Question about White Sewing 1521
White 1475 jeans machine
I bought this great sewing machine from a thrift store for 14 dollars, it does great stitches, i made a knapsack from an old scarf on it for my journal, devotionals and bible, I was just wanting a pdf manual for this machine, if someone could post one, it would be helpful to me and other people who have the machine
    Problem Solver:
  • 6 Answers
You can download White manuals from Singer. Just go to http://www.singerco.com/accessories/manuals.html and type W in the search box. The next page will be a list of White machines with manuals available. They may not have the exact model (as in my case), but there will be a similar one.
Posted on Jun 03, 2009
Company recomendated any table to use sewing machine 1507
if it is an ordinary sewing machine then any old table will do
kitchen, dining , bedside any table that you can sit at with your knees under it
Jun 14, 2015 | Sewing Machines
Sewing machine service manual
Hi I'm PeterThere are several sites where you can download manuals just google them. I bought a used machine from a thrift store for 10 dollars and downloaded the complete manual that I printed out and put in a nice folder.
Aug 04, 2014 | Montgomery Ward Sewing Machines
I bought a yamata fy-900 from a thrift store. used it for a couple of days, it worked fine untill i tryed to sew a pair of jean pants and the needle got stuck and it hasent worked right sence it does not...
You have probably knocked out the timing on the machine. Most household machines, inexpensive machines especially will not sew denim without a fair amount of coaxing. Check the threading and do try on lighter fabrics first. to see if its just the denim.
Derek
Jan 17, 2011 | Yamata FY900 Mechanical Sewing Machine
I saw a white sm2000 in a thrift shop. it was in decent condition and the needle moved smoothly. I was wondering if this machine would be worth getting. I have reservations because of all the negative...
There's nothing wrong with the newer plastic sewing machines. Most of them are plastic now and not as heavy as the old metal ones. You said that the needle moved smoothly but what you need to know is if the needle thread picks up the bobbin thread. If you don't know how to thread the machine either check the manual or ask someone in the shop to thread it. If anyone there sews, they will know how to thread it. If the machine makes a stitch go ahead and get it. It the bobbin thread is not picked up by the needle thread IT WON'T STITCH and then you'll know that the timing is off. That's a repair job and will be way more than what you paid in the thrift shop.
Sep 09, 2010 | White Sewing SM2000 Sewing Machine
Does it make a difference whether I use a 14 or 16 in my Kenmore sewing machine, basic 12 stitch. I had a 16 needle in it but after my friend cleaned it, in trying it, the needle hit the presser foot>...
Hi. You use different size needles for different fabrics and fabric weights. Size 16 needles are used for heavy fabric, like canvas, duck, or blue jeans. Size 14 needles are still on the heavy/thick fabric size. Size 10 needles are for very light-weight fabrics and size 12 needles are for medium-weight fabrics. Also, you need to pay attention to the type of fabric--if sewing on knits, you need ballpoint needles. If sewing on woven fabrics, you need sharps or universals. Universals are supposed to be for knits, too....but ballpoint needles are SO much better!
Use the right size and type of needle for your fabric, don't sew over any pins (they can bend or even break the needle), and make sure you don't pull or push the fabric while you're sewing on it. Let the feed dogs do the work of moving the fabric--you just gently guide it.
Hope this helps!
Aug 25, 2010 | Kenmore Sewing Machines
How do you adjust the size of the stitch on a Jeans Machine 1899 sewing machine?
to adjust the stich. there is a wheel infront of your machine, adjust it find the right stich of your jeans.
Mar 30, 2010 | White Sewing Sewing Machines
Hemming Levi's for husband. Using thick "jean" thread. Used 16 needle. Top stitch is perfect, bottom thread is anything but straight. I've re-threaded, cleaned the "hook", changed to a 14 needle. I...
Hi! Sounds like you're doing everything right to me, so let's see.
By not getting a straight stitch on the bottom, do you mean that the bobbin thread is loopy? If so, then most likely you have to reset the tension. Get a scrap of jeans material and practice on that....it would be great if you could use different color threads on top and in the bobbin, but that might not be practical if you don't have the jeans thread in different colors already.
You'll be adjusting the top tension, because even tho the top stitch looks perfect, it may not be tight enough to pull the bobbin thread up into the fabric where it belongs.
Sew a couple of inches on your scrap, then stop and check the bobbin thread. If it's loopy, you can also see the top thread on the underside. (Which is why using two colors is helpful.) With the pressure foot down, tightened the top tension just a bit. Sew a few more inches and check again. Keep on sewing, checking, and adjusting until you can't see any (or almost any) top threads on the bottom or bobbin threads on top.
Here are a couple of other ideas to check:
1. Make sure your bobbin is inserted correctly. If I happen to put one in backwards by mistake, the bobbin will make a lot of clanking noises.
2. Using your flywheel, lower the needle all the way through the stitch-making process to see if it's hitting anything along the way.
3. Oil your machine.
4. Make sure all the screws etc on your throat plate (also called needle plate) are tight. (I've had mine get loose and that will definitely throw a knock into the works!)
Check out these ideas and let me know if anything works, or if the problem is still there, ok?
Happy Sewing!
Robbie
Feb 18, 2010 | Singer 7466 Mechanical Sewing Machine
White 1599 jeans machine
Beginner problem
I need instructions on how to use White Jeans Machine model # 1810. Will someone please post the instruction manual.
Jul 08, 2008 | White Sewing 1521
White Sewing 1521 Logo
465 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
