Question about Canon Office Equipment & Supplies
I'm a technitian fixing copier machines. I got a problem while i was fixing CANON IR 8500 model. The machine stops and is turned off automatically eventhough it was running. If I turn on the machine right after it stops, it doesn't come back. but, if I turn it on after more than few hours, it got back but stops again. I've checked the electricity switch, but there was no problem at all. So, could you tell me what should I do to fix this machine please? It would be better if you tell me how to do it step by step. Thank you!
  • 2,272 Answers
This problem is related to power supply board of the copier.This board gets overheated and turns the printer off automatically.In some cases the power supply board has to be replaced.But in some cases the faulty component on the power supply board will be seen automatically .Either it will be bulged capacitor or leaked capacitor from its top.Or a burnt component with black burn marks.If nothing is seen then the components has to be checked by meter or the power supply board has to be replaced.The power supply board is the board to which the power wire of the copier connects.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Sep 15, 2010
Ir 85 error code E000015-0000
hello
8500 IR copy machine
E00015 - 0000 errors.
Please guide me.
I also translated by the site you have to translate the sentences. So you have the goodness wording is easy.
Thanks
Nov 19, 2012 | Canon imageRUNNER 8500 Copier
Error E354-0002 ir 8500
Error E354 in Canon iR 2016
error e354 code appear when you replace PCB controller board.
Please note. Before replace your PCB board with other one.
Pull out a small (FRAM COUNTER) chip from your old PCB board you can found it right side of the PCB board near a battery cell the chip attached with screw open screw and pull it out and attached it with your new PCB board .install your PCB board in the machine and turn on power error e354 will go off.
Aug 27, 2011 | Canon imageRUNNER 8500 Copier
Error E007 Canon Image runner 2020 Will not finish perinting a document with the above mentioned error
The error code E007 is a fixing film error code > it will have to be replaced to clear the code. That is if it a IR-2020, a IR-8500 does not have a fixing film.
Aug 20, 2010 | Canon imageRUNNER 8500 Copier
Sir; i have a canon ir 6000i model machine
these is often sympthom when there is fixing trouble, usually when there is error code like E000, E001, E002, E003...
If you want send me e-mail on emma.servis@gmail.com for service manual.
Aug 03, 2010 | Canon imageRUNNER 5000 Copier
Canon ir 8500 cannot detect A4 paper in auto mode.any idea how to set this up?
there is a good possibility that the main thermistor and the sub thermistor has gone bad or is dirty. also it might need adjusted to be better placed next to the upper fixing roller.
May 12, 2010 | Canon imageRUNNER 8500 Copier
Canon ir 8500 error code 001-010 and E 001-003
You can start by downloading this software, a new driver dated April 7, 2009
canon driver for the ir 8500
Apr 15, 2009 | Canon Office Equipment & Supplies
Copier model canon ir 2016 (down load stand by )
hi if yo have knowledge on electronics try to remove the boot rom and memory and let the machine for 10 minutes,then put it back the memory and boot rom,and turn on the machine.if the same thing try to update the firmware using sst
Mar 06, 2009 | Canon iR 2016i Black and White Copier
ERROR IN IR 8500
eo 732 is a reader board error or a bad or missing connector from the scanner to the machine looks like a parrallel connector
Dec 25, 2008 | Canon imageRUNNER 8500 Copier
Canon ir 8500
E010 relates to a main motor fault. A specified amount of rotations has not occurred within a set time. Check motor, see if it turns by hand. If not, inspect and/or replace. Check belts and gears for wear/damage, replace as necessary. E065 relates to a primary charging problem. Suspect primary corona arcing, corona wire broken, High-Voltage PSU may be unservicable, black developer unit may be pulling HVT down. How many copies has each machine done? Recommend calling an engineer, parts are probably required.
Sep 09, 2007 | Canon imageRUNNER 400S Copier
old marine
old marine
