Question about Sony KDS-R60XBR1 60" Projection HDTV
Red light blinking 5 times. is a fan problem on a sony KDS-R60XBR1
    Sergeant:
  • 171 Answers
Here are the fans you need are you sure this is the problem
http://www.discount-merchant.com/SONY-Cooling-Fan-Set-Cooling-Fan-Set-p/1158984.htm
Posted on Sep 15, 2010
3 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: replacing the exhaust fan on a KDS-R60XBR1
4 times blink shows problem of fans not running or connector of fan is not attached properly.
Please recheck the things what you removed during fan replacement and make sure all that is mounted and connected securely.
Posted on Feb 13, 2009
SOURCE: KDS R60XBR1 Red Light blinks 3 times when turning
on my xbr tv there is a little *** that sticks out on the lamp cover. the wrapped and it wont work light flashed 3 time with a new cover it worked fine. there was a t. s. b. for an over heat problem new fan and sensor and door. go to sony.com its there
Posted on Mar 31, 2009
Fuse replacement for KDS-R60XBR1
The info does not tell what is wrong---set has more than one fuse and if dead the set may still have lights on the front that light or blink (red one) in a specific sequence--5 blinks, pause and 5 blink etc.
A bit more info is needed to assist you.
Nov 08, 2012 | Sony KDS-R60XBR1 60" Projection HDTV
Red standby blinkig light 4 time on a sony 60 in wega
4 Blink 9 out of 10 times is your lamp fan. Check and make sure it clean and free of debrey. Spin it and see if there is any grinding noise. If after you clean and reassemble and the set still shuts down, either replace the lamp fan or check your outher 3 fans as well.
Apr 26, 2012 | Sony KDS-R60XBR1 60" Projection HDTV
What do i do if my sony sxrd power light starts blinking red
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly
Jun 17, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Sony tv red light blink 4 times on 60" WEGA
When your red light blinks four times on the Sony KDS-R60XBR1 60 inch HDTV, this is an error code for a stopped up fan. You will need to check the ASU board to verify Fan1-4 power to the fan is supplied, next check the fan connector to make sure it is properly connected, and finally make sure the fan is not caught in the wires or harness.
Feb 27, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Hi! GREAT site! We have a Sony SXRD KDS-R60XBR1 Projection TV and it stopped working last night... We are getting FIVE red blinks! What does that mean? Fans, bulbs.... ??? Thank you in advance for any...
5 blinks if for the ballast that powers the light. You can try changing the bulb first, if that doesn't fix it then I believ it will be your ballast. If you haven't changed the bulb before It could probably use one anyway, and you could keep the old for a spare.
Here are some more from sony on this.
According to Sony:
Red LED Flashing four(4) times
o Fan not plugged in
o Foreign object hitting blades
o CN2301 on ASU board not seated or connected
o ASU shield touching S1 board
Red LED Flashing five(5) times
o Interconnect harness from Lamp driver 5-pin to ASU 9-pin board not connected
o Lamp driver failure
o Bent pin on Lamp driver 5-pin connector
o DSU to C board harness not locked
o CN6501 on G board not seated or connected
o Lamp failure
Jan 29, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
KDS-R60XBR1 red light blinks four times when turning on
Replaced fan. Big one in the back p# 883586011 motor,dc sff21c/c-np. the four blinks indicate fan power is nt supplied (ASU board) , fan connector is loose, wires caught in fan ,fan stopped turning.
May 02, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Mar 22, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Replacing the exhaust fan on a KDS-R60XBR1
Feb 13, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
Sony KDS-R60XBR1 60" Projection HDTV Logo
583 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
