Question about Crate Music
I have a crate fxt 120. I 'll be playing in the #2 overdrive channel and it will automatically fail and go to a clean sound. Although it is not entirely clean. It sounds like 2 sounds combined. A loud clean and a low volume distortion. I'll tweak the "shape" knob, it will correct itself and revert back to the overdriven tone. This fix is only temporary because it will eventually happen again, 5-10 minutes later while I'm playing. How can I fix it from switching on me?
  • Crate Master
  • 5,603 Answers
A possible problem MIGHT be marginal switch contacts on the external foot controller cable. If you are not using the foot pedal, these contacts must maintain contact to keep the same channel selected.
Posted on Sep 16, 2010
  • 1 more comment
  • kianicockett Sep 17, 2010
    Thanks for the reply but I'm hard of understanding. This problem happens with or without the footswitch plugged in. How can I "maintain contact to keep the same channel selected?" It seems to be acting up in the left area of the control panel. When I tweak the input cable, shape knob, or either gain knob, the problem will correct itself temporarily. what to do?
  • Fred Yearian Sep 17, 2010
    The contacts on some of the jacks on these amps are really weak. These contacts default the signals to the channel selection switches when foot controller is not in and send the signals through the foot controller if plugged in. The signals are digital and if they don't have good contact to either the footswitch or the bypass the channel may change. The nature of these are slight vibration of the cabinet or circuit board when plugging in a cable can temporarily fix the problem.
    The problem ALSO may be bad soldering around these connectors which is fairly common. If a cable has been jerked by tripping over it, these jacks sustain damage easily.
    I would open up the unit and do a visual inspection around all the jacks and also pins from volume controls where they solder to the board.
    If you want to attempt a DIY repair, remove the amp from the cabinet. With a small soldering iron, retouch all the soldering of the 1/4 inch jacks and the controls. Also check if the contacts have sufficient contact pressure.
  • kianicockett Sep 20, 2010
    Thanks for the explanation. It seems that something is loose. I'm going to operate on it tonight
I have a crate vtx200s has very little volume everything else works whats the deal?
Hi, you hadnt mentioned how long you've had the amp, or how new it is, so I'm going to assume it's new to you. The Crate VTX200 has 3 channels, each with its own volume level. Let's check the simple things first:
1. Check to make sure you're adjusting the same volume knob volume knob to the same channel. The active channel will be lit with a green light.
2. Check the cables from the "Speaker Out" jacks on the amp (if you are using them). Are they plugged in all the way, or are they damaged?
3. Are you playing through a preset that you may have accidentally made "low", and may not be aware of or are stuck in it?
If none of these answers helps, there might be a problem with the input buffer in the circuit or possibly within the damping circuit of the speakers. I'd advise having the amp serviced to confirm an internal electrical problem also. If you don't have a manual for the amp, one can be found here:
http://www.manualguru.com/crate-amplifiers/vtx200/users-manual
Jan 22, 2016 | Crate Music
There is a lot of feedback on both distortions . Crate FXT 120
it may be your instrument. if not try turning your pre-gain down some.
Aug 16, 2014 | Music
Sound fades.
Did you try a new 9 volt battery?
Feb 22, 2014 | Marshall Amplification Marshall MS-2 Mini...
I have a Crate CR212 it started to hum/buzz today. It would not play out any sounds other than the noise. I unplugged everything and still it hummed. I unplugged the unit, check the fuse and replugged and...
Are all the tubes lighting up? they should glow like dim light bulbs. If not, replace them with the same model type (12ax7, or EL34 for example).
Often there are two fuses, one to protect the speaker and another to protect everything, it sounds like the latter fuse may be burned out. take it out and take it to radio Shack for exact replacement.
Oct 12, 2013 | Crate Music
Crate flexwave 120 head effects malfunctioning
That is probably a momentary switch that is dirty and sticking. These onboard effects on guitar amps are usually nothing more than a computer sound card and I've found bad connections going to and from them as well. I do think that switch is dirty and sticking, though.
Feb 19, 2013 | Crate FlexWave FW120H Guitar Amp Head with...
Crate flexwave 120 tuner and all effects stoped working
Hi there,I have the same problem with my flexwave 120. I opened the amp to measure several capacitors on the small effect circuit board. If one of this capaciters have internal short circuit, wich will effect the others causing effects to fail. I removed them one by one to find possible short circuit. All capacitors were ok. I think the problem is in the processor wich is to diffucult to replace. I think it's easier to replace the effects circuit board. But where do we find this board??10_29_2011_6_25_35_am.jpg
Aug 07, 2011 | Crate Flexwave Fw120h 120 Watt Head Dsp...
Sound is shorting out...its not the cable that I am using I have no trouble with it in any other amp. The overdrive channel does not work at all. And randomly all the effects will just decide they want to...
It sounds like the DSP processor is either about to go out, or is mostly there. Have a qualified amplifier technician take a look at the DSP. Also look up the cost of a new one.
Hope that helps!
Feb 12, 2011 | Crate Flexwave Fw120h 120 Watt Head Dsp...
Deville 212 overdrive channel making Loud humming noise
It sounds like a filter capacitor(s) has failed. The electrolytic caps dry out and cease to perform allowing unfiltered power to reach the preamp sections and get amplified.
Being this is tube with high voltages, an experienced person should work on it due to shock danger.
I assume you checked the tubes for shorts as well as emission since a heater to cathode short could cause this as well.
Sep 30, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Crate flexwave 120 head sound cuts out
You have a broken solder joint. You'll have to disassemble the amp enough to get at the soldered side of the circuit board that the controls are mounted to and touch up any suspect solder joints. Just be sure to resolder only the joints that were originally soldered or need to be soldered. Hope this helps.
Jun 07, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Music Logo
286 people viewed this question
Top Crate Music Experts
rjivaro
Michial Gueffroy
Ben Armstrong
Are you a Crate Music Expert? Answer questions, earn points and help others
