Vertical hold problem - Televison & Video
  • wintra69 Jun 14, 2008
    Hello, I have a philips 64" projection and the vertical hold does not work on it any info on how to fix it would be great. model number 9P6444C101
    Thanks.
  • Phantoms Jan 23, 2009
    I have a Toshiba model 42H83 HD projection TV. When I use the "touch focus" button on my front panel the vertical lines waver the horizontal lines are good. The other problem I'm having is the video 3 inputs on the front panel don't always work. I would appreciate any ideas on fixing these problems.
    Thank you Phantoms
  • 8,617 Answers
I will need the model number of your set, in order to even begin to make a suggestion as to what the cause of your vertical sync loss may be. Please post the model number.
Posted on May 17, 2008
Troubleshooting
If the vertical hold control have no effect, and can't stop vertical rolling, the vertical oscillator side should be checked. Check the hold control too, if any.
Jul 01, 2013 | RCA E13700 13" TV
Tv32d60
No vertical hold adjustment available. Vertical hold is controlled by a chip in the unit and from what you indicate, it is "out" on the unit. A tech can remedy your problem, "if" you can find out who is like me who took engineering along with being a tech (now retired)
Aug 27, 2012 | Toshiba Televison & Video
Vertical hold
no modern set has a vertical hold control, last ones were nearly 40 years ago. what is set doing or not doing?
May 21, 2012 | Acer AT4220B 42 in. LCD TV
Where is the vertical hold button
This set has no vertical hold control---is picture rolling left right or up down?
Mar 10, 2012 | Hitachi 57F500 57" Rear Projection...
I have lines like vertical hold is off but can't find ajustment
Thank you to "TheScreenGuy". He replied with an answer that says the vertical sync is automatic and that I need to replace the SSB. Thanks!!!
Mar 23, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Brother Model Pt-65
There are two vertical fonts - small and normal. To put the labeler into vertical mode, hold down the [Code] key and tap the [J] key.
When it asks " 1-9 ", let go of the [Code] key.
Press the [8] key if you want small vertical type, OR the [9] key if you want normal size vertical type. Then you have to hit the [ <--' ] enter key.
Now you are stuck in Vertical mode ! :-O
To get back to normal, hold down the [Code] key and tap the [J] key, Let go of the [Code] key.
Then tap the [3] key and the enter [<--'] key. You are back to horizontal labelling.
:-) phew!
May 26, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Vertical hold on tv
no control over the remote..but impossible not to have vertical hold control in the TV itself. it should have one maybe at the back.
Apr 07, 2008 | Audiovox AVT-1475 13" TV
Maybe sync separator transistor is faulty
Dec 22, 2007 | Zenith C32A26 32" TV
Vertical hold not working
on mitsubishi just replace the caps that are near the vertical ic this will fix the problem good luck
Nov 02, 2007 | Mitsubishi WT-46805 46" Rear Projection...
Quasar 32" TV VERTICAL HOLD
well most of the modern tv today doesnt have vertical hold anymore. this symptom is caused by a trouble in the IC integrated circuit or the vertical oscillator circuit. let the service guy do the job if u dont know anything about this. good luck!
Feb 02, 2007 | Quasar SP-3235 32" TV
Televison & Video Logo
181 people viewed this question
Top Televison & Video Experts
