Question about Garden
Need wiring diagram for 1988 Lawn boy YT16 electric PTO
nova2nv
  • 197 Answers
SOURCE: Need help finding the PTO and the solenoid in a
PTO on tis machine is located inside of trasmission,switch on dash.Solenoid/coil is located on rear of trans at the top.When energized the coil magnetically moves a valve inside of trans an allows high pressure fluid to engage clutch.In 15 years with Deere I only had too replace 2 solenoids and no clutches.
Posted on Nov 13, 2009
SOURCE: Black and Decker Electric Lawn Mower MM850 wiring diagram
There is a solution for this problem at another website, the link is
http://www.ridgidforum.com/forum/showthread.php?t=8535
check it out and good luck
Posted on Mar 26, 2008
  • 246 Answers
SOURCE: I need an electrical diagram of the snapper lawn tractor
Hello:
Try this Site Addy;
>>You can View a Breakdown of the Mower at this Site Addy; http://www.snapper.com/manuals/ . Enter your Model Numbers in the Box Provided and Click Find Manuals. Select Illustrated Parts List from the Manual List Provided. Now Download the Manual for Online Viewing.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 26, 2009
wireguy212
  • 1627 Answers
SOURCE: ELECTRICAL PROBLEM
Can't get you a diagram but i can tell you most electical problems on these tractors can be solved by replaceing the key switch/modual or cleaning corrosion from fuse holders.
Posted on Nov 10, 2009
wireguy212
  • 1627 Answers
SOURCE: Need wiring schematic diagram for JD L130 lawn
You should price a new wiring harness,around $80 so there is not much reason to spend a lot of time trying to find shorts or open wiring.
Posted on Apr 18, 2010
I need a diagram of a John Deere 420 lawn and garden motor where the pto is located
most likely under the motor and it is an electric clutch pto
Apr 11, 2018 | John Deere Garden
I need a wiring diagram for a 1986 -1988 toyota automatic 4x4 pickup
You can get them from an auto parts store such as auto zone, pep boys, etc
Apr 03, 2015 | Toyota Cars & Trucks
Wiring diagram diagrams
I just rewired my 782. same wiring as the 682.
All the electrical to the Engine coil runs through the PTO switch. Not sure what your issue is but that's a big failure point
http://www.ihcubcadet.com/diagrams/Electrical%20Schematics.pdf
http://www.ihcubcadet.com/cgi-bin/discus/board-auth.pl?file=/217125/217125.html&lm=1291234823
Jul 29, 2014 | Cub Cadet Garden
Bay boy czt. Lawn mower battery draining problems
if you have an electric PTO ( blade clutch ) you need no less than a 450 cranking amp battery...
you didn't mention the engine but I am assuming it has a B&S v twin ??? check and make sure you have battery voltage at the red wire at the voltage regulator... if yes, suspect it's bad, if not, look for a blown fuse
May 15, 2014 | Garden
What does PTO stand for
power take off which drives the belt that runs the mower deck sounds like a dead short in the pto clutch maybe a wire shorting out check for bare wires
Apr 17, 2014 | Cub Cadet Lawn Mower Electric PTO Clutch...
When we engage the pto switch, on our Ford YT16 42" cut, the mower deck does not operate. Is this a pto switch issue, clutch issue, or something else? How do we fix it?
Could be the switch. This model may also have a relay I'm not sure because of the age. There is also a seat switch that has to be made for the PTO to work. I f you have a 12V tester, with tractor off, disconnect wire from the PTO. Start motor, have an assistant sit on seat and turn on PTO test wire for voltage. If none present, then trace wire back, to either the switch or relay. There also should be a fuse in the circuit. By the way these were cool tractors.
Aug 18, 2010 | Ford Garden
I have a John Deere l130 and the mower blades engage when I start the engine even when the PTO switch is off. Any suggestions?
sounds like you have feed going directly from switch as soon as you turn ingition to start mode ?
check wiring back from electric clutch to main switch
possible 2 wires have been placed on main switch instead of pto switch ?
or you have a crossed circuit somewhere (that is feed from another live circuit) not directly connected and its ended up at electric clutch as soon as you liven main circuit
a wiring diagram may help
check with www.johndeere.com
or www.jdparts and enter their site load your model and type
and go to electrical system and print out a copy of wiring diagarm
you may need to supply and user name and apply for password from john deere via their site apply on line
its a good site for info and parts diagrams
cheers hope it helps
paul
Aug 05, 2010 | John Deere Pto Clutch For Stx38 And Stx46...
Electric pto will not engage the mowing deck. stopped working while mowing.
had a similar problem. The engine mount bolt that grounded the PTO black ground wire was loose- causing the pto to work erratically. To see this bolt (13mm i think) you will have to lie on your back and look under the machine. It is above the front steering arm of the right tire. If the wire is dangling you will need a new bolt. Thanks for the previous posts ;)
Aug 01, 2010 | John Deere Pto Clutch For Stx38 And Stx46...
I need an electrical wiring diagram
New Holland bought out Ford's lawn equipment division. You can contact your local New Holland dealer and purchase a manual for you lawn mower. The manual includes wiring diagrams. Or you can order a manual from New Holland online via this link https://www.newhollandtechpubs.com/. Hope this solves your headache.
Mar 30, 2009 | Ford Garden
Garden Logo
166 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
