Question about Mastercool 67680 Evaporative Cooler Air Conditioner
I need an owners manual for my master cool. Can you help. Also, what size motor pulley is required for a 3/4 horse motor and a 1 horse motor?
  • 455 Answers
Hello You need the SHAFT diamater size on the motor.And they have an ADJUSTABLE pulley to set.Bring the old one if possible.
Posted on Sep 16, 2010
OWNERS manual for an 1989 Cruise Air 3 JUST BOUGHT THIS MOTOR HOME AND DONT HAVE ONE
Georgie Boy Owner Manuals Download And Printed - Manuals Ink
https://manualsink.com/georgie-boy-camping-owners-manuals.aspx
  1. Cached
Results 1 - 50 of 86 - 1977 Georgie Boy Cruise Air Motorhome Owners Manual · More Info ... 1989 Georgie Boy Motor Homes Owners Manual · More Info ... 1992 Georgie Boy Cruise Air III and Cruise Master Motor Homes Owners Manual.
1989 Georgie Boy Cruise Air III battery question - RV-Coach
www.rv-coach.com > Discussion Forum > Newbie RVers
  1. Cached
Re: 1989 Georgie Boy Cruise Air III battery question, Rudy S. Muguerza, 2-6-11. Hi, planning on ... Need to purchase owners manual for 1989 Cruise Air III.
[PDF]Georgie Boy Cruise Air and Encounter 1994 Owner's Manual
www.georgieboyclub.com/wp-content/uploads/.../1994_georgie_boy_rv_manual.pdf
  1. Cached
3. The above steps are suggested because of our sincere belief that your dealer will satisfactorily handle any problem which might arise. Should you find it ...
[PDF]Georgie Boy Pursuit 1993 Owner's Manual - Georgie Boy Owners Club
www.georgieboyclub.com/wp-content/uploads/.../1993_georgie_boy_rv_manual.pdf
  1. Cached
69950 M-62 . EDWARD BURG MICHIGAN 49112 . PHONE. (3. INC. (616) as ... Keep this Owner's Manual, the Chassis Operator's. Manual, and your Owner's ... ******* and Cruise Master motor homes are covered in .... Front and Rear Air.
Manuals - 1989 & older - RVing-The Midwest Connection
www.rvingthemidwestconnection.com/manuals1989older.htm
  1. Cached
  2. Similar
I need an owner's manual for 1989 Georgia Boy Cruise Master Motorhome. ..... heater air conditioning tandem axels shower/tub heater Rick & Sue (3-7-15).
GBM CRUISE AIR III OWNER'S MANUAL Pdf Download. - ManualsLib
www.manualslib.com > Brands > GBM Manuals > Motorhomes > cruise air iii
  1. Cached
View and Download GBM Cruise air iii owner's manual online. Cruise air iii Motorhomes pdf manual download.
manual for an 1989 Cruise Air 3 Google Search
Oct 31, 2016 | Cars & Trucks
Will an electric motor with more horsepower and more rpm hurt a compressor pump?
Electric motors seem to turn around 1125 rpm or 3600 rpm. The pulley size on the motor and pump must be adjusted to achieve the desired result without overheating /loading the motor. I have seen pumps turning from 800 to 1200 rpm using different pulley size on motor, motor hp and motor rpm. Some brands will turn same pump from 1200 to 3600 rpm depending on if was electric or gas motor. This will certainly shorten the life of the pump but will most likely work. Most turn an average of 1200 rpm for good balance of long life and good supply of air. Pump rpm is usually limited to the power of the motor. Cost effective match of 1.5 hp motor will turn pump about 1000 - 1200 rpm for about 5cfm. Rol Air 2hp motor turns 2 cyl pump about 1100 rpm for 10 cfm. Good luck
Mar 17, 2015 | Campbell Hausfeld Tank Air Compressor, 1...
I have an Ingersoll Rand Type 30 air compressor. Model #234. I was given this unit because the motor had gone bad. I would like to replace the motor and use it but I was not given the bad motor with the...
One dealer for your model compressor is Northern. They are very good at replacement parts. If you do not have 3 phase power, you could shop around for 5 to 7 hp 220 v motor making sure that the motor mount will align with your plate. Pully size depends on dia. of pulley on the pump. Most pumps turn between 550 min to 1100 rpm depending on the power available and cfm requirements. Most motors turn at 1725 rpm so for example if your compressor has a 14 in. pulley then you motor will need a 5 in. pulley to turn it about 620 rpm. The larger the pulley at the motor the higher cfm produced but more amps used. Motor speed x pulley dia. divided by compressor pulley dia. To obtain more efficiency and highest cfm you will need 3 phase. Good place to see motors and two piece pulley combnations is www.grainger.com. Good luck
Sep 25, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
I need to find out what size belt for tine engagement on a Dayton 5hp Tiller model # 32885 C144B
a simple way to figure out the length is to engage the tine mechanism and take a string and wrap it around the pulleys mark it and take it to any belt store, and buy the Belt you need. You will need to know if it's a 3/8s or 1/2 inch drive belt. Normally tine belts are half inch or 5/8 wide on a 5 horse power motor, You can get these belts at sears or Nappa auto parts store. hope this helps.
Mar 19, 2010 | Garden
How can i get more cfm out of a saylor beall 703 pump. The 705 look exactly the same to me but put out 3 times the cfm. I am guessing it is the same pump just bored out or maybe stroked with a bigger motor...
The 703 has bore sizes of 3 1/2 and 1 7/8 inch with a 3 1/2 inch stroke, the 705 has bore sizes of 4 1/2 and 2 1/8 inch and stroke of 3 1/2 inches. I am also sending you a link to the cut sheets for each pump. How they determine that a 705 is used for 3 H.P. is to turn the pump at 540 rpm and at 5 H.P. it is turning at 845 rpm. this all depends on motor rpm and motor pulley diameter to get the correct ratio of rpm and horse power at the pump.
703 cut sheet link;
http://www.saylor-beall.com/userfiles/file/Cut%20Sheets/703%20Cut%20Sheet.pdf
705 cut sheet link;
http://www.saylor-beall.com/userfiles/file/Cut%20Sheets/705%20Cut%20Sheet.pdf
Mar 03, 2010 | Cfm Air Tools & Compressors
What horse power is required for producing 16.9 CFM at 100 psi or what horsepower is required to produce 16 CFM at 175 psi We have an air dual stage air compressor and need to find a motor to fit that will...
You are looking for about 5 H.P. to do that, but what is more important is the r.p.m. of the motor, the size of the pulley,,, and the size of the compressor pulley! most manufactures will spec the pump for certain horse power,,, they go hand in hand,,, for example you cannot take a pump designed for 5 H.P. and hook a 10 H.P. motor and a bigger pulley on it and spin the pump faster to make more air,,, it wont take that high of speed,,, I hope this helps.
Feb 25, 2010 | Campbell Hausfeld Air Tools & Compressors
I have a engine on my sawbench which is rated at 3000 r.p,m thepulley on the output is 6 ins .what size pulley do i need on the saw to make it turn at 800 r.p.m.
The RPM's of the motor x the size of the pulley (3000rpm x 6inchs = 18000) = the output RPM's of the drive x the size of the pulley (in this case 800rpm x D ) Diameter would = 22.5 inchs.
Basically:
3000 X 6 / 800 = 22.5
You will have to change the pulley size on the motor to a smaller pulley. A 2" pulley on your motor would require a 7.5" pulley on your drive. Or you could use two belts to reduce the size of the pulleys even more. If you halve the RPMs to 1600 first from the 2" pulley you would need a 3.75" pulley followed by another belt hooked up to a 4" pulley to get your 800rpm. Hope this helps.
Oct 01, 2009 | Saws
Motor pulley for an old Ingersoll Rand type 30 compressor
Here is a link to Ingersoll-Rand (compressed air division) where you can find a local distributor. I think a call to a parts tech might provide the original motor sheave outside diameter and belt size (I'm suspecting "A" or "B" size).
http://www.ingersollrandproducts.com/contact/air/index.aspx
With that info, here is a link to a good industrial source for your new motor sheave (McMaster-Carr):
http://www.mcmaster.com/#v-belt-sheaves/=3fwz7b
Their prices aren't so bad.
You may also have a local industrial sales in your area.
I hope this helps you... Nice compressor!
Sep 01, 2009 | Ingersoll Rand Type 30 Fully Packaged Ir...
Towing capacity of a Ford 250 5.8 L engine
Towing capacity for any vehicle depends on the engine size along with tire size. the towing capacity should be on the ID tag on the driver's side door and will also be in the owner's manual.
Mar 12, 2009 | 1990 Ford F150
What size a step pulley required for the motor ?
rpm_chart.jpg?t=1236890602
here is the chart you need to answer your question. please mark this as a fixya! thanks
Mar 08, 2009 | Saws
Mastercool 67680 Evaporative Cooler Air Conditioner Logo
217 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
acrman404a
Level 1 Expert
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
