Question about Cisco Linksys E1000 WirelessN Broadband Router Network Routers
I am trying to restore factory default for 192.168.1.1
I try to restore factory default, but after the beeping the options don't list a "recovery of factory default software"
then it may not have the software installed on it todo it.
try doing a full recovery disc of your windows then try and do a restore or factory reset.somtimes that works.
Jun 19, 2014 | Toshiba Satellite Computers & Internet
Dvr ja7204
Restoring Default Settings
To restore factory default settings to your DVR:
1. Enter the Factory Default menu, by going to Main Menu > Maintenance > Factory Default.
2. Select the OK button to restore factory defaults or select the Cancel button to return to the previous menu.
Note: Network information such as IP address, subnet mask and gateway will not be restored.
hope thid helps. and you can also try removing all power from unit if it does not have inturnal battery. if it does have an internal battery after removing all external power you will have to remove battery to completely reset. Note the latter suggestion will void warrenty if you have to open the unit to remove the battery.
GOOD LUCK :-)
Jun 14, 2014 | Computers & Internet
How do I factory reset a Lexmark x658de?
When you first enter the printer menus from the operator panel, you may notice an asterisk (*)
next to a value in the menus. This asterisk indicates the factory default setting. These settings
are the original printer settings. (Factory defaults may vary for different countries.)
When you select a new setting from the operator panel, the Saved message appears. When
the Saved message disappears, an asterisk appears next to the setting to identify it as the
current user default setting. These settings are active until new ones are stored or the factory
defaults are restored.
To restore the original printer factory default settings:
1 Make sure the printer is on and the Ready message appears.
2 Press Menu until you see Utilities Menu, and then press Select.
3 Press Menu until you see Factory Defaults, and then press Select.
4 Restore appears on the second line of the display.
5 Press Select.
The message Restoring Factory Defaults appears followed by the Ready
message.
When you select Restore:
No other button actions are available on the operator panel while Restoring
Factory Defaults appears.....
May 01, 2014 | Lexmark X658DE All-In-One Laser Printer
Im trying to factory restore my vaio what does "do
It means do you want to change the default factory partition size (ie. the size of the C Drive). I suggest you select No because you may have a Restore partition on the hard drive and if you change the partition size you may wipe out this Restore partition and you will not be able to do any future factory restores.
May 02, 2013 | Computers & Internet
Reset factory settings on hp deskjet 1050
Reset the Printer to Factory Default Settings Restore factory settings Restoring the factory-set defaults returns most of the settings to the factory defaults. It will not reset the page count, tray size, or language. To restore the product to the factory-default settings, follow these steps.
  1. Turn the product off. Disconnect the power cable from the product for 30 seconds and then reconnect.
  2. Turn the product on while you press and hold the Resume c02469297.gif button for 10-20 seconds. The Attention c02469293.gif light turns on.
  3. Release the Resume c02469297.gif button. The Attention c02469293.gif and Ready c02469296.gif lights cycle while the product restores factory defaults.
Reset HP 1050 DeskJet Series Cartridge
Jun 07, 2012 | HP Office Equipment & Supplies
I want to do a factory restore on my laptop with no cds
hi there,
You can try these steps:
  • 1
    Click "Start" menu.
  • 2
    Click "Programs."
  • 3
    Click "Acer Recovery Management."
  • 4
    Click the "Restore" button on the bottom of the dialog box that opens.
  • 5
    Click "Restore System to Factory Default."
  • 6
    Click "Yes" in the warning dialog box which asks if you wish to continue the recovery process.
  • 7
    Click "Start" to restore the computer to the default factory settings.
  • Hope this helps!
    Jul 04, 2011 | Acer Computers & Internet
    I am trying to change color laserjet 2600n back to English and need some assistance. can you help?
    Restoring the factory-set defaults returns all of the settings to the factory defaults.
    To restore the factory-set defaults
    1 (LEFT ARROW) or the (RIGHT ARROW) button to select Service, and then press
    Use the
    (SELECT).
    2 (LEFT ARROW) or the (RIGHT ARROW) button to select Restore defaults, and then
    Use the
    press (SELECT).
    The device automatically restarts.
    Then you need to change the default settings back to what they were.
    Oct 19, 2010 | HP Color LaserJet 2600n Printer
    How to reset factory defaults to CK31? How I can put the settings to access WPA2 in wireless network?
    You can restore the CK31 to factory default settings from
    Intermec Settings.
    Note: Using the Restore Defaults option restores all parameters
    including network settings. When you choose to restore defaults,
    you erase the registry. As a result, you may lose network
    communications.
    1 From Intermec Settings, select Device Settings > Restore
    Defaults.
    2 Select Restore Defaults and choose the Run App button. A
    Run Application dialog box appears asking if you want to run
    the restore defaults program.
    www.portablesolutions.com
    May 12, 2010 | Intermec CK31 Portable Terminal
    Forgot password to acess< and or its still default setting. could you tell me what the wireless 700 routers default password is
    Restore Factory Default Settings When you restore factory default settings to the base station, you clear your Internet connection settings and any special base station configurations that you have established. After the restore is complete, you will need to reconfigure your base station settings or restore these settings from a backup file. You should restore the original factory default settings only under the following circumstances: O You are experiencing serious problems with your base station, and resetting the base station does not fix the problem. O You cannot remember your base station password. In this situation, you must restore the factory default settings by using the Restore button on the base station, and then use the default password admin to log on to the Base Station Management Tool. To restore factory default settings 1. Open the Base Station Management Tool, and then click Management. 2. On the Management menu, click Back Up and Restore Settings. 3. Under Restore factory default settings, click Restore Factory Default Settings. While the original factory default settings are being restored to the base station, the Power light on the base station turns orange. When the light is solid green, the settings have been restored. If you want to open the Base Station Management Tool after the settings have been restored, type admin as the password on the Logon page. Do not attempt to log on to the base station until the settings are restored and the Power light on the base station is solid green. After you restore the factory default settings to the base station, you should navigate to each page of the Base Station Management Tool and reestablish the network settings you want, or restore the base station settings by using a backup file. For information about creating a backup file of your settings, see the following section. Be sure to establish your unique base station password as soon as possible after restoring the factory default settings to prevent unauthorized users from logging on. For more information, see “Change the Base Station Password.” please rate this answer, thanks
    Jan 30, 2009 | Microsoft MN-700 Wireless Router
    Cisco Linksys E1000 WirelessN Broadband Router Network Routers Logo
    297 people viewed this question
    Top Cisco Computers & Internet Experts
    Prashant M
    Prashant M
    Gareth Tomlinson
    Gareth Tomlinson
    Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
