Question about Lexmark X2500 All-In-One Printer
It not pulling papper threw to print - Lexmark X2500 All-In-One Printer
    Genius:
  • 1,478 Answers
First, clean the roller on your printer, if after cleaning the roller, the problem still persist. Remove the rear access door. Off to the left near the feeder roller you will see a spring. Move the spring to the END of the plastic arm that it is attached to, If you have moved your printer around a bit, the spring may have slipped down on to the arm and is no longer sitting at the end. This will extend the spring another 1/16 of an inch, with that in place, your printer should pull paper through.
Take care.
Posted on Sep 15, 2010
Load fhoto papper to printer
Well the glossy side goes down, the dull side lays up. It gets pulled in and rotated then printed on,I think that's what u are asking for?
Feb 20, 2015 | Cannon Office Equipment & Supplies
Cannot print card stock from samsung sl-m2820dw tray
your paper type is not missmaching the printer papper in sencer please try to correct fill the papper in to the papper sncer liver
Mar 07, 2014 | Samsung Office Equipment & Supplies
Incomming fax same page printing contenusly and wasting paper
put machine oil on papper roller let run a few pappers intell it gets worked in then see if paper is sticking if this doesnt work blow it out with air in can there has to be papper jamming the papper side.
Feb 13, 2011 | Ricoh 3310Le Fax Machine, FAX3310Le...
Papper got stuck . spongy peace 9"x1/2" came out ,
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Nov 04, 2010 | Canon PIXMA MP530 All-In-One InkJet...
My printer pulls the papper half way to print and then it sound if it was printing but the papper doesn't move i already restarted it unistall the program n reinstall and it still does the same thing
check paper path with test print
right click printer icon go to properties click test print
can you see and remove the jam in paper path Check rollers for slick coating on them they are soft rubber and can get glazed so to speak
remove all parts that you can including paper drawer recheck the paper slot adjustments
sounds simple fix just recheck the paper path for jam or glazed rollers
1 Question ??no error message ?
Jun 11, 2010 | Lexmark Office Equipment & Supplies
Printing papper two sida is no quality
check quality of paper,printer settings, and the toner, these are usually responsible
Mar 29, 2010 | HP LaserJet 1600 Printer
Papper locked in laser printer.
check the back of printer there is a door to remove jammed papers. open it it should flip down and you can easily remove the paper. but switch off the printer before removing paper.
Mar 25, 2009 | Brother HL-2040 Laser Printer
PRINTER JAM
look for small, small pice off papper in the printer where pappers pass tru
Sep 29, 2008 | Dell 1720dn Laser Printer
The top lights stays blinking and printer will not print
Yes definetly,
First cheak that paper was cuts wrincled from any side from top or bottom, after pulling if yes cheak that the
small part of papper jam in to the papper path or sensor earia
or papper feed out sensor actuater arm jam by pulling the papper by you after cheaking those things you will able to solve the problem you are facing,
vyas
Mar 23, 2008 | HP DeskJet 5550 InkJet Printer
Lexmark X2500 All-In-One Printer Logo
22 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
