
System software missing
BEFORE you connect the Garmin to your computer you must download the free Garmin program on your computer called UPDATER. Did you do that?
If not:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To download the latest unit software visit Garmin website: www.garmin.com/webupdater AFTER installing WebUpdater once from the Garmin website, perform all future software updates from your computer. Simply connect your compatible Garmin device to your computer, then run WebUpdater from your computer's "Start Menu" by selecting "Start", "Programs", "Garmin", and finally "WebUpdater"
Normal 0 false false false MicrosoftInternetExplorer4 REMEMBER: It takes hours to do a complete a map update.
Unless you bought the Lifetime maps you may have to pay for current maps.
Does this help? Let us know. Thanks.
Dec 26, 2008 | Garmin nuvi 260W GPS Receiver
How to view the call log
Call log depends on what system you have the phone connected to. In an 824 it requires 2 buttons and has to be system log, since personal doesn't show missed calls IIRC. These 2 buttons are CID Indication and CID Selection. They are functions 96 and 97 in programming and I usually put them as the top 2 buttons on my button strip.
In addition, there are some extra programming steps to make it work on your extension, but if the steps above work, it's already done. If it doesn't work, please comment back with your phone system model number and I''ll give you more specific instructions.
Carl
Dec 20, 2008 | Panasonic KX-T7735 Corded Phone
Saeco Royal Cappuccino Espresso Machine Logo
26 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
