Question about Dell Computers & Internet
My batery no charging because the module bay no install
  • 2,567 Answers
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Posted on Sep 17, 2010
Batery meter
Check your battery if it is properly seated. Try removing and re-install the battery.
Else, your battery could be bad (not charging). How old is your Dell?
Feb 14, 2013 | Dell Inspiron M5030 Laptop
I have a 2004 Kawasaki zzr 600 that does not keep the charge longer than 2 days. What is causing this problem
hi, you probably have a "almost dead" batery, but in order to properly check, proceed as folows:
1 - give the batery a full charge
2 - disconect both cables (+) and (-) from batery
3 - check charge and see if batery holds it - a good batery must keep 12,7 to 13,2 volts for a very long period
If after this test,considering that batery is ok, then chek your wiring loom for ground losses
good luck
Sep 13, 2011 | 2004 kawasaki ZZR 600
Change or charge battery
Hi, depending on what happens when the batery is fully charged, does it go flat aftera day or two or does it stay charged? If it keeps going flat take it to a battery centre to test the amps that the batery makes. I f the amps is out the battery is dead.
But
If the batery is fine after charged and the amps is correct and the bike still makes the batery flat.
Then you have to replace the Stator and the magnitor.
Dec 09, 2010 | Yamaha YZF-R1 Motorcycles
I'm having a real problem using my Acer8920g set-up with dual channel memory. Basically I get a lot of screen freezes and blue screens when both these ram modules are installed. I have two identical...
when you test the ram modules separately, did you test them in the same bay...or have you tested both sticks separatly in both bays?
this sounds like a non responsive ram bay and may indicate that you need a new motherboard. Check to see if your motherboard has any bulging capacitors or other visual dammage.
Mar 16, 2010 | Computers & Internet
I got Nokia N99i chinese version cellular phone with 2 batteries, one battery worked for 3 months & now charging isn't holding & other battery can't charge since bought. How can i buy a new battery...
Men you really got a problem!
ok Try Ebay, if not www.alibaba.com sure you can find the batery there.
Other ways:
the batery its not charging at all?
you can buy a Universal Batery Cell phone carger, these ones got the ability of charge some times baterys whit thiis kind of problem.
Make an adaptation from other batery (just look details as Voltage, amps) sometimes its require soldering directly to your phone :S (pretty extreme)
Oct 17, 2009 | Cell Phones
Module Bay
The D610 second battery is installed in the slot occupied by the CD Rom.
This is an additional omponent that can be purchased to extend the battery life for the laptop.
Unless you have this battery module installed the error is completely normal.
Jun 04, 2009 | Dell Latitude D610 Notebook
Batery hang problem
batteries have a charge memory in the, when you purchase a new battery the best thing to do is to fully drain the battery before charging it up, this will tell the battery that it needs full charge, if you charge the battery before this it will only charge the battery to a certain percentage.
what you need to do now is find a way to fully discharge the batteries
kind regards
Dec 23, 2008 | HP Compaq Business NX9110 Notebook
Original shape oakley thump
www.baterysplus.com
www.batteriesbatteriesbatteries.com comp usa staples
bestbuy circuit city radio shack <<< blah order direct from oakley and get quality
my spelling bad this morning bare with me i might not have spelled baterys right
Jun 02, 2008 | Oakley Thump MP3 Player
Computers & Internet Logo
16 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
