Question about Hoover Vacuums
Was vacuuming fine and suddenly the thing won't turn on. Tried another plug.
  • 4 Answers
Same thing happened to my Wertheim 4030. It turned out to be a broken connection in the retractable cord plug, no doubt due to continual shock upon retraction. How did I find it? By pulling the top off and first checking the internal switch was working with an ohmmeter (definitely no power for this test) Then plugged in, powered up & checked if any power to switch with AC voltage tester(be careful and have unit RCD protected for your safety) None showing, so checked if power at internal reel. None, so switched off power and checked continuity of cord for active and neutral continuity. None in one so cut off plug and checked again OK so new plug fitted and reassembled. If I had power to the switch originally, the motherboard/rheostat or motor may have been the problem. Hot wiring the motor would have determined which(unlikely to be both but a possibility) Repair or replace faulty item, obviously checking motor brushes first. Electrical is simply a matter of isolation and elimination.
rjjs
Posted on May 17, 2008
My Oreck Xl was working. Turned it off to do other stuff. But the next few minutes whne I turned it on, it didn't turn on. But why?
You've probably tried all this but humor me, check the plug to make sure it's not loose, make sure the terminals at least feel like they're tight and still connected, the walk down the cord (unplugged), hand over hand to make sure there aren't any bulges or shallow feeling spots showing a problem in the wiring.
I would guess there is a fair amount of problems with the foot switch, but I don't know this, after plugging back in, slap the switch with your hand vigorously a few times, if corrosion or a fault is present, this might wake it up, at least give you an idea of where to head next if it tries to run.
Is your cord still retracting as normal?
HTH!!
Feb 28, 2015 | Oreck BB2000 XL Little Hero Canister...
Vacuum was working fine one day, next day it won't come on
You can try doing this first, plug it in to your outlet and switch it on. If it will not start, try to move the wire near the plug to see if the problem is a lose wire in that area. If it responds in moving the wire you have to replace the plug of your vacuum. Message me if you need further assistance. Thanks..
Jul 22, 2012 | Vacuums
My Oreck vacuum cleane won't turn on
I have an Oreck vacuum. My son used it just earlier today and it worked just fine, then just a little while ago a tried to turn it on to vacuum our bedroom and suddenly it won't turn on! I tried plugging it into other outlets but it was no use. My husband takes a look at it and first thinks that the switch is out in it. He takes the handle apart and quickly realizes that it is not the switch that is causing the problem. Then he took the base of the vacuum apart, removes the spin brush part and cleans it off, puts it back together, and suddenly it works! He said that when those brushes get real dirty the motor gets clogged, then it just won't turn on. I'm just happy I married someone who can figure these things out, because even if I knew the problem I'm still no good with a screwdriver, taking things apart and putting them back together again. Hope this works for your Oreck too and it's running again for you soon.
Jun 18, 2010 | Oreck XL2200 Bagged Upright Vacuum
Vacuum won't turn on when plugged in and switch is turned on
The easy answer to this problem is you need a new cord. Any fit all 20 to 35 foot two wire cord will work. However, you will need to take disassemble the almost the entire vacuum to test the current cord to see if it is bad. There are a lot of pieces to take off to get to the inside of the vacuum where the cord enters from the back. You could also have a bad motor.
Nov 18, 2009 | Hoover U6311-930 Power Drive Bagged...
I was vacuuming then all of a sudden the vac turned off and wont go back on. i thought the bag might be full so i emptied it and still it wont go back on
Greetings from GoVacuum.com,
There maybe several things wrong with the vacuum at this point. When a vacuum cleaner doesn't turn on, it usually is 1 of several things. It's either a reset button on the machine, the cord, the plug, the switch or the motor. One of these things have gone bad in your machine.
If you'd be so kind as to let me know your make and model, I can help you diagnosis the vacuum to find out what went bad.
Please email me your make and model to chris.jones@govacuum.com
Chris Jones
GoVacuum.com
Oct 15, 2008 | Vacuums
Will not turn on
Your problem is probably a bad male cord end or the there is a problem with the cord winder. It might need a spacer.
Aug 16, 2007 | Miele S251i Plus Bagged Canister Vacuum
there is an overheat stat which turns motor off. possible cause is filters blocked or a blockage elsewhere - no air flow and the motor overheats
Mar 26, 2007 | Bosch Cyclone Jet Upright Vacuum
Vacuums Logo
432 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
