Have never seen filter completely blocked your pump may be running but fuel not making it out of tank there is a line from pump to top of hanger unit that may have ruptured the pump is down in tank and it has lines going to top where the fuel lines connect i would remove fuel tank take out the pump unit and inspect
I would check the fuel pressure regulator, as it my be faulty as well. You can check the pressure on the fuel pump to see if it is up to specs. Any Autozone can tell you what the specs should be and also loan you the equipment to check it yourself! You will have to leave a deposit, but it is completely refundable!
