Question about Fender Hot Rod Deluxe Guitar Combo Amplifier
My Fender Hot Rod Deville reverb is not working. What should I look for in trying to fix this problem
    Sergeant:
  • 336 Answers
Make sure the in and out is correct on the reverb chamber., if someone else disconnected it at any time it could be plugged in backwards and act just like that.
Posted on Mar 08, 2013
    New Friend:
  • 17 Answers
There are two coils in the reverb unit which use delicate wires which can break off - these can easily be checked, as follows:-
i) Remove one cable plug from the reverb unit & substitute an uncapped phono plug to the socket.Then check that there is electrical resistance across the plug terminals.
ii) Reconnect original phono plug & do same test as i) to the other socket.
iii) If either is open-circuited, then look for a break in the lead-out wires from the corresponding coil inside the reverb unit.
This break may be repaired (contact me for details) or buy a new reverb unit!
iv) If there is electrical resistance at both sockets of reverb unit, then clean both original phono plugs & try the system again.
Posted on Feb 22, 2011
FENDER
What does 'it does not work correctly' mean? The reverb? Low sound? Hums?
Jun 14, 2014 | Fender Hot Rod Deluxe Guitar Combo...
Is there a way to make the sound of the reverb on my deville 2-12 sound better ?
modding the reverb takes some electronics experience...if you know where the reverb circuit is. all you can really do is change the input caps that make the tone bright or dull... larger uf for dull... lower cap values for bright... it's in the signal circuits... dont mess with power caps. The schematic shows op amp into the tank and out of the tank to another op amp...Output of the tank to opamp.. Id double that input cap ( 330 pf ) to see if you get more response into the opamp... then look at the circuit C17-C18/R33-R34 894cf4a0-46f7-4f21-9667-be620f05b31d.png
Jun 06, 2012 | Fender R) Hot Rod DeVille III 212 Guitar...
Sometimes the reverb works, then next day it dont.i have a 1999fender hot rod deluxe
Fender Amplifiers are notorious for their reliability issues.However, I'm sure that amp will sound sweet once you get everything working again!
The problem is likely your "tank". The tank contains the springs which create reverb as the guitar's signal is sent through them. A broken spring could be causing your problem.
Luckily, any of the larger music stores should have them avalible.
Good Luck!
-Sheeves
Mar 02, 2011 | Fender Hot Rod Deluxe Guitar Combo...
My reverb on my Fender deluxe Hot rod amp has stopped working. What is wrong?
Your reverb spring is most likely broken. If it has electronic reverb, then the chip has gone out. For both of these problems, a qualified amplifier technician will have to look at it and replace the parts.
Hope that helps!
Feb 13, 2011 | Fender Hot Rod Deluxe Guitar Combo...
How do i connect the boss gt 10 to a fender blues deluxe amp and bypass the amps preamp
You can plug the output of the gt10 into the "power amp in" jack of the Fender. This bypasses the preamps in the Fender but uses a buffer amps in the Fender to drive the power amp. Please note that the reverb is STILL in the circuit when you do this. You can turn the reverb to zero if you wish to disable it.
Jun 09, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Fix Reverb unit on Fender Hot-Rod Deluxe Amp
Could have broken a spring in the reverb tank, or a wire connecting it to the amp, or the reverb driver tube, or a few other things, but those are the most likely in this situation. Thats what I'd check first. Give it a little slap and if it vibrates like normal, your spring is probably ok, you can still open it up and double check though. Check your wires. Then pull your reverb driver tube and replace it. If that doesn't work, it is probably in the circuit somewhere, and you should not work on your amp unless you know what you are doing. They store large amounts of electicity in the caps and they can kill you.
Apr 24, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Reverb wont work !!!!!!! Hot rod deville 410
probably a bad reverb tank. there is a little inductor inside that shorts out easily/common. you cant repair it. its just easier to order a new tank. what you do to test is........turn on the amp with the reverb turned up all the way........ volume up on the amp at normal playing level.....then tap or knock on the reverb tank itself......if you get sound then the output of the tank is good/ no sound the ouput side is dead.......then what you do is unplug the ouput of the tank and plug the output wire to the input of the tank and tap/knock on it again....if you get sound then the input side of the tank is good/ no sound is dead. this is a way to test the tank independently from input to output. which side is bad is irrelevant, what is improtant is determining if the tank is toast. i can get accutronics tanks from my distributor at a better price than anywhere else. email me thru my contact page on my website with the tank code numbers and letters so i can get you a price also check my price with whats on ebay, etc. my website is yostamplifier.com
good luck
Feb 07, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Hot Rod Deville, reverb squeal...
Here is an article that might help:http://www.guitarplayer.com/article/reverb-troubleshooting/jun-09/97165 Here is the schematic:http://www.fender.com/support/amp_schematics/pdfs/Hot_Rod_DeVille_Schematic.pdf Check to see if someone hasn't reversed the input and output cables at the reverb tank. Then troubleshoot the reverb section .
Aug 28, 2009 | Fender Hot Rod Deluxe Guitar Combo...
I have a Fender Hot Rod Deluxe. It has very few
First try turning the volume control down before turning switch to operate.
IF this seems to fix it, IF the unit has a tank reverb, the vibration of the reverb springs MAY be causing the problem. The solution then is to reduce the volume before applying power WHICH is a good idea anyway... from an electrical engineer.
Jul 24, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Fender Hot Rod Deluxe Guitar Combo Amplifier  Logo
772 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Matthew Spark
Matthew Spark
Are you a Fender Music Expert? Answer questions, earn points and help others
