Question about Sport & Outdoor - Others
When I raise the cross hairs on the scope on the graft the bullet goes down and when i lower the cross hairs the bullet goes up is this correct. When I bought my pursuit boar sight from Basspro I only received a very small paper of instructions .Can you help
    President:
  • 1,514 Answers
That is right. If you had the rifle held in a vice aimed at a particular point and without moving the rifle you raised the cross hairs you would now be aiming above the point. To get your aim back onto the same spot you would have to loosen the vice and lower the barrel of the rifle. This would mean that the next shot would hit the target lower down. The same is true if you lower the crosshairs which means the bullet would rise.
Likewise moving the crosshairs to the left brings your shot to the right and moving them right brings your shot to the left.
Posted on Sep 15, 2010
Why will my crosshair not raise up and down on my leopers scope
The cross hair is located in an erector tube and will not move in your view even when the point of impact moves.
May 08, 2013 | Optics
Which direction do you turn windage and elevation
To raise the point of impact, turn the elevation screw counterclockwise. To shift left, turn windage screw clockwise. If you raise the horizontal cross hair you will lower the point of impact of the bullet. If you move the vertical cross hair to the right the shot placement will go to the left. Make small adjustments tap the scope with a screwdriver handle to give it a shock, not to hard to help move the cross hairs and try to bore sight first. Hope this helps Fix ya up.
Jun 22, 2011 | Tasco 22 Riflescope
My bsa sweet 17 6-18 is shooting about 2 inches high at 100 yards. on the adjustment turret it has an arrow that shows which way to turn for up. What is moving up? the point of impact relative to the...
Jun 02, 2011 | Bsa Optics Sweet 17 Target Riflescope...
Hi I sighted inmy rifle today with a Ziess Conquest scope. When i needed to bring the point if impact up . The impact moved down instead. I turned the scope turret to the right like the markings on the...
I hate those 'direction' arrows. I usually end up ignoring the arrows and moving it however it takes to get what I want.
Raising the crosshairs will cause you to have to point lower to make the round hit on target.
Oct 12, 2017 | Zeiss CONQUEST 3-9X40 MATTE Z PLEX
Scope will not bore site. when cranking scope left it goes right, when cranking scope down it goes up. when goes other directions it runs out of adjustment before reaching barrel sight line by 2" in...
The sighting sounds about right to me meaning to you need to adjust the cross hairs i the opposite direction to where your point of aim is. If your sight is off 1/4 inch to the left you need to bring the barrel to the right to compensate and that's what the bore scope/site is doing. Think opposite and you'll have that tuned in a few seconds. I don't doubt that you have the correct mounting hardware BUT, it's from center bore to center scope what 2 inches so at 25'? Depending on what caliber I'd say at 25' you need to hold 2 inches high for center target. I'll just guess that you might not be able to get a zero until say about 25 yards with a 22 short. A larger bore/caliber will extend this out to possibly 100 yards.
I'm going to give you a link to a bullet trajectory chart so you can sort of see what it is I'm trying to write. you may need to cut and past this in your browser window.
http://www.chuckhawks.com/rifle_trajectory_table.htm
Here is another chart that shows a bullet drop from the muzzle.
http://www.chuckhawks.com/bullet_trajectory.htm
Hope this was a help have fun and be safe
Dec 30, 2010 | Tasco Optics
When I turn the turrets they go in the reverse direction, WHY
To raise the point of impact, turn the elevation screw counterclockwise. To shift left, turn windage screw clockwise. If you raise the horizontal cross hair you will lower the point of impact of the bullet. If you move the vertical cross hair to the right the shot placement will go to the left. Thats just the way it works. Point your right index finger at a spot on the wall, and sight down your finger like looking at sights, then take your left index finger and pretend it is a horizontal cross hair above your shooting finger, then raise your left finger a set amount above the right, then move your hands back to the shooting position not changing the distance in between, using your left finger now as the sight. You will see your shooting finger is now pointing lower than before. This is now the new point of impact, lower not higher. Hope this is clear as mud and helps Fix Ya up.
Dec 30, 2010 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
How to use the BDC on my rifle scope
  1. Step 1 Take a rifle with a properly installed BDC bullet drop compensating reticle to a rifle range. Using ear protection zero the scope reticle so that the point of impact corresponds to the center of the cross hairs at the distance you have selected - typically 100 or 200 yds.
  2. Step 2 Determine the trajectory of the specific cartridge you have selected. There are several ways to do this. Ammo manufacturers publish trajectory and wind drift information. There are web based ballistic calculators like http://www.biggameinfo.com/BalCalc.aspx which will tell you how much your bullet drops at known distances.
  3. Step 3 Scope manufacturers like Leupold can be a valuable source of information about their reticle: "Leupold® Ballistic Aiming System: Boone and Crockett Club® Big Game Reticle aiming system provides a series of additional aiming points to improve your ability to shoot accurately at longer ranges. Nikon2_bing.gif also provides good information suggesting the marks on their reticle be used for zero at 100yds followed by circles below representing 200, 300, 400 and 500 yds if the cartridge travels around 2800 ft per sec. Nikon suggests the center cross hair be zeroed at 200 yds for magnum calibers traveling around 3000 ft per sec. We understant that each variation of different bullet weight and powder charge changes trajectory and a scope manufacturer can not build a different reticle for each different cartridge made so practice on the range to determine how well the marks relate to the actual impact of where your bullet strikes at a know distance is important. The one thing that people using BDC scopes typically have problems with is that a BDC scope has the reticle in the second focal plane of the scope. If the reticle was in the first focal plane of the scope the reticle would look smaller on low powers like 3x and grow proportionately larger as the power increased to say 9x top power. The problem is that while the marks on the BDC reticle correspond accurately to the bullet drop at the know distances 200, 300yds etc. What happens when you lower the power from the scopes maximum power to any other lower power is the reticle stays the same size and the field of view within the scope increases which means that the distance between these marks on the BDC reticle no longer corresponds to the point where the bullet will strike. In short BDC reticles only work at the maximum power of the scope or at a set specific power. At all other powers these BDC reticles do not accurately represent where the bullet will strike.
  4. Step 4 The center X always remains the same. If you zero at 100 yards and you know that your bullet drops 8 inches at 300 yards you could forget about the BDC marks and hold the center X 8 inches high - that works at any power 3x or 9x and should be used at lower powers. If you zero the center crosshair at 100yds and have the BDC scope at the maximum power 9X then the first line or circle below the center X should be the mark you place on the center of the 200 yard target----- the bullet strike should hit the center. If by some chance you put the scope on 3x and placed that first mark below the center cross hair on that 200 yard target you would shoot over the top of the target. This is because as the power of the scope decreases the field of view increases the angle increase and gets wider. You can experiment with known power settings and see at a specific power say 3x what that first circle down corresponds to and make notes because at any set power what the marks correspond to will be repeatable.
I got this from a website, hope it helps.
Apr 08, 2010 | Hammers Air Gun Rifle Scope 3-7x20 With...
Will my scope remain zeroed at different distances?
You need to look at your bullet ballistics, Most guns should shoot dead on at say 15 - 17 yards out, to be on center at 100. Line of sight is straight the bullet must go over the line of sight to come back down and cross again so far out -- make sense? So no you will be a little high at 100 but may be close at 130 - 150. Ck on line for your ballistics with the bullet manufacture.
Jun 26, 2009 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
Tasco propoint PDP2 scope
Are you looking set the eye relief or the focus ring?
For eye relief you need to loosen the scope in the rings, mount the rifle to your shoulder with your standard hold and cheek weld. At this point, slide the scope back and forth in the rings until you obtain a full field of view. Tighten one of the rings slightly, dismount and remount the rifle several times to ensure correct adjustment. Level scope and tighten rings a final time.
For focus adjustment (remember that you are using the eyepiece to focus on the cross hair, not your target!) loosen the lock ring and turn the eyepiece until the cross hair is focused. It is best if you check it several times by closing and opening your eye several times. The crosshair should be instantly in focus. If your eye must adjust, then you need to refocus until the focus is instant.
The two dials on the scope are for adjusting the bullet point of impact. They will typically move POI 1/4 inch at 100 yards.
Nov 08, 2007 | Optics
Sport & Outdoor - Others Logo
83 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
