Question about Slendertone Fortex
Hi, my belt keeps beeping and a triangle keeps flashing. i'd be very greatful if you could tell me why this is. thank you.
2 Suggested Answers
  • 1116 Answers
SOURCE: I just replaced the pads
Triangle error code denotes a pad contact problem.
These are the solutions for this error:
The triangle symbol has appeared on the LCD*
Pads not covering metal stud
Pads are worn
Pads on wrong way around
Liners still on the pads
Reposition pads
Contact your local distributor for new Slendertone pads
Ensure black surface of pad is facing you
Ensure liners are removed from both sides of the pads
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Posted on Jun 02, 2011
Haier dishwasher HDW9WHT beeps 5 times and won't wash what is wrong with it can I fix it or should I get someone in
7 results (0.54 seconds) Search Results
    Haier HDW100WH / HDW100SS - ProductReview.com.au
    www.productreview.com.au > ... > Dishwashers > Freestanding > Haier
    Rating: 1.7 - ‎30 votes
    Haier HDW100WH / HDW100SS: 30 customer reviews on Australia's largest ... 1.7 out of 5 stars for Haier HDW100WH / HDW100SS in Freestanding Dishwashers. ... I putthis review in to do my part for what I think is a great consumer service you ... it it keeps beeping 10 times telling me doors open??and won't begin cycle.
    Haier Dishwasher Error Fault Codes - Lights Flashing ...
    removeandreplace.com/.../haier-dishwasher-error-fault-codes-lights-flash...
    Dec 21, 2015 - Haier dishwasher error codes - flashing lights - beeping ...Dishwasher keep filling water and draining at the same time ... Fix Washing Machine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note 5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The Refrigerator ...
    Dishwasher Has Beeping Sounds Blinking Lights - How To ...
    removeandreplace.com/.../dishwasher-has-beeping-sounds-blinking-light...
    Dec 21, 2015 - At times your dishwasher may need to be reset. ... Haier DishwasherError Fault Codes - Lights Flashing Beeping Sounds My Haier ... Fix WashingMachine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The ...
    How to Troubleshoot & Repair a Dishwasher ' HomeTips
    www.hometips.com/repair-fix/dishwasher.html
Jan 19, 2016 | Haier Dishwashers
What does a flashing Red triangle mean?
TCO means that the tachograph does not work properly. Because the european legislation is very strict regarding the malfunction of the tachograph system, the truck manufacturers alert the driver about his critical situation with a warning sign, the red triangle that flashes.
Apr 16, 2014 | Bruder MAN TGA Container Service Truck
Yellow triangle with ! in middle popped up on dashboard what does that mean
Hi there:
this is the ESP warning triangle and is normal , what this is is when the wheels start to slip even very slightly the triangle will flash , if you look at your switches on the dash there will be one that says ESP off , if you press this the triangle comes on solid , press again and it goes out.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Mar 04, 2012 | 2001 Mercedes-Benz C-Class
My 1998 Dodge Caravan will periodically beep four times in succession while driving. Does anyone what this indicates? Thanks
There are a number of things that can cause this beeping to happen. Problems in the Air Bag system, Seat Belts, Low Fuel, door or trunk Ajar, Low Washer fluid, Parking Brake on, Going too fast, Turn Signal On, Key-In Ignition, Exterior Lamps ON, Warning Lamp Announcement, or Transmission Over Temperature. You can try the self test to see if there are any codes stored in the computer, if needed.
1. Cycle the ignition key On - Off - On - Off - On within 5 seconds.
2. Count the number of times the Engine light flashes. The number of flashes represents the code. There is a slight pause between the flashes representing the first and second digits of the code. All codes are 2 digits. There are longer pauses separate individual two digit trouble codes.
Jul 20, 2011 | 1998 Dodge Caravan
Yellow light keeps flashing underneath triangle- Error code 6480. Please advise what this means? many thanks
There is a thin (1/4"wide) plastic strip running across the width in front of and below the drive belt. This is part of the optical encoder that tells the print-head where it is. If you look closely, there are fine black vertical lines on this strip. If the strip gets a piece of crud on it, you get an error during the start-up sequence. Gently clean this strip with a damp lint-free tissue. This also will fix a gap in the printing running lengthwise (not across the page like a clogged head).
Mar 09, 2011 | Canon MX700 Office All-In-One InkJet...
My slendertone belt keeps beeping with a triangle next to it. I can't turn up the intensity and it won't vibrate but I'm not sure why. What's the problem?
I just replaced new pads but that triangle still appear. Can't really do anything with the belt right now. Really frustrating.
Feb 18, 2011 | Slendertone Fortex
Fault on Zanussi FS1455W
why should i tell you how i solved the problem????? you want money off of me to tell me how to solver it, so shove off
Aug 28, 2008 | Zanussi FS1455W Front Load Washer
Motorola V262 flashing triangle: what's it mean?
This means that the phone is roaming from the home network
Oct 30, 2007 | Motorola Mobility V262
Slendertone Fortex Logo
489 people viewed this question
Top Slendertone Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Slendertone Exercise and Fitnes Expert? Answer questions, earn points and help others
