Question about Black & Decker Black Decker 16" Hedge Trimmer
B & d 16" hedge trimmer motor runs, but blades do not move
5 Suggested Answers
boscia
  • 163 Answers
SOURCE: Black and Decker 16 in Hedge Trimmer
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Posted on Nov 28, 2008
  • 634 Answers
SOURCE: My B & D electric hedge trimmer blades are frozen
spray liberally with wd40, let side and hour spray rag with wd40 and clean blades and look for any bent teeth in blade that maybe binding them as u clean use pliers and screwdriver to move if any found, it is likely that wither sap dried or rust formed and is creating too much friction for blades to move wd40 will help free up blades
Posted on Jul 09, 2009
  • 18 Answers
SOURCE: Black & Decker Hedge Hog 24-Inch Hedge
You can definitely pick up a sheer pin for that model. I know ereplacementparts.com has them usually pretty discounted, or just check out a local store, but make sure they are in stock.
Posted on Apr 29, 2010
  • 5 Answers
SOURCE: homelite hedge trimmer , motor runs but blades do
Had the same problem: when I turn on the trimmer, the motor would hum but the blades won't move.
What I did:
1. Sprayed a ton of wd40 between the blades
2. Took a screwdriver and kinda wedged it between the blades to get them unstuck. Also removed some guck between the blades.
And it worked!
Posted on Jun 09, 2010
B&D Hedge Trimmer (HT33) was working yesterday but not today. Motor sounds fine & the blades move back & forth ... just not cutting any foliage ... any ideas?
Mechanical issue. Make sure that the screw that holds the moving blades up against the non moving blade is adjusted properly. If loose, the blades will not be close together during the cutting stroke and no cutting will ensue.
Jul 05, 2015 | Garden
Gas hedge trimmer blade locked up motor runs find
look for a bad nick in the teeth and file or grind it off smooth
Sep 16, 2014 | Poulan Pro PP2822 22-Inch 28cc 2 Cycle Gas...
Hi! There is power to the unit....the blades don't move.
What I did:
And it worked!
Jun 08, 2010 | Black & Decker Hedge Hog 20-Inch 2.8-AMP...
My Black and Decker hedge trimmer's blades won't move, but smoke and a burning smell comes from the motor. Can it be fixed? How much would it cost?
Your blades are stuck together.
What I did:
And it worked!
May 30, 2010 | Black & Decker Hedge Hog 20-Inch 2.8-AMP...
Homelite hedge trimmer , motor runs but blades do
What I did:
And it worked!
May 16, 2010 | Homelite Factory Reconditioned 26cc...
Black & Decker Hedge Hog 24-Inch Hedge Trimmer. Motor runs, but blades don't move. Is there a sheer pin that I can replace, or is the thing bound for the dump?
Apr 27, 2010 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
Describe your Black & Decker Hedge Hog
You may have a piece of metal between the moving blade and the stationary one. Also the motor may have been at the top of the stroke when it stopped. You may be able to "force" the blade to move a little. This may free it enough to work.
Jul 14, 2009 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
Jul 09, 2009 | Black & Decker Black Decker 16" Hedge...
Hedge trimmer blade not moving
I have a Troy-Bilt gas powered hedge trimmer. My blades would not move. After tearing it apart, I found that there were some spacers under the 5 or 6 screws along the blades. These spacers are steel and designed so that you don't overtighten the screws. However, around those steel spacers, there is a teflon type material that makes the oval shape of the slot. That teflon had fallen apart and lodged so that the blades would not move. I removed the teflon and put the spacers back in and it now works fine. There is a little play between the spacer and the edge of the slot and it will probably eventually wear out but at least I got a few more cuttings off of it.
Jul 04, 2009 | Black & Decker Black Decker 16" Hedge...
Black & Decker Black Decker 16" Hedge Trimmer Logo
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
