Question about Belkin (F5D5231-4) Router
My brother accidently reset my belkin router and now i am having trouble connecting to the internet....ive tried unplugging everythin and plugging it back in but have had no luck
  • 550 Answers
You will need to reconfigure the router.
Once you reset the router, it will come back to the factory default settings. Now you can reinstall the router.
You can do it manually without the CD also.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Posted on Sep 16, 2010
Tip
Wireless Network Reset - Belkin
If you are unable to connect your laptop wireless to your <b>Belkin</b> wireless access point/router, the <b>easiest</b> and<b> fastest</b> way to get going is to reset your router to the factory defaults. This will make your router work like the day you bought it.<br /><br /><br /><br /><b>Reset your router:</b><b><br /></b><br /> <ul> <li><b>Unplug</b> your <i>DSL/Cable</i> <b>modem</b> from power (not your access point/router) Leave this unplugged for now</li></ul><br /><br />Next <ul> <li>On the rear of your<b> Belkin router </b>you will find a small RESET button</li> <li>With the power still on the router,<b> Press</b> and<b> hold</b> (with a pin/pen tip) the <b>RESET</b> button for 10 seconds.</li> <li><b>Release</b> the RESET button a wait 15 seconds for the router to reboot</li></ul><br /><br />almost done.... <ul> <li><b>Unplug</b> your <b>Belkin</b> router from power</li> <li><b>Plug</b> your DSL/Cable <b>modem</b> back in to <b>power</b></li> <li><b>Wait </b>1 minute for the modem to boot up</li> <li>Be sure the ethernet (cat5) cable from your <i>modem</i> is securely plugged into the <b>WAN port</b> on the back of your Linksys <i>router.</i> This is usually labeled <i>WAN</i> or<i> Internet</i> above the jack</li> <li><b>Plug</b> your Belkin <b>router</b> back into power.</li></ul><br /><br />You will now be able to connect to the internet with your wireless device. I would advise that you follow the next steps in securing your wireless network.<br /><br /><b><br /></b><i><b><br /></b></i><i><br /></i>Magoo
on Mar 13, 2011 | Computers & Internet
My belkin router n3000 stopped working out of the blue , internet connection shows up but no internet
Try recycling the router by unplugging it then after 20 seconds plug it back in. See if you can stay connected. If not, unplug the modem and the router, then plug the modem in and let it cycle up for about a minute or two, then plug the router in and let it cycle up.
If you turn your computer and router off at night, then when you turn them back on, if the router boots up before the modem, it will have connection problems. A power outage in the house causes the same thing if the router cycles up before the modem.
Jun 08, 2012 | Belkin Wireless Surf Router (F7D2301)
Router connection fail
do you have internet with the modem? if you do then router is not configure correctly. If you do nothave internet ask you ISP why you are not online with the modem directly.
Sep 11, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Belkin 54G won't connect to the internet
Are you sure your modem is giving a WAN IP from your ISP? Try power-cycling your modem with your router unplugged then bring up your router next, if you havent tried that already... After that try connecting your modem directly to a PC and set your NIC card to DHCP and see if you get an IP address thats routable to the internet (i.e not a private IP)
Mar 27, 2009 | Belkin Computers & Internet
I unplugged the cable connected to my desktop and the wireless function stopped working
You must always have a 'host' adaptor whether you want a LAN or a WAN. Go to your configuration utility or control panel via your Run command to set or view your options. Steve Medley
Nov 07, 2008 | Belkin (F5D8231-4) Wireless Router...
Belkin router not working
Are there no leds when you power up the router? If there are no leds make sure the 110 volt circuit the router is plugged into is not tripped. If you have leds try holding in the reset button on the back of the router with a paperclip the botton is a small hole located by the internet/wlan port, hold for 10-15 seconds this resets the router to factory defaults. BPCS
Dec 28, 2007 | Computers & Internet
Belkin F6d3230-4 No internet
Since this has happened to you in the past, my first suggestion would be to purchase another router.. I would recommend moving to a Linksys Brand (made by Cisco), since I believe it is a much better grade consumer router...
But, you might try resetting it back to its original configuration by pressing the 'reset' button for more than 30 seconds, then plugging it back into the LAN..
Another thing you could try is to install updated Firmware for the router... Firmware is usually available from the manufacture's site...
That being said, I will say that I have had issues with Belkin's in the past, and no longer suggest them to my customers.
Dec 04, 2007 | Belkin (F6D3230-4) Router (F6D32304)
Actiontc cable/dsl router
please be clear , which model you are using , post some info here
Nov 15, 2007 | Computers & Internet
Help
Replace the router.
Aug 04, 2007 | Belkin (F5D7231UK4) Wireless Router
Belkin (F5D5231-4) Router Logo
139 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
