Question about Garden
Cabinets built in 1961. Looking for center rear mounted guide rollers approx. 1 inch across and 1/4 to 3/8 in diameter
  • 10,865 Answers
Hello. Replacing the old drawer slide with the exact same thing is not necessary. Most drawer slides can be installed with success. Home Depot, Lowes, and most hardware stores have a wide selection of drawer slides. Joe
Posted on Sep 17, 2010
How many pieces 3.25 x 2.0 inches can be cut from a 8 1/2 x 11 inch sheet of Cardstock?
12. 3 across and 4 down with both the sheet and the labels in landscape rotation.
Oct 24, 2016 | Office Equipment & Supplies
I need a new SHENG BANG HD-1688 AA VOLT BATTERY MOVEMENT
Check on Amazon or Madeinchina .com, Tradetang may be a good place too
Nov 11, 2014 | Watches
How do you take a stand off
There are 4 screws found in the center bottom of rear plastic back. 2 at top and 2 at bottom - approx 1/2 inch from bottom the 1st 2 will be about 3 inches apart - then directly above there are 2 more. These screws hold the bracket that holds the stand. Once you remove the bracket there should be no parts sticking out further than the actual television and can now be mounted to the wall with a mounting system.
Jul 20, 2014 | LG 42LH30 42 in. LCD TV
Ihave 2 sony xs-gtx120Lw 12' going in a 04 honda civic. I want to build a box but do not have the specs for them subs in a ported box
here are the specs
  • Depth (Approx.) : 5 3/4"
  • Diameter (Approx.) : 12"
  • Dimensions (Approx) Depth : 5 3/4"
  • Mounting Dimensions (Approx.) : 13" OD, 5 3/4" mounting depth and 11" mounting diameter.
  • Weight (Approx.) : 11 lbs. 11 oz.
  • Power Handling Capacity : 1000 Watts Max
  • Rated Input : 300 Watts
  • Magnet : Ferrite
  • Material : Polypropylene cone
  • Frequency Response : 30 - 1000 Hz
  • Impedance : 4 Ohms
  • Sensitivity (db) : 86 +/-2dB (1W, 1m)
  • Jun 03, 2011 | Car Audio & Video
    What is the clearance for rod bearings on the crank of a 98 ford f 150 4.6
    General Specifications Item Specification
    Displacement L (CID) 4.6 (281)
    Number of Cylinders 8
    Bore and Stroke mm 90.2 x 90.0
    Firing Order 1-3-7-2-6-5-4-8
    Oil Pressure (HOT @ 1500 rpm) kPa 138-310
    Drive Belt Tension a
    Cylinder Head and Valve Train
    Combustion Chamber Volume cm 52?±.5
    Valve Seats Width?€"Intake mm 1.9-2.1
    Valve Seats Width?€"Exhaust mm 1.9-2.1
    Valve Seats Angle 44.51-45.01 degrees
    Valve Seats Runout (T.I.R.) Max mm 0.025
    Valve Arrangement (Front-to-Rear) (Left Hand) E-I-E-I-E-I-E-I
    (Right Hand)
    I-E-I-E-I-E-I-E
    Valve Stem to Guide Clearance?€"Intake mm (Inch) 0.020-0.069
    (0.00078-0.00272)
    Valve Stem to Guide Clearance?€"Exhaust mm (Inch) 0.045-0.095 (0.0018-0.0037)
    Valve Head Diameter?€"Intake mm (Inch) 44.5- (1.75)
    Valve Head Diameter?€"Exhaust mm (Inch) 34.0 (1.34)
    Valve Head Diameter?€"Gauge Diameters mm (Inch) 42.5- and 32.0
    (1.67 and 1.26)
    Valve Face Runout Limit mm (Inch) 0.05 (0.002)
    Valve Face Angle 45.25-45.75 degrees
    Valve Stem Diameter (STD)
    ?€"Intake mm (Inch) 6.995-6.975 (0.275-0.2746)
    Valve Stem Diameter (Std)
    ?€"Exhaust mm (Inch) 6.970-6.949 (0.274-0.2736)
    Valve Springs?€"
    Compression Pressure N @
    Spec. Length?€"Intake 587.14 N @ 28.02 mm
    Valve Springs?€"
    Spec. Length?€"Exhaust 587.14 N @
    28.02 mm
    Valve Springs?€"Free
    Length ( Approximate)?€"
    Intake mm (Inch) 49.55 (1.951)
    Length (Approximate)?€"
    Exhaust mm (Inch) 49.55 (1.951)
    Valve Springs?€"Installed
    Pressure N @ Spec. Length
    ?€"Intake 244.64 N @ 40.0 mm
    Valve Spring?€"Installed
    ?€"Exhaust 244.64 N @ 40.0 mm
    ?€"Service Limit 10 % Pressure Less @ 28.02 mm
    ?€"Out of Square Limit 2 degrees
    Valve Guide Inner
    Diameter mm (Inch) 7.015-7.044 (0.2761-0.2773)
    Rocker Arm?€"Ratio 1.75:1
    Valve Tappet?€"Diameter
    (STD) mm (Inch) 16.000-15.988 (0.66-0.629)
    Valve Tappet?€"Clearance
    to Bore mm (Inch) 0.018-0.069
    (0.00071-0.00272)
    Valve Tappet?€"Service
    Limit mm (Inch) 0.016 (0.00063)
    Valve Tappet?€"Hydraulic
    Leakdown Rate b 5-25 seconds
    Valve Tappet?€"Collapsed
    Valve Tappet Gap?€"
    Desired mm (Inch) 0.085-0.45 (0.0033-0.0177)
    Camshaft
    Lobe Lift?€"Intake
    mm (Inch) 6.58939 (0.2594)
    Lobe Lift?€"Exhaust
    Lobe Lift?€"Allowable
    Lobe Lift Loss mm (Inch) 0 (0)
    Theoretical Valve Lift @
    Zero Lash?€"Intake
    mm (Inch) 12.0 (0.472)
    Zero Lash?€"Exhaust
    End Play mm (Inch) 0.025-0.165
    (0.00098-0.0065)
    Journal to Bearing
    Clearance mm (Inch) 0.025-0.076
    (0.00098-0.003
    Journal to Bearing
    Clearance?€"Service Limit
    mm (Inch) 0.021 (0.0048)
    Journal Diameter (All)
    mm (Inch) 26.962-26.936
    (1.061-1.060)
    Journal Diameter (All)?€"
    Bearing Inside Diameter
    (All) mm (Inch) 27.012-26.987
    (1.063-1.0625)
    Camshaft Runout
    Cylinder Bore
    Diameter?€"Surface Finish
    (RMS) 0.2-0.6 Microns
    Diameter?€"Out-of-Round
    Limit mm (Inch) 0.015 (0.0006)
    Service Limit mm (Inch) 0.020 (0.00079)
    Diameter?€"Taper Service
    Limit mm (Inch) 0.006 (0.00023)
    Piston
    Piston?€"Diameter?€"
    Coded Red 1 mm (Inch) 90.177-90.197
    (3.550-3.551)
    Coded Blue 2 mm (Inch) 90.190-90.210
    (3.5507-3.5515)
    Coded Yellow 3 mm (Inch) 90.203-90.223
    (3.513-3.5521)
    Piston-to-Bore-Clearance
    mm (Inch) -0.015 + 0.031 (0.0005-0.0012)
    Pin Bore Diameter
    mm (Inch) 22.0015-22.004
    (0.866-0.8663)
    Ring Groove Width?€"
    Compression (Top)
    mm (Inch) 1.520-1.550 (0.06-0.610)
    Compression (Bottom)
    mm (Inch) 1.520-1.530 (0.060-0.0602)
    Ring Groove Width?€"Oil
    Ring mm (Inch) 6.996-7.224 (0.275-0.2844)
    Piston Pin?€"Length
    mm (Inch) 61.93-62.05 (2.44-2.443)
    Diameter mm (Inch) 21.994-21.999
    (0.866-0.8661)
    Pin to Piston Clearance
    mm (Inch) 0.005-0.010
    (0.0002-0.0004)
    Pin to Rod Clearance
    mm (Inch) 0.015-0.040
    (0.0006-0.00157)
    Piston Rings?€"Ring Gap
    ?€"Compression (Top)
    mm (Inch) 1.0 MAX (0.0394)
    Oil Ring?€"Side Clearance
    mm (Inch) 1.25 MAX (0.05)
    Oil Ring?€"Compression
    (Top) mm (Inch) 0.040-0.090
    (0.0016-0.0031)
    (Top) mm (Inch) 0.030-0.080
    (0.0012-0.00031)
    Oil Ring Snug Fit
    Oil Ring?€"Service Limit
    mm (Inch) 0.015 MAX (0.0006)
    Ring Gap?€"Compression
    (Top) mm (Inch) 0.23-0.49
    (0.01-0.02)
    (Bottom) mm (Inch) 0.23-0.49
    (0.01-0.02)
    Ring Gap?€"Oil Ring (Steel
    Rail) mm (Inch) 0.05-0.66 (0.006-0.026)
    Lubrication System
    Oil Capacity?€"Automatic
    Transmission (Quarts U.S.) 6.675?±0.125
    Oil Capacity?€"Manual
    Transmission (Quarts U.S.) 6.425?±0.125
    Cylinder Block
    Main Bearing Bore
    Diameter mm (Inch) 72.401-72.422 (2.85-2.851)
    Crankshaft and Flywheel
    Main Bearing Journal
    Diameter mm (Inch) 67.483-67-503 (2.65-2.657)
    Connecting Rod Journal?€"
    Diameter mm (Inch) 52.988-53.003
    (2.0861-2.0867)
    Crankshaft Free End Play
    mm (Inch) 0.130-0.301 (0.0051-0.012)
    Crankshaft Runout to Rear
    Face of Block mm (Inch) 0.050 MAX (0.002)
    Connecting Rod Bearings
    Clearance to Crankshaft?€"
    Desired mm (Inch) 0.027-0.069 (0.001-0.0027)
    Allowable mm (Inch) 0.027-0/069 (0.001-0.0027)
    Bearing Wall Thickness
    (STD) mm (Inch) 2.44-2.452 (0.096-0.0965)
    Main Bearings
    Desired mm (Inch) 0027-0.065
    (0.0011-0.0026)
    Allowable mm (Inch) 0.027-0.065
    (0.0011-0.0026)
    (STD) mm (Inch) 1.920-1.928 (0.075-0.076)
    Connecting Rod, Piston and Rings
    Connecting Rod?€"Piston
    Pin Bore Diameter
    mm (Inch) 21.959-21.979
    (0.864-0.865)
    Connecting Rod?€"
    Crankshaft Bearing Bore
    Diameter mm (Inch) 56.756-56.876 (2.234-2.24)
    Connecting Rod?€"Length
    (Center-to-Center)
    mm (Inch) 150.7 (5.93)
    Alignment (Bore-to-Bore
    Max. Diff.) c ?€"Twist
    mm (Inch) 0.050 per 25 (0.0015-0.984)
    Max. Diff.)?€"Bend
    mm (Inch) 0.038 per 25 (0.0015-0.984)
    Side Clearance (Assembled
    to Crank)?€"Standard
    mm (Inch) 0.015-0.45 (0.0006-0.0177)
    to Crank)?€"Service Limit
    mm (Inch) 0.05 MAX (0.02)
    Crankshaft Main Bearing
    Journal Taper mm (Inch) 0.020 (0.0007)
    Journal Runout mm (Inch) 0.05 (0.002)
    Crankshaft Connecting Rod
    Journal Taper mm (Inch) 0.015 (0.0006)
    Feb 15, 2011 | 1998 Ford F150 Regular Cab
    I have a Speedaire model 3z492 air compressor. The manual is gone and the information plates as well. I need to know if this model is cappable of maintaining 100 psi @ 10cfm? Any ideas?
    Here is info I found "Pump:
    Two Stage, Cast Iron, Compressor Pump, 5 HP, 17.1 CFM Maximum Free Air Flow At 175 PSI Maximum, 2 Cylinder, Oil Capacity 2 Quarts, Pump Speed 685 RPM, Bore Size 4 3/4 x 2 1/2 Inches, Stroke 3 Inches, Motor Sheave Diameter 6.75 Inches, Flywheel Diameter 16 1/2 Inches, W 18, Depth 16 1/2 Inches, Height 22 1/4 Inches, Outlet 3/4 Inch NPT, Mounting Holes 8 3/4 x 5 3/4 Inches"
    Nov 08, 2009 | Air Tools & Compressors
    Dishwasher for 32 inch cabinets
    Miele makes a G600 series that are 32 1/4 " tall - that would probably be your best bet.
    Jan 05, 2009 | Dishwashers
    HP speaker
    The screws are little fatties,
    they measure 3/inch in height and 1/4 inch in diameter...
    just measured them for you!!!
    hope this helps!!
    Nov 17, 2008 | HP PL4260N 42 in. Plasma HDTV
    Small dent in paper
    check pc drum or fusing unit roller
    Oct 13, 2008 | Minolta 2430DL Color Laser Printer
    Garden Logo
    14 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
