Question about Sony VAIO Digital Studio PCV-RX650 PC Desktop
Installing standard third-party optical drives in VAIO PCV-650 case
My Sony VAIO PCV-650 has a dead DVD drive. I am sufficiently hardware-competent to replace the drive with a new one, except for one thing:
The case front panel has nonstandard half-height openings in front of its removable-media drive bays, and there doesn't seem to be an obvious way to remove the panels which block the other half of the opening..
Do those panels interfere with the ability of generic third-party optical drives to open and close? Do I *have* to get a Sony-branded replacement drive? What do I do to get a working DVD drive into that horrible case?
    Problem Solver:
  • 8 Answers
Hi there. I've worked for Sony VAIO and can assure you that the only solution is to get a Sony Branded Spare parts. The parts of Sony VAIO are very specific. As of now I see that the only solution for you is to either contact Sony Service Center or go for an external DVD Drive.
Posted on Jul 12, 2010
Sony vaio dvd stuck
If your optical drive is the open kind, just get a pin, look for little hole in the hardware and push it in, this will take out the stuck DVD. If the optical drive is the one that swallows the disk, then you need to take out the hardware.
Jun 20, 2013 | Computers & Internet
Hi can Sony Vaio PCV-RS602 mother board support a sata hhd
Yes,Specs says that it has SATA controller:
Product Description: Sony VAIO PCV-RS602 - P4 3.2 GHz
  • Type: Personal computer
  • Form Factor: Tower
  • Processor: 1 x Intel Pentium 4 3.2 GHz
  • Processor Main Features: Hyper-Threading Technology
  • Cache Memory: 1 MB L2 Cache
  • Cache Per Processor: 1 MB
  • RAM: 512 MB (installed) / 2 GB (max) - DDR SDRAM
  • Storage Controller: Serial ATA ( Serial ATA-150 ) ; IDE ( ATA-100 )
  • Floppy Drive: 3.5" 1.44 MB floppy
  • Hard Drive: 1 x 160 GB - standard - ATA-100
  • Optical Storage: DVD±RW
  • Optical Storage (2nd): DVD-ROM
  • Card Reader: Yes
  • Monitor: None.
  • Graphics Controller: AGP 8x - ATI Radeon 9600 XT
  • Video Memory: 128 MB
  • TV Tuner Type: Analogue TV
  • Audio Output: Sound card - 5.1 channel surround
  • Communications: Fax / modem - 56 Kbps
  • Networking: Network adapter - Ethernet, Fast Ethernet
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
    Thanks, Joe
    Feb 06, 2011 | Sony VAIO RS602 (PCV-RS602) PC Desktop
    How to expand c drive
    you can use third party software like partion magic to expand c drive
    Nov 23, 2010 | Sony VAIO Digital Studio PCV-RZ24G PC...
    Replacement for Sony Vaio optical disk
    Your computer is an older pentium 4 PC. As such it uses ATA / IDE - EIDE drives. These days stores sell SATA drives but IDE drives are still VERY COMMON. You can find tons of them on eBay or your local computer store (for much more than eBay). The original drive has a 24x CD reader, 8x CD-r writer and a 4x DVD reader. It does not write DVDs. You can buy any ATA/IDE drive you like and now you can probably afford a DVD burner too.
    Apr 23, 2010 | Sony VAIO Digital Studio PCV-RX670...
    Sony Vaio Notebook's blu-Ray optical drive stops during DVD play
    The laser is definitely weak on that drive, it takes alot of power to play blu-ray discs and if the laser may have been slightly defective to begin with then that can cause the drive to act funky the way it has been.
    Whatever blu-ray drive you get doesn't matter as long as the shape of it is the same as the one you have now cause all you would have to do is change out the front door and the screw holder on the back of the drive, then because the shape of the drive is the same, you can move it back into its slot.
    Your notebook is new enough to where any drive will work in it.
    Jul 04, 2009 | Sony Computers & Internet
    Hardware Monitor Problem Sony Vaio
    have you tried installing a seperate controller card?
    Jan 27, 2009 | Sony VAIO Digital Studio PCV-RX580 PC...
    Replacing the powersupply on a Sony VAIO PCV-RS720G desktop
    Hi There,
    From the looks of things that model will take a standard ATX power supply which would be available from and computer part dealer and ebay etc, get yourself a nice 400w replacement try and get a small form factor one if you can as it will be a tight sqeeze inside the case.
    when replacing it you will have to open the case up (get an anti static wristband if you can, and work on a table rather that a carpeted floor) un hook all the connectors the old power supply (one in each drive and there should be 2 in the motherboard) you may have to pull the Dvd rom out slightly to get the new supply in, unscrew the 4 case screws holding the power supply from the back of the case. lift it out then put in the new one, screw it in using the case screws and connect up the internal power cables to the drives motherboard and new graphics card, close the case, plug in and voila
    If you get stuck just ask and we will help
    Dec 10, 2008 | Sony VAIO PCV-RS720G (027242658103) PC...
    CD/DVD ENCLOSURE in Sony Vaio PCV RX860
    http://esupport.sony.com/US/perl/tutorial-display.pl?tut_id=269&mdl=PCVRX860
    this link is a tutorial of how to get the side panel off,
    to get the cd drive out, you need to do a couple more steps.
    first, you will need to take off the top and other side panels. this can be done by looking at the top back of the case. there are two clips that hold the top panel on. push up on the two clips and the top part will slide back and you can pull up on the panel and it should come off.
    Next, you should be able to push some more clips on the top to get the side panel off. it should fold down just like the first side.
    then, you need to take off the front two panels. the bottom part should be just a couple clips on the inside front of the case, and the top clips will be revealed when you take off the bottom part.
    after that is done, you should be able to unscrew the cd/dvd drive from the case and unplug the cables connected to it from the top where you removed the top panel.
    then you should be done
    Jun 02, 2008 | Sony VAIO Digital Studio PCV-RX860...
    Sony PCV-RS720G - DVD-Rom gone bad
    Here is a link to instructions that detail how to replace a hard drive but it shows you how to open the case: javascript:moreinfowindow('http://www.iq.sony.com/srvs/DocsConnect/docget.asp?manualid=90411&DL=',600,560,10,10,'Manuals')
    Jul 26, 2007 | Sony VAIO PCV-RS720G (027242658103) PC...
    Sony VAIO Digital Studio PCV-RX650 PC Desktop Logo
    273 people viewed this question
    Top Sony Computers & Internet Experts
    Alun Cox
    Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
